Just make a screenshot like you did, paste into paint, then open GPU-Z and CPU-Z and take another screenshot. That's what I do. :up:
Which kit are you running anyway?
Most likely another 15L on wednesday, will continue to try some more. shamino already suggested a different uncore multiplier regarding my low coldboot problem, hope that helps. xcool jumper didnt work last time, but perhaps on LN2 now it will around - 80 / -100 , i know it does 5.4ghz 32M, i want to get a better 32M score.
And test some 06 / vantage clocking, last run i had was 5175mhz on vantage, im sure it can do 5.2ghz vantage aswell, it's uber awesome :D so think it does 5.3 / 5.4ghz 06, hope i can arrange it for wednesday!
Weird, I never encountered that.... I hope someone can help!
How did you get your first screenshot?
I think I read something about this problem....
It seems you need a newer Directpll, I hope AM3 will still work with another pll under Win 7 x64.
Wait, can you see the score and it shows up black in paint, or can't you even see the score at the end of AM3?
@thijs: Good luck! :up:
Hm... Can you at least edit your first score, the one you uploaded already, with the hardware info of some other score? So you can get some points.
I'm really sorry I can't help you out on this issue...
<-- I'm an addict now officially, though I have to admit I've been addicted for quite some time. :D
I'm off to bed now, c u tomorrow! :)
I make my AM3 screenshots with fraps. When run is finished, do ctrl+alt+del, run fraps, alt+tab back into am3, take a screen.
How did you do it?
Upload it to hwbot, using the HTML score isn't enough as it can be faked easily, so make sure to get the points and use this screenshot! :)
By the way, AM3 loves uncore speed from what I heard! ;)
another 1 for you
http://i107.photobucket.com/albums/m...tagehigh-1.jpg
Awesome results Bill! Wish I could have been there ;)
Well my motherboard prep line is done.....5 more boards prepped and ready to go....Need to chase a few small points on phase today I think.....Ln2 tommorow.
I also need to figure out what happened with my 03 run with a single 4850......I almost beat it last night with just water on cpu :shakes:
03 w/o tweaks
http://i107.photobucket.com/albums/m...d26/03high.jpg
Board 1 round 1 is over, time to move to a ddr III platform to better some of the memory intensive results. :up:
I thought it was time for another update:
http://img44.imageshack.us/img44/179...vember29th.jpg
At first of course the major contributor of this weekend, Bill and his 5GHz i7 960 with 3 5870s, scoring 172k in 03, 34k in 06, 37k in Vantage and 364k in AM3!
Next one is Hondacity pushing over 31k in 06 with a single GTX 295!
Then we have contributions by two members who do not post regularly, but it seems they do not forget about hwbot! :up:
Raiderman gets a nice golden cup in the Turion II X2 500 category, and Skinnee, most of the time found lurking in the WCG section of this forum, ran WPrime on his W3580 at 4.5Ghz on water.
Last but not least there are Brian's scores for the Athlon II X4 620 category, where he manages to get quite a few cups and medals.
Please get to the real hardware now though... :p:
And have a look at this:
http://img18.imageshack.us/img18/4251/xsgoup.jpg
We are going up up up in almost every benchmark! :up: :up: :up:
And can we say the race on 8000 points has started? :yepp:
Have a nice day! :)
Does anybody in the US have an AMD/Radeon platform to bench 3dmark vantage with for the country cup? chew* just put up a killer result, we now need 2 more results to get ranked! :D
I'm going to put up one this week so we'll need one more.... Mine should be between 12 and 15k with a 5870...
Glad to see you guys are organizing in some fashion. You guys have some kickass 5870/5970 results on the bot :up: Shocked what just simple watercooling does with those chips.
