how did you get the 11x multi?
That's what I was thinking, please tell..Quote:
Originally Posted by ncc-1709
Ahhh, so you're the one with the WR and the 11x multiplier. I went to check what I had to beat to get the WR on this thing, and saw 11xblah, and was like "No fair!". :p: Please, do tell.
He just had luck and got a CPU with 11x multiplier opened.
hit the nail on the head...i have a 0546xpmw under water @2.8ghz 1.4725 voltage set in my bios. a8n32-sli m/bQuote:
Originally Posted by alpha0ne
it can do 2950mhz but takes upwards of 1.56+ volts to get there.
anyone got any data on the CCBWE 0609 FPAWs? i cleared out my CCB1Es of the same stepping, but have these 3 left. evidently the same shipment that my parts came from are sitting in AZ...garrrrr...must resist buying more!
PM would be appreciated.
dave
dave I've looked at your web but seems like its outdated. Also the pricing list is no more on the server (that's what it says, 404). Have you moved it or something? Thanks!
lolQuote:
Originally Posted by mursaat
yeah...sorry, trying to move pricing over to the new store front, etc. if you hit the forums you can always get pricing.
sorry!
dave
Hi Dave:D
Any signs of more of those CCB1E coming in?
guys, in deference to the rules and regulations of this forum (and my desire to not get banned) please shoot me a PM.
dave
Noob warning!
Hey guys, I have problems getting my 165 0551WMPW to any decent speeds.
Above 230HTT and system wont load XP. I tried with up to 1.45 vcore.
HTx3, ram 266. Decent Antec Neo Power 430W PSU. ASUS A8N-E mobo with the latest bios.
People seem to be getting atleast 2.5 with 1.4vcore with this stepping :/
Also Cpuz and other apps always display the CPU as running at stock, even tho it is overclocked in the bios :confused:
http://www.sourcekills.com/albums/ts...de/priming.png
Someone called me out on my chip, so I made a screen of where it's at so far, as of this morning. It's nothing really good, but it's something to prove where I'm workin' at isn't total BS. ;) Of course ambient went up 10F today, from 65F to 75F. :( I just can't get a spree of good luck.
That's not true. Two I've tested won't do 2.5 GHz without 1.5V. On air, you'll be lucky to get 2.65-2.7 and 2.7-2.75 on water, 2.8 tops. I wish I had waited and gotten a new 0608. Why does AMD have to release some :banana::banana::banana::banana: stepping in between 2 good ones.Quote:
Originally Posted by Lord KneeGrow
Got bored. Suicide run with 1.5v, I'm 100% positive heat is the limiting factor now.
http://valid.x86-secret.com/show_oc?id=82765
No 11x for the first 6 weeks I owned the chip (I checked).Quote:
Originally Posted by neoman
I was thinking recently, and just before I put it under phase for the first time (with no IHS by the way) I covered the SMD resistors and the exposed contacts on the package with nail polish, just standard clear nail polish.
Put it under phase, as a larf I checked and wow 11x multiplier.
Dinos22 also put nail polish on his SMD's, before ever putting his chip under phase, and got 11x I believe.
so you can unlock 11X on what chip?]
Think it would work on a 170?
i doubt that had anything to do with our chips going nutsQuote:
Originally Posted by Nephilim
i'd say it had something to do with phase maybe or RAM used.......
i have a kit of OCZ RAM which will force the chip back to 10xmulti and after cmos clear i get the multi back with a different stick of RAM.....something odd....but my 11xmulti is here to stay for sure :)
nice lapping btw.....mine is not even close to that but it's flat enough hehehehe and damn i had blisters for a few weeks after I was done lapping the IHS on its own heheheheh :slapass:
So I have to ask, what color did you guys use on your Opterons? Did it match it's outfit well? :ROTF:
I am getting ready to mount my new Thermalright XP-90C heatsink, but am planning on lapping the two mating surfaces first. I have never done this before, but think I understand the basic concepts. I plan to do the following:
1) purchase wet/dry sand paper in grit ranges from about 600-2000
2) mount the sandpaper on a flat surface
3) progressively work up through the ranges of grit to eventually achieve a mirrorlike finish
4)finish off with some sort of metal polish (I have both Brasso and Autosol paste)
The lapping process will be done by applying light pressure to CPU and heatsink assemblies, doing no more than three strokes at a time in any one direction, and varying direction so as to sand in all 8 points on a compass.
After the final polishing is done, I will clean both mating surfaces using the new two part Artic Silver cleaning solution.
I will apply a super thin layer of Artic Silver Ceramic thermal compound between the mating surfaces to enhance heat transfer.
I have a 20" x 48" x 1" thick piece of plexiglass I was planning to use as a mount for the sandpaper. It is apparently flat (smooth to the touch with no surface abrasions), and has enough room so I can mount all the necessary sandpaper in a row.
My questions are these:
1) Is my plexiglass a suitable surface to work on, or should I get an actual piece of plate glass? Would glass be a flatter/ better surface?
