It tooks me almost two weeks of trying but finally i've come to an accetable oc setting - at least for the summer, maybe in autumn when there's no longer 32°C room temp i'll try something higher.
But i've a question for you: i've got to a stable config at 345x10 wich leads me to a discrete 3.45 Ghz, first of all i've come to this setting keeping my ram at 1:1 and loosening its timings, then i've tried different memory clock and timings and the previous settings resulted completely wrong. I'll give you some numbers:
FSB Clock 1380
RAM 690 at 5-5-5-15 2T 1.9v
CPU Volt +0.2
NB Volt 1.325
CPU GTL 25
NB GTL 20
FSB term 30
wich were completely stable (+8 hr blend prime95 and many hours playing GRID and Assasin's Creed) but once i start ocing ram any sort of problems came out (freeze, rebot, no win boot...at least no BSOD!). So, after some days of tweaking and trying, i've come to:
FSB 1380
RAM 863 at 4-4-4-12 1t and 2.2v
CPU 0.2125v
NB 1.425v
CPU GTL 25
NB GTL 20
FSB Term 63
so the question is: why so much different settings? i've expected to have to rise CPU Vcore, and even the NB volt and FSB term, but never tought to have to raise them so much! Do you think it's normal?
BTW, this last settings lets me to run my RAM at 690 3-3-3-9 1t and 1104 5-5-5-15 2t, but found that keeping at 863 4-4-4-12 1t gives me a little advantage over the other settings.
I've always been told to search the max stable CPU oc and then the max RAM oc, and i've always succeded to get ram stable with little tweaking. But from this experience i'm starting to think that it's better and time saving searching both max CPU and RAM oc togheter.
How do you proceed?
