Originally Posted by
Supacon
I'm a little frustrated because my P7N Diamond/Q6600 Setup is limiting me to a mere 3.1GHz overclock, when it seems that most people can get closer to 3.6 GHz.
I've got some decent Corsair XMS2 6400C4 RAM (2x1GB) rated for 2.1V, and am cooling with a Kingwin Revolution RVT-9225 (92mm Fan). I was formerly using a Freezer 7 and found that it was pretty comparable in performance, although it seemed that things were running a little hotter than they should have been.
I've got 4 120mm case fans installed, and although I used to run them at 7V to keep things quiet, I've ramped them up to 12v after installing a couple of very hot 8800GTS video cards.
Anyways, it seems like no matter what I do with voltages, I can't get much over 1680. That speed runs fine, OCCT runs for a long time no problem, but if I go to 1400, I can't even boot Vista. System posts fine even at 1600, however, but Vista won't completely boot.
I've just recently updated to the V1.10 BIOS available from MSI's Liveupdate, but it doesn't seem to make much difference, other than voltages are set differently.
I've tried the following settings, just to get a boot at 1400:
CPU FSB: 1400 MHz
Memory: 700 MHz
CPU V 0.1750 (or less, makes no difference)
DRAM V 2.1
NB V 1.45V (or less)
CPU GTL (67% FSB Term, at 8.879V or less)
FSB Term 1.313V or less
All the CPU options are disabled, and all the other general recommended settings are made.
I am a little frustrated that I can't even hit 1400 MHz. I'm wondering if perhaps there is something that I'm missing here, or something else that I could try.
I'm currently running very stable at 1380 Mhz (3.1 GHz) at much lower voltages than those above. I could probably run stock voltages (or close to) at this speed... it's almost like the board isn't actually changing them, but that's a bit of a jump to a conclusion as to why my overclocking performance is so lame.
Any ideas would be much appreciated!
