Originally Posted by
AndrewZorn
i have some noob questions:
- can i use any [reference] brand bios on my Visiontek 5850? i have the Asus bios on there now, but what if I use MSI, in order to be able to use Afterburner (and will I be able to?)? i know the safe answer is just to modify the Asus bios i already have on it... since it already works and is already unlocked (unlike the Visiontek)... but if the MSI is the same as all the others but has Afterburner, mind as well...
- i do not have any 'selectable voltages' in RBE. do i just type in the voltage i want for the main/high/3D clock section ("Clock info 00") and leave everything else the way it is if i do not want to mess with 2D and such clocks?
- if i someday figure out my exact desired overclock, can i just put it in the Clock info 00 spot directly... and never have to even use catalyst control center? since it is in the BIOS, i wouldn't need to install CCC to see working powerplay and overclock?
