i just got the chip today i plan on trying to burn it in at this speed here even if it crashes now and then as long as i can prime a few hours at a time i think i can make it run this speed. where do i get the new max t screen prg at?
thx perc,
thx perc,
http://www.thecoolest.zerobrains.com...topic.php?t=83
Download here.
my 144 is 63c ;)
mines a 67 i thought all these 0530APMW CABNE chips were the same? so i take it that the max case temp is diff even with same stepping and all that?
peace perc,
3000Mhz 1,36Vcore Prime Custom FFTS In Place 15min for over 5H 35min still running!!!Aircooled like in the Sig!!!!Ambient Temp was 15,5°C-17°C.(Roomtemp)
http://img441.imageshack.us/img441/8...om5h4ez.th.jpg
http://img433.imageshack.us/img433/4550/bild10mz.th.jpg
http://img433.imageshack.us/img433/2029/bild40ku.th.jpg
Dude....your ambient temps are down in the single digits :rolleyes:
Id have to agree on Vapor on this one, where are u rufus? It must be awfully cold there for your hardrives to be running so cool. I imagine you must have an air-con unit strapped into your case, or your benching in temps belowe 0, in a freezer maybe!!Quote:
Originally Posted by Vapor
Please tell us all your details, so others trying to stabalise their chips on air now the facts.
Ditto.
Lukü/Lukue = aircoolingQuote:
Originally Posted by dogsx2
Wakü/Wakue = watercooling ("tripple" stands for tripple radiator of course)
Kokü/Kokue = cooling with a compressor (eg. Mach/Prommie)
Thanks volvic, welcome to XS. :welcome:
Originally Posted by mongoled
the screenie he has above shows air temps where you seeing the single digits at? im looking but i dont see what you guys are talking about.
peace perc,
HDD temps
He must keep his harddisks in the fridge. :D
Guys just bought a Thermalright SI-120 with 120mm Panaflo L1a 69cfm @ 30dba, that's going to be good enough for these babies right? :)
Hey guys, how are you going to bruin your Opterons ? c'mon tell me your methods ;)
I guess what FCG does works....run P95, restart when it crashes over and over...it'll eventually go a lot longer between crashes.
I can get hold of an AMD Opteron 144 Tray ("Venus") S939
OSA144DAA5BN Stepping 0536 VPAW
Does that sound alright? :)
Originally Posted by Richdog
Where from?
Edit: I see now. How much is postage?
CABNE 0530 APMW 3ghz 1.4v
:stick:
CABGE 0536 VPAW 3ghz 1.9v
It s a big difference between 6weeks
+- same temp ...
SAME TEMP :eek: :eek: :eek: :eek: :eek: :eek:Quote:
Originally Posted by Pt1t
Wow that's a lot of difference in voltages...
Any other recommendations ? Like high/low vcore, high/low Mhz or high/low Temp ??Quote:
At it's max....it'll lower the voltage needed to run at that clockspeed and might even add a few MHz with extra volts.
I would like to disagree with this figure....I run my CABNE at 3.15GHz with 1.65V and am not getting terribly high temps (I'm on crappy water cooling with 22-23C ambient). Running the CABNE for a while at higher volts drops its temp A LOT, people just haven't done it yet apparently. On top of that, I've been running the Ricky Tweak (yes, on crappy water, too lazy to get rid of it frankly) which only adds more heat.Quote:
So have the OSA144DAA5BN Stepping 0536 VPAW not been doing too great then? Has no-one hit ~3gh with ~1.5v?
