Originally Posted by
zerazax
ly in a layout like that?
I mean, reading into pixels? If so, then why is the 6850 touching the 5770 when its obvious by now the 6850 is faster?
Er, what? 5770's TOP is touching 6850's BOTTOM. What kind of comparison did you just make :D
And for that matter, why is the 5970 so much higher than the 5870 when the 5870 should be quite big compared to the 5770?
In the graph, the 5970-5870 difference is slightly larger than the 5870-5770 difference which is actually the case in certain res/AA settings, but not all.
Also, on the fliip side, look at the 6950... it's placed higher than the 5870 so if the 6970 is 17% faster than the 6950 (like 5870 is to 5850), and we say 6950 is even a conservative 10% faster than the 5870, the 6970 is going to be close to the 580 and probably be ~ the 5970 depending on the scenario.
According to the graph, the difference between 6950 and 5850 is about double that of 5850 and 5870. So, if 5850 is 100 performance points, 5870 is 117 and 6950 is 135, and 6970 is around 150 which makes slightly lower than GTX 580 and lower than HD5970.
It's pointless to argue this - the drivers already put Antilles as 2xCayman, so using Barts is a non-sequitur
Didn't know that. :up:
Furthermore, the 5970 was already theoretically crippled - it was 2 x Cypress XT cores clocked at Cypress PRO.
Not this much. Full Cypress was 180W. Full Cayman is probably between 230 and 250W.
AMD can take it a step further and make it 2 x Cayman PRO cores @ Cayman PRO clocks, with Cayman PRO supposed to be < 225W (my guess is in the 175-200W envelope) which would fit with a X2 configuration.
Would it? You think saving one PCB would save 50 to 100 watts? I don't think so.
That would actually leave room for AMD to keep the higher binned XT cores to reach higher clocks and thus make the 6970 stand out even further while the ones that couldnt reach such clocks get clocked lower / have units disabled and put in the PRO and X2 config
This doesn't make sense. "Ones not reaching such clocks" means "ones not reaching such clocks under a certain voltage". If you want to save power, which is definitely what you want to be doing in Antilles, you have to use the best binned cards possible, so that they will reach the same clocks using lower voltages, ending in lower power usage. Using lower binned GPUs would merely mean you having to use a higher voltage to reach the same clocks as the higher binned GPUs.
