The new bios really works...
f8x FTW
f8x FTW
Got my replacement board in today and everything is back up and running :)
Hmm, fresh flash F7E, try to OC from scratch, no matter what i do I get 4.5ghz, even with 49-50 multi selected.
I have to load a previous template in for it to work, WTF.
Really starting to hate this board.
Huum, try clear cmos, reflash ( try the F8x ), reboot and load optimized defaut .. maybe something who mess with turbo settings or something like that.
Hi.
Yeah, tried the power off, cmos clear. reboot, reload saved bios settings.
then a bunch of reboots, and back to square 1. the maddening thing is
I had stable system for a week or more, then suddenly it wont work.
I finally loaded F7A back, and kinda running ok again, will try F8X also.
try setting turbo enabled, disable EIST, C1E, C states, enable CPU PLL Overvoltage, set turbo multis all the same, set TDP and TDC to 300 each.
Getting nowhere with 58x. 57x I can do 57x 101 but cant even boot at 97 bclk at 58x
Need some help on this one, any idea?
It's with the new bios F8x...
Did you clear the cmos with the power supply unplugged (or switched off) after flashing? And did you flash with the DOS based spiflash (this is always the safest flasher).
My UD5 board was setting PCIE to 8x and anything less than 100.0 bclk, (and setting it to 8x on auto) until I cleared the CMOS...though I'm not sure if a previous overclock caused this or not, as I didn't notice it for days...
Endless reboots if i set it up as above, Was doing fine everything in CPU page set to auto, with 49 multi, then reboot and it acts like OC i was just running is failed. I loaded F8X with SPIFLASH and seeing how that goes.
BTW under memory settings for channel B it has a '-' instead of a value for I0. should it be this way? for channel A it has it set as '1' this is with redline 6-8-6
stuff, PSC i think?
Also notice i used to get splash screen right when i hot 50 on post, now it doesnt show up until after, this isnt just with F8X, noticed it with F7E and F7A
I will try F8x
He mate, got the same warning here with F7.
Seems to me its a bios issiue, because my only two USB components ( keyboard an mouse) where previously running fine on my X58A-UD7.
I've monitort it for a wile, because it randomly kept popping up. but i aint seeing any voltage spikes at the +5v line.
Here's mine :confused:
http://img808.imageshack.us/img808/3...ue1biosf71.png
My Asus boards have the same USB Overvoltage error too sometimes... more Intel chipset bugs plz
Hey guy's are there any reviews about the performance of an P67 board with and without NF200 to compare.
because its not a 100% clear to me what the nf200 Ads, because it only splits the lanes.
Sin i've read yours:up:, but that was in comparrison with X58. like to see a non Nf200 vs one with so that the Cpu can't compromize the score,
because SB is clock for clock faster then Bloomfield.
I also encountered the same problem, had only 1 usb logitech receiver connected to my pc for my mouse and keyboard use.
Eventhough it has not yet been confirmed it might be the Renesas chip / software causing this msge. to appear.
After I reinstalled the Usb software 20300 the error msg. /warning so far
dit not surface.
Here bios F8X Eldonko:) Vcore @ 1.58 with SS
Dang..pretty difficult board
http://img37.imageshack.us/img37/101...enshot003c.png
Niceley made Dumo ..
Anyway, you see a good difference with SS on it ? im in question if i mod the head of mine for try it on this baby ( just the fixation, not hard anyway ) ...
My CPU doesnt like several multis, 55x and 54x especially (56x and 57x work great) but I still get them to run. Once I finally get this thing to boot Im ok. Good point on the 97 bclk though, I havent tested that using other multis, Ill give that a try. I saw dumo run 58x so it cant be the BIOS. :up:
Tell me about "booting". Looks like my motherboard just doesn't like booting from the first time, ever. Thank god for that chipset bug, ill be able to switch to Asus Delux w/o any problems in April.
