I hope to achieve 4GHz on 24/7 use but right now i am somehow stuck at 3751MHz. Tried 3.8GHz, longest running stable on Orthos is 2hrs and system will reboot.
The followings are my Genie BIOS setting @3751MHz (Orthos 8hr stable):
Genie BIOS Setting
Exit Setup shutdown........................... - Mode 2
Shutdown after AC loss........................ - Enabled
AC Shutdown free.............................. - Enabled
O.C. Fail retry Counter....................... - 1
O.C. Fail CMOS Reload......................... - Disabled
CPU Clock Ratio............................... - 11X
CPU N/2 Ratio................................. - Disabled
Target CPU Clock.............................. - 3751 MHz
CPU Clock..................................... - 341 MHz
Boot Up Clock................................. - Auto
CPU Clock Amplitude........................... - 800mV
CPU Clock0 Skew............................... - 100ps
CPU Clock1 Skew............................... - 0ps
DRAM Speed.................................... - 333/667
Target DRAM Speed............................. - DDR2 682
PCIE Clock.................................... - 100 MHz
CPU Spread Spectrum........................... - Disabled
PCIE Spread Spectrum.......................... - Disabled
CPU Feature
Thermal Management Control.................... - Enabled
PPM (EIST)Mode................................ - Disabled
Limit CPUID MaxVal............................ - Disabled
C1E Function.................................. - Disabled
Execute Disable Bit........................... - Disabled
Core Multi-Processing......................... - Enabled
DRAM Timing
Enhance Data Transmitting..................... - Auto
Enhanced Addressing........................... -Auto
T2 Dispatch................................... - Auto
Flex Memory Mode.............................. - Auto
CAS Latency Time (tCL)........................ - 5
RAS# to CAS# Delay (tRCD)..................... - 5
RAS# Precharge (tRP).......................... - 5
Precharge Delay (tRAS)........................ - 15
All Precharge to ACT.......................... - Auto
REF to ACT Delay (tRFC)....................... Auto
Performance LVL (Read Delay).................. Auto
Write to PRE Delay (tWR)...................... - Auto
Rank Write to Read (tWTR)..................... - Auto
ACT to ACT Delay (tRRD)....................... -Auto
Read to Write Delay (tRDWR)................... - Auto
Ranks Write to Write (tWRWR).................. - Auto
Ranks Write to Read (tWRRD)................... -Auto
Read CAS# Precharge (tRTP).................... - Auto
All PRE to Refresh............................ - Auto
Clock Setting Fine Delay
DLL and RCOMP Settings........................ - Auto
CH1 DRAM Default Skew......................... - Model 5
CH2 DRAM Default Skew......................... - Model 5
RCOMP Setting................................. - Model 0
(Cant boot as 3 3 1)
Fine Delay Step Degree........................ - 70ps
Voltage Setting
CPU VID Special Add........................... - +162.5mV
DRAM Voltage Control.......................... - 2.123
SB Core/CPU PLL Voltage....................... - 1.55V
NB Core Voltage............................... - 1.3700
CPU VTT Voltage............................... - 1.40V
Vcore Droop Control........................... - Disabled
Clockgen Voltage Control...................... - 3.6V
CPU GTL 0/2 REF Volt.......................... - 0.67X
CPU GTL 1/3 REF Volt.......................... - 0.67X
North Bridge GTL REF Volt..................... - 0.67X
FSB Vref...................................... - Auto
Wonder if anyone can enlighten me to get higher clocks. Temps are nt a problem for now. Running the abv with load at 39C. Will post screenies if you guys want.
Mobo: DK P45-T2RS (bios 10/03/08)
CPU: C2D E7500 (R0 Rev.)
Memory:2x1GB Gskills F2-6400 GBHZ 4-4-4-12 2.1V
Thanks!
