Haha, thanks:)
Got 2 new WR's today, X2 4800+ Toledo and 3500+ San Diego:D
I also tried both 0507CPMW's, and, lucky you Gianni, both had horrible coldbugs. Never seen ANYTHING like that on a BH! ~320mhz @ ~-28c. I also tried the AABHE 0506GPMW again, I made it run @ 10mhz more, but then reboot. That was @ at least -28c (temp sensor is a bit weird when it's colder) and 1.8v. With 1.89v, I didn't get over 3.8g. But then the temps were like -15, so if I can get -30c and 1.9v, then MAYBE...
The 170 was very bugged, so it was damn hard to try it under dice. But it was fun anyway, as it went always 50c++ up from idle to load:D And 15c core temp difference... I'll probably remove the IHS so I can get more even and stable temps on chilled water.
I also tested one of the 185's. It sucked pretty hard for a 0613, highest suicide was ~3600 @ 1.8v!
THe 0613XPMW's were quite good for a 3700+ toledo, 3100 prime stable @ 1.376v @ air. Didn't try it on dice, though. Also, the 0606APMW was crap.
I'll post the cpuz stuff of the 3500+SD and the X2 4800+ Toledo soon;)
