my Q6600@3960 mhz with actual vcore about 1.55-1.56....wPrime stable not Prime 95
i hear your frustration!!!!...the bios is pathetic when it comes to a 9650 or even a 9770!!...i had many problems but it was all with Vista...XP worked fine for me up to 4400 mhz...it appears that the 12/28 and 1st release has severe deficiencies with the 9650 and vista...ever since i put my Q6600 back in, it has worked NICELY with XP and Vista.
3,000 post's and haven't figured out multi-quote, rofl, just busting your nads :D
Ace, your setting for 3.96, you are unable to prime95 stable it, do you believe this a CPU wall for you, or the board? As my goal is ~4GHZ stable, crunching stable.
Ace already did http://www.xtremesystems.org/forums/...&postcount=432
Ace-a-Rue what os are you using to get the 4.4ghz in your sig?
thanks for the link!:up:
i did soften up some of the memory settings when i tried vista 64 bit install at 3963Mhz to make sure vista didn't have any problem making it through the install.
i'll try to update some time today...my poor dog had major surgery 2 weeks ago and he is still dripping blood from his new pee site....going to have to buy a crate/cage to minimize the dripping on the bedroom carpet (we used towels and blankets before)...thought it would go away or diminish by now but it has not..sigh
sorry for the outdated sig...i sent back my 9650 for an exchange...it had a defective DTS on one and possibly two cores...Intel would not give me an RMA for that reason...i read intel's warranty and it does not state any exceptions....i was lucky to do the exchange since i was 29 out of 30 days into my drop-dead return policy with clubit.com
installed both XP SP2 and Vista 64 (dual boot) on the Intel Raid controller (128K).
ace-a-rue, what are your pwm temps when loading your 4 cores @ ~1.5V on your cpu?
Sorry bout your doggy, ileostomy? Nice thing about dog's and kids, they heal quick and adjust to things like that just as fast.
not sure which is PWM..is that the "SYSTEM" temp?
not that but something similar...they did a cystotomy and scrotal urethrostomy....huge stones removal in the urethra (behind the penis) and they made a new pee site....he has a genetic disease called cushing's disease which is the cause for the stones...this is his 2nd surgery to remove stones...this time it was far worse....he is 12 years old...i couldn't put him down...he is like our child...spent $4k for the surgery and doctor bills.Quote:
pwm temps should be found in the temp sensor section of the bios, I assumed with everest or some other windows based sensor you should be able to pull these temps as well.
I have yet install the board yet, awaiting my graphics cards, 2 days to go. Busy working on a few modifications to the board. I have a horizontal mounting mobo tray in my MM horizon, so the pwm heatsink was easy, drilled and tapped the screw holes, so they are now attached providing stability. Will be adding an enzo tech all copper NB block with an 80mm fan, also will have an 80mm on the pwm heatsink. I found digital pwm's the hardest part of heat to dissapate when I had an IN9 32X max board, so assume the problem exists on this board as well at higher voltages.
http://byfiles.storage.live.com/y1pD...Zp1IboCGbUeB1U
http://byfiles.storage.live.com/y1pD...ewuF9rAIPrLoz4
http://byfiles.storage.live.com/y1pD...eCVd922t-wrodQ
http://byfiles.storage.live.com/y1pD...45JqcgW5dlY8qo
I understand about your puppy, my chow chow has just hit 6, and I dread the day even now when she ages to the point of needing to be put down.
i did a wPrime 1024M bench and the "SYSTEM" temp went up to 55C so i assume that is the PWM temp...i have a small 40mm fan on it and the case door is open for the time being....i presume with the case door closed that it would be in the low 60C range.
CPU VID CONTROL = 1.5375
VID SPECIAL ADD = AUTO
DRAM VOLT CONTROL = 2.150 OR 2.10
SB CORE/CPU PLL = 1.89
NB CORE VOLTAGE - 1.703
CPU VTT VOLTAGE = 1.514
GTL REF VOLTAGE:
CPU GTL 1/3 REF VOLT = 116
CPU GTL 0/2 REF VOLT = 116
NORTHBRIDGE GTL REF VOLT = 120
these are not hard locked settings...i need to still explore downward except for the Vcore...the vcore is my lowest that can hold 3963 mhz and also perform wPrime 1024M bench.
i am not sure, should look like this, not my pic, taken from the everest forum on a lanparty P35, PWM is clearly noted.
http://img.photobucket.com/albums/v3...nuff66/ev4.jpg
http://img.photobucket.com/albums/v3...isc011_8x6.jpg
here's mine that i used off the DFI disc...there might be a more current one; i'll have to check.
the cpu has a +13C add
System temp is PWM temperature. Don't know about the accuracy though. The Volterra controller is under strict NDA. I do know it has the capability of monitoring and reporting the temperature of each phase. Since we are seeing a single temperature I'm not sure if that is an average of all the phases or the reported temperature of a single phase.
anyway you look at it, there is a shortfall in reporting.
when will they start selling this thing at newegg.com?
It would be so nice to like have this and like a c2d e8400 or a q9450 paired with like 4 gigs and an ati 3870
what do you guys think?
the more i look at the thread and i see someone saying the board has crap penryn support or the volts don't read correctly the more i wish i didnt buy it :(
i doubt it, im 100% sure dfi will release a bios to fix this all...
lets be straight forward to each other... if not this DFI, which other motherboard guys?
dfi is the best mobo manufacturer out there...
