Well I am going to have found a first big configuration of this mobo, recommended for 24/7, this for the summer that itself hot stupid pair appears.
http://img127.imageshack.us/img127/8...tp5kra0.th.jpg
Settings bios:
JumperFree Configuration Settings
AI Overclocking: Manual
CPU Ratio Control: Manual
- Ratio CMOS Setting: 8
FSB Frequency: 440
PCI-E Frequency: 100
DRAM Frequency: DDR2 1100
DRAM Command Rate: 2T
DRAM Timing Control: Manual
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 4
RAS# Activate to Precharge: 9
TWR: 2
TRFC: 25
TWTR: 2
TRRD: 2
TRTP: 8
DRAM Static Read Control: AUTO
Transaction Booster: AUTO
Clock Over-Charging Mode: AUTO
CPU Spread Spectrum: Disabled
CPU Voltage: 1.4125v
CPU Voltage Reference: AUTO
CPU Voltage Damper: Enabled
CPU PLL Voltage: 1.50
DRAM Voltage: 2.10
FSB Termination Voltage: 1.30
North Bridge Voltage: 1.40
North Bridge Voltage Reference: AUTO
South Bridge Voltage: 1.05
Advance CPU Settings
- Ratio CMOS Setting: 9
C1E Suppport: Enabled
Max CPUID Value Limit: Disabaled
Vanderpool Technology: Disabaled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
PECI: Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support: Disabled
