i got it...ahci mode...sorry
can someone give me a direct link to the latest bios ket was referring to..im at work and i just dont have time to look for it...thank you
http://www.pctreiber.net/asrock-bios...57&sortby=date
Suit yourself.
Next 2 weeks my Extreme6 will be here, so i subcribe this thread to follow all news :D
!st Question: Do TRUE Black fits on this board? Im not sure for that pipes and cooling system of Extreme6.
thank you i found it on the asrock support/tech forum....anyone using a hyper 212 plus? i mounted my 9500 zalman and on the back of this board is that plate holding the cpu mount in and im not too comfortable with the way its on there so im looking for a good cooler that will do a good job as well as fit in my antec 900 case.
xtreme6 are others where bios 1.6 teases by oc
bios 1.6 is unstable at high overclock here
so i downloaded and extracted to a flash drive from here:
http://www.asrock.com/mb/download.asp?Model=P67 Extreme4&o=BIOS
hit f6 during boot up (double boot btw) and it just bypasses the screen and windows starts up...? please help
ok i got it to go into the flash utility screen (instant flash) but it doesnt recognize the flash drive
flashed bios now it starts to boot to the windows log and gets a quick blue screen and reboots itself...this after i just flashed to 1.6
sorry but couldn't find this anywhere
the debug led in the extreme 4 or 6 show the cpu temperature after post? or just stay AA?
thanks
Ughhhhh!!!!!! :slapass: Not good regarding the 1.61 & overclock stability!!
Comparing 1.6A to 1.6, how does overclock stability compare between those two?
Thanks for the insight! Sounds like 1.6A & be done! The saved profiles aren't that big of a deal. However, I have been able to force post by depressing the onboard reset button and the delete key at the same time. :up:
had to reinstall windows again! wow what a quirky board,been building computers for a long time always used asus and never a glitch...anyways i dont c 1.6a on the list of bios updates...anyone have a link to it?
hey sailindawg...funny emoicon u got there. btw i tried flashin back to 1.5 and when i enter instant flash it doesnt recognize the flash drive...when i looked at the files it had like 4 files in there unlike 1.6 which just had the bios file....weird.
not really havin an issue now..i got my overclock stable at 4.5 with 2 clicks of the mouse. im happy with that, may push more after i get my hyper 212+ installed. but after freaking out last night because my system blue screened right after i updated to 1.6 i was worried..why i had to reinstall win 7 64 bit i dont know. anyways it is running great so far and love the setup i have and i have this thread to thank for my choice of boards...i strayed from asus because if u look at the boards they offer ...this one is comparible to them all and has a better lay out as far as memory slots not being too close to the cpu so an aftermarket cooler would hit unless its low profile ram and the upper pci-e slot being blocked as well. i have noticed there are some straight up gurus here and am thankful for all the info :)
Z68 is coming.
You can download Z68 Extreme4 manual from:
ftp://174.142.97.10/manual/Z68%20Extreme4.pdf
The strange thing: lack of electrical SPDif Output (only optical) and no appropriate header on-board. Why not the other way?
Good things:
Virtu d-Mode is supported which means you can hook your lcd to discrete card and get Intel transcoding at the same time. It seams Asrock bought the right license version.
I agree. DVI-I to VGA (D-SUB) can be converted passively. DVI-I and DVI-D shares the same connector. Display port to HDMI can be converted passively. Two connectors (DVI-I and HDMI) should be sufficient without feature compromised (Intel graphic supports up to 2 screens simultaneously).
Instead we are losing precious space.
