XP is strong
did 178K with lower CPU and GPU clocks :)
http://img593.imageshack.us/img593/3038/178k03.jpg
XP is strong
as above lane if you flash the backup bios to f6x and use f7e i'd say , it very rarely tries to flash to backup then , these i would say are the best bioses and as dinos says if it reboots and you notice its gone back to the old bios switch off psu then when turned on it lets you back into the normal bios
alt f12 on bootup then it says flashing backup bios
Anyone know how I get 58x on this board? Max is 57x
yeah other boards have higher, ud7 has 57x :(
I uploaded a new bios for you on HWbot forum you asked at, it goes up to 59x
LINK
Thanks Dino! :up:
Bah
Ah nice :). Anyone able to boot at 57-58x though. I can't get mine stable at 56x, it boots and shows 5.6Ghz at the POST screen, but then it crashes a few seconds later :down:.
How is F8x going for everyone in terms of overclocking?
Guys
I have a GIGA X58A UD3R with RAID0 x Samsungs F3's 1TB, will the GIGA P67A UD7 regognize my raid0 on the intel ports ? i know the bug but well i will give a shot
thanks !
Sergio
i dont know cowie i am suspecting its XP related mate
will test on UD5 again
I've had my two f3 502hj's on my previous X58a-UD7.
And yes that wil work! But only on the Sata-300 port.
It cost me a full day to get my pre installed raid0 setup to boot.
I think its the first F3 Bios that gives trouble whit PCH 600 and Marvel.
I was getting; boot failure, missing HDD, Error, and a bunch of other BLa Bla's.
Because of the bug i dident try the 300 controller but after words that's the only one that works.
question, i had my set running previously on valueram 1333, because my 1866 i ordert was delayed.
And the thing is, that when overclock through turbo, say 45x100=4500 it clocks back to 1600mhz idle.
But when i set SPD on 18.66 wit the same turbo overclock it stays on 4500 and won't clock back to 1600mhz.
Is that because VID only works whit 1333 ?
Dinos have something like a 6th sense, someone ask about 57+ multi, and hop a bios.
@Glenboy: yop thanks dude, will give a try, hoping it's not related to the problem you and cowie have got .
Not yet. I flash with the new one using @bios, then reflash with Qflash at start up.
Great thanks, I'll flash and test tonight.
I have boot in windows without error with 51-52-53-54x ...
Still no crash in windows as i post right now with 5415mhz ... best bios for me so far.
http://img834.imageshack.us/img834/2930/5400.png
definitevely like this bios, have find a good sweet spot temp vcore at 5100mhz stable for 24/7 ... enough don't need more ( outside for benching )
