Well, sound spretty convenient for an online storage "device". And free? I'll check it out.
well went in to update my m1402 bios to 1406 and cant get ez flash to see the usb key drive... It only shows A,C and D options... Any ideas? The key is the same one i used to update from the stock bios on my p5q-deluxe to the 1402..I even retried formatting to see if that would work(fat--- not fat32)... Any ideas?
Why don't you put the .rom file in one of your hard disks?
I did... but still couldnt see it.... But i did the unthinkable-- used the asus update program--lol... and lived to tell about it... But i didn't download the rom from the internet.. I just loaded it from the rom on the computer.. it worked ok.. But sure hate doing it that way...
candyman--- try doing a 333fsb divider... I couldn't get much over what your getting till i went from 400 down to 333 and now i can get as high as 525 stable.. Though i do have a deluxe.. But worth a try.. Also try upping your Nb Volts.. I have mine @ 1.28 and that helped a bit.. FSb @400 is quad pumped-- so a 500 mem speed @ 400 divider is really a 2000 bus speed... But if you lower the divider to 333 it brings your bus speed back to close to what the system is rated for and allows you to raise your ram speed a bit more.. Im so tired I cant see straight-- so if that isnt what you were asking-- lol sorry about that.. Im off to bed.. :shocked:
isnt the 2000 showing "effective" fsb but actual is based on the fsb strap to nb? .. Hell--Dont listen to me-- i cant even keep my eyes open... I just know i was having a similar situation as you were and coming down to 333strap and upping my nb to 1.38 seemed to help me break through(though finally worked my nb down to 1.28 wth some playing)
what are you temps @ 4.4 and what stepping do you have? I have a credit @ frys and thinking about picking up one of the e8600s and seeing if i can lower my temps a bit(eo stepping seems to run a bit cooler -- or so they say lol) .. 4.4-4.5 would be nice.. 10x450--- could under volt my mem a bit and still have a pretty quick system..
right now i have almost the same system. Only problem i have right now is my co e8400 runs just a bit hotter then i like...
p5q-deluxe(1406)
g-skill pc8800
wd640aaks
This is what I managed last night before going to bed,
http://img264.imageshack.us/img264/3025/sohiep5.jpg
Production date of 8/13/08 I like it. Good old Microcenter. I settled at 469x9 4.23Ghz~though for temp reasons / memory strap reasons.
My EPROM programmer turned up today :D all I have to do is figure out why I keep getting an error saying it can't find the harware and I can get a system of sorts back up and running :toast: system running will be my stalwart AW9D-Max. Got a good board with that one, it can do 425FSB+. Not bad for a 975X chipset.:cool:
Glad to hear you are back online. :up:
Online yes, but still waiting on some stuff. Ordered a OCZ XTC memory cooler, 2 40mm fans and 2 80mm fans a few days ago, coming by FedEX........... still hasn't turned up. Takes the piss cos my EPROM Programmer had to come from China and it got here before FedEX could farking deliver me my package coming from the same country I bloody live! :mad:
FYI P5Q Pro owners BIOS1406 has gone official. I found it on the UK site.
You probably have a fsb wall on th chip. Test your wall by lowering your multiplier and cranking it up as far as you can get her and see where you hit the wall. I got mine to boot at 4.5GHZ last night with 1:1.
Give my 1406 mBIOS a shot when I do it, it should increase your FSB limits.
Try what he said and report back. Ket I didn't know you had modded this one. I will have to give it a whirl later as well.
Your "m" bios for the P5Q Dlx, can handle PL=7 with fsb>= 450 ?
Someone did test it ? 704m with PL=7 and FSB=450 ?
Because for me the high PL is the major problem of the P45 mobos. ;)
You BOTH should be thankful :p:, its been 3 days now since I sent my Pro back to the etailer and they haven't sent me an email or anything about if they have sent a replacement or whats going on yet :\
