nice setup antho! :up:
Thanks. Took quite a while to modify everything but luckily everything turned out alright. :)
Only if it comes in black. J/K.
Exactly. I also had a few members on another forum request me to compare my case to my gigantic feet. As you can see.. well.. err.. I'm abnormal. :rofl:
But it takes quite a man to fill those socks. :ROTF:
Anyways. Thanks for the small support.
I just added my new Mushkin sticks and boy I'm loving them! 1.8V and I still get to keep my overclock. :up:
To xTKxhom3r , in fact the led's don't cost me that much around 80 $, me girlfriend bring them back directly to the Chinese manufacturer ;)
@antho: where'd you get the T-balancer?
@lyl: just occurred to me...do you also put heatshrinks on the other end of the 1/8" sleeves (the ones closest to the bigger sleeve)?
To emoners http://www.aquatuning.de/ ;)
antho thanks...found out that it's also available at Performance-PC
Well, I dont individually shrink all 24 on both sides. I just used 1" shrink over the whole thing. Shrink is tight enough, im not worried about it unraveling.
The first picture of course was incomplete (didnt have a black connector), but you can see the 1" shrink in the 2nd picture
that type of sleeving reminds me of the sentinels in the matrix haha and i think you would have to put tie straps to keep them all together wouldnt you?
http://images.imagup.com/03/1213996369_1.JPG
http://images.imagup.com/03/1213996415_1 (1).JPG
http://images.imagup.com/03/1213996476_1 (2).JPG
http://images.imagup.com/03/1213996511_1 (3).JPG
http://images.imagup.com/03/1213996532_1 (4).JPG
http://images.imagup.com/03/1213996555_1 (5).JPG
http://images.imagup.com/03/1213996580_1 (6).JPG
http://images.imagup.com/03/1213996600_1 (7).JPG
http://images.imagup.com/03/1213996616_1 (8).jpg
http://images.imagup.com/03/1213996631_1 (9).JPG
http://images.imagup.com/03/1213996649_zr (1).JPG
wow awesome build bro damn i love that case so much! how can you drop 300 for a case!!! i envy your deep pockets lol
Nice system!
You're water cooling an empty socket! Creative.
http://images.imagup.com/03/1213996616_1%20(8).jpg
Changed out the barbs for some of the Koolance compression ones and added in some San Aces. A few pictures...
http://dl.getdropbox.com/u/2028/Xtre...s/_MG_3203.jpg
http://dl.getdropbox.com/u/2028/Xtre...s/_MG_3282.jpg
http://dl.getdropbox.com/u/2028/Xtre...s/_MG_3226.jpg
http://dl.getdropbox.com/u/2028/Xtre...s/_MG_3283.jpg
Lol I can't see the cpu so it's probably empty. Nice pics and thanks for sharing.
it's probably a pic while he's leaktesting, especially as there are no l;ight lit up on the mobo at all ;)
Antec P180!
http://img.techpowerup.org/080620/case.jpg
http://img.techpowerup.org/080620/hddbay.jpg
Custom button to turn off CCFL.
http://img.techpowerup.org/080620/ccfl.jpg
http://img.techpowerup.org/080620/case2.jpg
Only thing left to do is better cable management.
Most people say the P180 isn't an easy case for watercooling, but this case is easy to casemod and to make it ready for watercooling. You just need to be a little creative.
Acrylic :). It certainly makes the back of the card more interesting.
Yes, but then i would have to make an extra hole in the case. I won't use the side panel, so this way was good enough for me.
I have a petter picture. Daylight and pc turned off.
The water is blue because i used Antifreeze.
http://img.techpowerup.org/080621/case3.jpg
