someone please :stick:
how to deal with over voltage error? :(
Use stock vcore or up..
Or disable the F1 thingy in the bios. Forgot what tab its under but its under a sub menu thats with the hardware monitoring.
Haven't tried disabling "F1 notice" but you can find the temp reading/warning in the HW monitoring section, as deathman20 said...I did this with other Asus mobos...just set to "Ignore", rather than provide a warning reading in ur BIOS. Your temps will still show using other monitoring s/w. IIRC, it will still show ur temps in the BIOS, too.Quote:
Originally Posted by Smartguy
OK, anyone have any idea why my BIOS picks up my LiteOn CDRW the first time, but then drops it after I "leave" the BIOS?
The CDRW has the jumper set to "master", and is on the master connector, & uses the mobo's (only) Pri IDE conn.
My single WD Raptor's on the SATA1 channel off the Intel ICH8R, set to IDE config, and all is well there.
IF I reset the BIOS via manually clearing, or install a new BIOS, I can see the CDRW in my BIOS boot order listing upon the initial new POST, but as soon as I leave the BIOS, & boot into windows, it disapppears for good. Very weird, & very irritating; Otherwise I really like this E6600/P5B-Dlx/G.Skill 6400HZ combo...a lot! :cool:
~ Strat ~
:pls ignore outdated sig:
a) which is the pci freq. then with clockgen ? Still 33.3Mhz ?Quote:
Originally Posted by Merc1212
b) where are these settings (2th pcie)on the bios ??
thanks
0711 was crap for me, made more problems than it fixed. did not fix boot bug or power off cmos clearing. Plus it made the exact same overclocks with older bios unstable. I reverted back to 0706 and it's perfect.
0711 is the best bios for me yet!! Very stable, i dont oc, but i do tweak the memory timings, and this is the best bios for that. If i tried to tweak timings before, it would always crash or no boot at all. But no such problems no more.. :)
Goooo 0711!!! :D
I did distabled "hold for F1 on error" but it still produces that stupid sound that bothers me most. I didn't found that thing in HW monitoring section :)Quote:
Originally Posted by Stratcat
please someone :stick:
I tried to increase my FSB to 400X9 but it ain't stable at all. I think i prob. need like 1.65 vcore to reach it and i'm on air so i don't think it's possible
356X9 = vcore 1.5 V
I think i need to lap my cpu (it's about 52C idle)
My chip = 6600 SL958 MALAY L626A175 (is this the :banana::banana::banana::banana:ty version - week 26. I heard that week 28 is the best for OCing)
Conroe e6600 L626A175
Asus P5B Deluxe Wifi (bios 0711)
G.Skill pc6400 2GBHZ (4-4-4-12)
XFX 7900GT
Antec NeoHe 500W
I have one like coolalers:D week 28 B
Try to boot at 9x401 so its on the other strap.Quote:
Originally Posted by hotchoc
Thought I'd respond to my own post, since I found the "problem":Quote:
Duh....
The sole PATA Conn (PRI IDE) hangs off the JMicron SATA/ATA controller!
So, as I usually do when overclocking, disable all "unused" on-board devices within the BIOS, I also disabled the JMicron controller, knocking out my PRI IDE conn, & thereby my CDRW. :rolleyes:
Oh well...
FWIW, in case anyone else has a similar "issue".
~ Strat ~
:sig update soon:
Mine simply refuses to post at anything above 399...I can run orthos all day and night at 399 X 9 with my 6600. I've tried lowering the multi and a myriad of other settings and combos above 400 and she just aint doin' it...Quote:
Originally Posted by loc.o
I haven't had this problem with the P5B, but in my other Asus mobo:Quote:
---> BIOS/Power/HW Monitor
Then, when the HW monitor eventually comes up (takes several secs), it will show an "out-of-spec" parameter by either changing color, or some other notice. Select that parameter using the "arrow" keys, like you usually do when manueveing thru the BIOS, then hit "enter", on the problem parameter.
There should either be a pop-up, or pull-down window, enabling an "ignore" option that is selectable thru the usual "arrow" keys, again hitting enter after selecting "ignore".
Best I can do for you, since I haven't had this issue with a P5B, as of yet.
HTH
~ Strat ~
:pls ignore out-of-date sig:
Tried it. Can't even boot into the windows logo. Keeps restartingQuote:
Am actually at 1.6 Vcore now at 380 FSB
I think my CPU and mobo is :banana::banana::banana::banana:ed !!! PPl would have obtained at least 415-420fsb given the vcore i'm using
It's a week 26 btw. You reckon it would make any diff it was week 28 ?
FWIW, I had to crank up my NB voltage a notch, around 400, to insure stability, in order to keep going to higher FSBsQuote:
This on BIOS 0711 (working fine for me).
~ Strat ~
:old sig:
I just flashed to 0711 and now my computer will not boot.
steps i took:
1. clock back to stock
2. Use asus update utility and bois downloaded from asus website
3. flash was successful and it asked me to restart.
4. after restart, when i would normally see my ide drive it just said, "Searching for ide devices" or something of the sort.
5. Turn off, reset cmos
6. Turn back on, fans power up... no post, only black screen.
7. Turn back off, Disconnect IDE drive, turn back on, fans power up... no post, only black screen
Try clearing cmos like asus suggests...shut down, remove battery, move jumper for 4-5 seconds, replace jumper, replace battery...fire it up...Quote:
Originally Posted by dr_sharp
Still nothing. :(Quote:
Originally Posted by correx
I set the PCI freq to 33.3Mhz in bios - I assumed everything was ok, but didn't check with clockgen.
I believe they are under the southbridge config (I'm not at that machine right now) - there is only 1 or 2 options in the menu.
Note that with the 0711 bios I no longer had to play with b), but I left a) as is.
I have a guestion about this P5B-DLX mobo:D
Does it run SLI, can you use 2 NVIDIA cards?
Thanks,
OPP
My infinity will...haven't had a chance to try the P5B cuz one of my cards went south. All you need is the hacked driver set...Quote:
Originally Posted by OPPAINTER
It can run SLI but with less performance increase than expected. The reasons for this are mainly that the 2 pci-e slots aren't both controlled by the NB. One is controlled by the sb and as u know nb/sb communication speed is limited. The second reason and with less impact is that the second slot is 4X.Quote:
In my opinion, if u want SLI on intel u'd better go with 975.
Sounds promising then.Quote:
Do you have a link to the driver?
Thanks,
OPP
So, the P5WDH DLX has 975 chipset, I have one of those here also.Quote:
Originally Posted by JoeBar
Should I use that board to run SLI instead?
OPP