2) Is it safe to lap the IHS while it is still on the processor, or do I need to remove it and then remount it later? I will be using the black foam piece that came with the processor to protect the pins.
3) Is the process as I outlined it essentially correct, or should something be modified?
pink of course :p:Quote:
Originally Posted by tsuehpsyde
pics please. i just tried with some pink stuff to hand, but it dident work.Quote:
and a pic on the nail varnish maby. please. it could be the cure to my cpu problems(other than having to make a new chiller)
Posted this over in the opteron thread... meant to put it in the dual opteron thread....
I just got my new CPU and want to start overclocking.
some specs...
Asus a8v deluxe
2gb corsair TWINX2048-3200 3-3-3-8
Antec 480W True Power
Thermaltake Tsunami Dream Case
some stock non overlclocked settings
2:1 DDR 400
bank interleaving AUTO
Burst Length 4 beats
CAS 3
TRAS 8
TRP 3
TRCD 3
TRRD 2T
TRC 11T
TRFC 14T
TRWT AUTO
TWCL AUTO
TWR 3
aysnclat AUTO
read preamble setting 5.5ns
2t command DISABLE
CPU FSB 200mhz
CPU mult 10x
CPU voltage 1.350v
agp/PCI 66.66/33.33
vdimm 2.8v
Seems that the ram and cpu combo are a little sensitive. Any suggestions on how to relax the RAM timming so I can get a decent overclock and still get past system post.
All your timings look about right, I think it is more the motherboard holding you back than the RAM and CPU combo. One thing to try for now though is set a bigger mem divider, until you can afford a better mb
U might wanna look into another PSU.Quote:
I agree on the mobo and the psu, whats your amperage on the 12V line?
Just to let you guys know, I've got a significant quantity of Opty 170 CCB1E and CCBWE 0609FPAW's up for grabs. Let me know if anyone is interested... soon. I'll be placing an order mid-day (pst) on the 30th.
I'd post this in the for sale section but i've got no access. So i figured you guys would be the ones interested in this. PM me if you're interested
w00t just recieved my Opty 170 today from the egg. It's an CBBWE 0550 UPMW. I've heard good things about the 0550's can anyone give me a rough estimate of what my OC'ing potential might be? I'm using the stock heatsink right now, but with AS5 applied.
This PSU is rated at 3x 12v@16A.Quote:
Originally Posted by situman
Although looking in bios 12v is about 11.65@stock. Doesnt seem to drop when I change HTT.
I will get rid of this PSU and get a seasonic or enermax.
Aim for 2.6 at stock and maybe 2.8 with a bit vcore bump. Don't go crazy with bolts as that will surely end in a worse OC. With a lot of luck, 2.9 with 1.475v (guesstimate, I've not done my homework by calculating the thread median :) ).
With the stock cooler, I would try to get the most at stock or up to 1.375v but always try to stay behind 45c. If you get a BigTyphoon, then you can add more juice
LOL
I think i got a dud
UPMW's are hit or miss as there saying
some go 3g
some barely do 2.6
mines doing 2.9 with 1.41 right now
but cant get anything prime stable above 2650 with this volts
and heatoutput is too much to gi hiugher onthe volts..
If I had to getss Id say pray for 2.8ish
thats about their margin some 2.9 rare above 3g
Hi.
How is the CCB1E 0609EPAW compared to the CCB1E 0609FPAW ?
They got the "E-version" in my local shop at the moment, should I get one?
I got 2 duds in a row. I've been burning the current one in for about a week with zero gain. It has actually lost stability. If the review for Conroe is good I'll probably sell this now while it's still worth something and wait it out. From a price chart I saw, a 1.86 GHz Conroe will cost about $200. I must have read something wrong.Quote:
Originally Posted by Philosophy
I admit it is difficult to get up much past 2650 MHz stable with this version of the 0550 UPMW processor. I have been stuck for a while at 2650 MHz, but tried using VID and Special VID in combination on my motherboard to go "between" the regular .025 V steps. As a result, I gained 40 MHz of dual Prime 95 Stability (now 2690 MHz). I am trying a new heat sink and different thermal paste on Friday, and will definitely post the results. I am trying to get up to 2800 MHz dual Prime 95 stable on air. If it can do that, I will invest in a serious water cooling system for it.Quote:
Anyone noticed that dual-cores draw more power when stressing them with large fft's or custom (large fft's in place/15min). My system is small fft stable at 1.46V, but when also testing mem. controler & ram it needs bump to 1.52V.
I finished testing my system for stability (i get stucked with ram timings for almost 3 weeks, till i stabilize my system :stick: ). Overall, i pleased to have such an awasome chip -
3gig was my goal from the beginig and thats all i need :toast:
Small fft's
http://img301.imageshack.us/img301/2...z12h8ue.th.jpg
Custom fft's
http://img20.imageshack.us/img20/727...rime8qt.th.jpg
PFFFFFFFFT! You greedy peasants ;)
My aim was to reach 2.6. I will be very happy then as it would mean a FX60 chip for a 3rd of the price.
