I have a backplate that came with my Rocketfish case. It is labled as a Nocona mounting plate. It looks like the one from Performance PC's. If so looks like I am set for that.
So i need CPU and Ram then i am all set. Anyone have the ram link in handy? Thanks
http://www.newegg.com/Product/Produc...82E16820134272
yes, Rocketfish is Lian Li and their plate works fine. I have one in my Lian Li PC62 that came with my G70 case..
And the X5482's are 150w..
Can't compare E's and X's..
I really do have to try those chips though..
10.5 multi..times say 440?..:)
So here is my board,it's backend:D. Anyways my questions being- do I remove the plastic white strip and the existing metal brackets and insert the new backplate? Thus using the new backplate to attach the new heatsinks?
http://i30.photobucket.com/albums/c3.../random008.jpg
Thanks guys:cool:
Sorry, was on the phone.
Leave the board as it comes.
Leave the paper, it won't harm anything and these are low temp cpu's.. No fire hazzard.
I had one in a case with that paper there for months and no issues..
Now as to the Lian Li back plate two ways to go, easy or hard..
1) easy, put in behind board before putting board in case and just screw the heatsinks into it.
2) hard:
find and properly place that back plate to the motherboard tray and then mount with 4 tiny screws to motherboard tray using the two top and bottom offset holes..
I did this, takes time to properly set that piece.
Now way #1 is fine because the HS in question are light aluminum and when screwed to that backing plate distribute the weight so no issues.
Your choice on this.
Good luck Gongo,hopefully the 2gb and 1gb sticks I got will not be a problem- I grabbed the ones you suggested from the selller on eBay. I am sure they will be oK and I have not taken them out of there bags yet. I am sure the Kingstons you ordered will work; and I understand the shedding situation- I have an always shedding German shepherd!!!
This is the stuff i'm using in sammy.2 and sammy.3. Works like a champ. Not 100% sure what the original Sammy has in it.
KVR800D2D8P5/1G
Yes, people say DDR2-800 stuff isn't supposed to work (or work correctly), but it does and I've not had any problems.
Here you go...
http://www.needmoreboost.com/wes/sammy800.jpg
Micron 4GB (2 x 2GB) DDR2 REG ECC 1Rx4 PC2-3200R Memory
MICRON
2 x 2GB DIMMs (4GB Total)
DDR2-400
240 pins
Registered with ECC
1Rx4 PC2-3200R
Excellent Condition/Matched Pair/ Server / Workstation Memory
__________________________________________________ ___
Micron 2GB (2 x 1GB) DDR2 REG ECC 1Rx4 PC2-3200R Memory
MICRON
2 x 1GB DIMMs (2GB Total)
DDR2-400
240 pins
Registered with ECC
1Rx4 PC2-3200R
Excellent Condition/Matched Pair/Server / Workstation Memory
This is the memory I grabbed for my sosssaman's- got 8 of each
I figured it was ECC so it it would work- of course that train of thought might bite me in the face!!
Gongo I remember you said before that you had updated the bios- did you do that on top of what you did above. I plan on using linux and I am afraid to admit some of this will be uncharted territory for me :eek:
Does the Intel board work with only 1 cpu installed?
Most serverboards do , just asking to be sure.
This ram will work right? :D
http://cgi.ebay.com/ws/eBayISAPI.dll...m=250389037351
