Ermmm... Raxxath... Where are the wires?!?
Great work. :)
Great work. :)
very nice!
haha thats so great, I don't believe it :up:
Do you actually have the wires plugged? If yes, great work
Nice lc Gregor :)
It's hard looking through 160+ pages of watercooling. It's fun and addicting but it takes time. I've finally gotten through most of it (I did skip some pages though) and I have to say I've seen some amazing cases that have inspired me to continue with my designs. Currently I've got a single loop cooling a 9850BE and two 3870's. EK Supreme and Swiftech MCW60's. Here are the photos of it finished (for the moment).
http://img174.imageshack.us/img174/9528/wc3lq7.jpg
http://img292.imageshack.us/img292/8347/wc4gs5.jpg
http://img174.imageshack.us/img174/5259/wc5if2.jpg
http://www.abload.de/img/lian-li-343-13wmb.jpg ... update of a system that does not exists anymore.
Beautiful stuff here! Keep em coming :)
Yo DRT-Maverick, I like how you mounted the upper MCW60. Still got this running on a 240?
Yeah, and surprisingly I still don't go above 40C under full load for the hot videocard. The temperature is higher however, just a couple degrees. But that's not bad at all. :)
My water cooling systems :D
1st DFI:D
http://mjhieuexpert.com/images/Picture%2060.jpg
2nd Abit P35 :D
http://mjhieuexpert.com/images/Picture%2052.jpg
Tanks and P500 Thermaltake Mod Pump!:D
http://mjhieuexpert.com/PUMModbyNhen...Picture 69.jpg
http://mjhieuexpert.com/images/P1000363.jpg:rofl:
Rad 240 danger den!
http://mjhieuexpert.com/PUMModbyNhen...ieu/Rad240.jpg
WTH is that pump mod you speak off. You may have just made the TT solution 100 times better lol.
Oh ok, so you just remove their pump and replace it with a better one. Thanks for the info. :)
It does look different from the normal mundane TT res pump thing I see all over youtube but I don't really know much about TT products :p
Mjhieu that is one nasty kink coming off that thermaltake image... 3rd image down in your post...
As im new to this forum, ill start with some pic's of my pc :)
This is the second rebuild of my TJ07. I'm doing leak tests right now and hopefully it will be finished tomorrow.
QX9650
EVGA 790i Ultra
EK Supreme
EK NB/SB 5 (SPP) & 6 (MCP)
EVGA 8800 GTX / EK FC8800
ViperJohn's mosfet heat sinks
PA120.3 (GFX)
MCR220 & BIPII (CPU & chipset)
EK X-Res 100 w/ EK Anti-Cyclon (modified)
Tygon B-44-4X 3/8 ID 5/8 OD
... and Martins elbows and tees!
http://img147.imageshack.us/img147/1847/1000417ow7.jpg
Got EK??
Raxxath, where did you get the side panel for your Lian Li PC-A70B, I really like the look of that, but not really into the look of the factory panel here
http://www.performance-pcs.com/catal...ducts_id=22439
I,m thinking about new case for watercooling setup, & I really like yours.
