AND HE SOLD IT!!!! Hope you got some good coin for it. Something that nice you hold on too.
@sc4mpie
what do u use in your water loop mixture? i like that color
Originally Posted by Liquid_Cooled
What is the PCI-E Power cable you are using. i need to buy it.
thats a abit ic7 max3. it uses an agp slot not a pci-E
Isnt there one PCI-Express power cable where you can hook up to two PCI-Express card?
No, It's an ordinary Molex connector. Just a special version of it, witch he propably made him self.Quote:
Originally Posted by Bail_w
i dont know but... what like mixing Zerex with Blue Dye-Lite ?? any performance dropping?? bad side, good side of it?
Dye's are a bad choice because they begin as a solid white powder, and over time, they will inevitably return to their solid state inside of your loop.
so any idea how to make my coolant glows in blue without damaging the loop?
Buy UV reactive tubing of your color choice. Primochill makes some nice uv tubing. Or, use a blue antifreeze like pentosin and illuminate it with cathodes.
Awesome setup man. Love the colors, and its clean as hell. Nice job.
too bad he sold it, looked so damn nice.
yea but, is that a single 1.120 rad....... is that the only thing keepin it cool? cause if so it must of been hot as hell.
Na, it's a heatercore. A single 120mm heatercore is about equal in performance to a Black Ice Pro 2.Quote:
Originally Posted by Gimmpy224
No dye. just uv tube. its just distilled water with zerex coolant added. to protect against corrosion.Quote:
Originally Posted by trance565
Been Busy.
I use the same setup w/ a x800xl in a PCV2000 (Though the fan is a bit bigger (150mm :eek: (only @ 5volts :hrhr: )
Originally Posted by thunderstruck!
Some mid-build reconstruction pics...
-pickles
http://www.binaryresults.com/wc/p160new1.jpg
http://www.binaryresults.com/wc/p160new2.jpg
http://www.binaryresults.com/wc/p160new3.jpg
Holy shat. Way over doing it don't you think?
Had leftover parts and waaaaay too much spare time heh.Quote:
Originally Posted by n00b 0f l337
-pickles
pickles, exactly, how much does your case weigh in tons?
omg.. first it was the overkill on the rad box. now you have another radiator strapped to the top!?!
one word: congrats:clap: :clap:
and keep up the overkilling :D
edit: o wait that was your p180 case. o well. keep up the good work
Dual radiators rocks! :toast:
http://www.techpowerup.com/gallery/23/1.jpg
Here is my watercooled Rig:
Sys:
AMD Opteron 148 @ 2.86GHz @ 1.4
DFI nF4 Ultra-D
2GB Samsung UCCC @ 260MHz @ 3-4-4-8-1T @ 2.5V
connect3D X850XT @ 590/640 (no Vmods)
WC parts:
Zern PQ+ (made in Austria) @ CPU
NexXxos NB-SLI1 @ NB
Heatkiller GPU Rev2.1 @ GPU
NexXxos Xtreme II w/ 2x SilenX 14db(A)
Alphacool Eheim-Station 600
<a href="http://img361.imageshack.us/my.php?image=dsc00011s6rz.jpg" target="_blank"><img src="http://img361.imageshack.us/img361/1791/dsc00011s6rz.th.jpg" border="0" /></a>
<a href="http://img361.imageshack.us/my.php?image=dsc00014s8qp.jpg" target="_blank"><img src="http://img361.imageshack.us/img361/1984/dsc00014s8qp.th.jpg" border="0" /></a>
A little bit less messier...
http://img46.imageshack.us/img46/478...2medium4pa.jpg
http://img136.imageshack.us/img136/5...1medium3wo.jpg
http://img139.imageshack.us/img139/5...9medium8ov.jpg
http://img101.imageshack.us/img101/6...6medium7ri.jpg
http://img146.imageshack.us/img146/5...3medium3jk.jpg
http://img143.imageshack.us/img143/1...5medium8ae.jpg