My CPU wont clock for :banana::banana::banana::banana:!:(
Does someone know why CPUz and other similar apps always report the CPU running at stock regardless of what I have set it to in bios?
well, that is quite hard to guesstimate...but if we are comparing the CCB1E 0550VPMW with the CCB1E 0550UPMW the former do perform better.Quote:
Originally Posted by Nightprowler_77
Also the CABYE 0540FPAW has done very good.
Those last letters also indicates on wich weekday they has been manufactured, that could be a factor as well.
This is ofcourse by gut feelings and such...but I would pick the CCB1E 0609FPAW...
The 12v might hold you back a TINY bit, but nowhere as much as the A8N-E... abysmal bioses on all the A8N series, I've tried em all... no inverse dividers (233 & 250 mem on 200FSB) without screwing with other clocks.Quote:
Not an ASUS fan, and personally would consider anything above stock on the A8N series a blessing :)
Which temp is the CPU temp no_nick? Also, what kind of custom settings are you using in p95 that required .12 more volts?
I've never had problems with CPUZ. It refreshes the speed real-time. Now if we talk about MBM that's another story, I can show you a screenshot of my 165@4078mhz with a Big Typhoon :banana:Quote:
Temp1 is cpu, temp2 is MB ..Quote:
Originally Posted by thunderstruck!
Custom settings;
min FFT size: 8
max FFT size 4096
FFT in place, every 15min
875MB ram per instance (i have 2×1GB sticks)
How is 3D mark stability Nick?
What is your LDT and Chipset voltage?
Its prime95, memtest, 3d stable system, yesterday we had lan party and the system was running like 13h games without a problem.Quote:
Originally Posted by rapty
LTD and chipset voltage is @ default (no overvolting enabled).
0550VPMW, Batch# 678L5001
Anyone seen this before?
Guess I will be selling the mobo :) Aside from DFI Nf4 ultra, what board do you recommend to let me reach atleast FX60 speeds?Quote:
The A8N-E's aren't really quality motherboards from what I've been told, therefore I'd be questioning that first. ;)Quote:
I am suspecting this. However, I have seen several posts by users on other forums who use A8N-SLI premuim hitting 300HTT no probs.Quote:
Originally Posted by LiQU!D
Im gonna refitt the cooler and add some AS5 and see if it makes a difference.
The A8N-E cannot handle an Opty. It will handle a x2 cpu fine, but Opties just draw too much power for it to handle.
Anyone wanna buy my 0550UPMW to support my ever growing addiciton to CPU buying and testing? ;)
Im lookin at a CCB1E 0609 from dave :p:
A8NSLI-premium/Deluxe?Quote:
What do you recommend :)
For me they both run my two 165 optis @2700mhz on air.
I would get the sli 32 because of better memory compatibility.
Jolly jumper, what voltages do yours do 2.7GHz at?
1,45 on both cpus.
If you are going SLI, I recommend the A8N32. If you dont ever plan on running two vidcards, get the Sapphire Grouper board (the white one).Quote:
That serial number is missing one digit after 5. If it's 50001, then it's batch # 1 and I can only imagine what that would do:) You should've got one when they were cheap and plentiful!Quote:
Originally Posted by CompGeek
anyone got a comparison of a CCBWE 0609 FPAW and the CCB1E of the same week stepping?
dave
CCB1E 0550 VPMW realy good stepping.. default vcore > 2.75-2.8ghz ;)Quote:
Originally Posted by dave_graham
I havn't seen any CCB1E's in the 0609 flavor, only 0608.Quote:
i had 4 of them. trust me, they exist. I've also got CCBWE 0609 FPAWs that i'm trying to see if anyone has them and if so, if they've been overclocked.Quote:
dave
Well send me a review sample, I'll let ya know how it compares. :p:Quote:
Just grabbed a new 170 from monarch, turns out the MP-05 doesn't work with naked CPU's on DFI boards :/ (socket gets in the way)
Shoot me a PM if you want mine
Originally Posted by Repoman
looks like it will work fine on a naked chip.....
http://www.systemcooling.com/cooltec...xtreme-01.html
http://www.systemcooling.com/images/...me/image11.jpg
similar to storm block....
besides if it does not work get a storm block....:toast: :woot:
Yeah it was my fault, my tubing actually puts upward pressure on the CPU block, I put 6 layers of electrical tape on the part of the socket that sticks out and it's OK now. I will still be selling this one though, hopefully the 170 I get from Monarch is good..
And it still hits 35-37C load at 1.4v, what are you other 0550vpmw watercoolers getting? (or air cooled for that matter)
I am @ 1.525V in bios 300x10 idle 28-30C load 37-39C
The Enermax Liberty 620 W PSU failed in my system again. This time it also ruined my DFI Expert Motherboard and both hard drives. Fortunately, dealer is covering everything under warranty.
Because the dealer is out of stock on DFI right now, I have decided to try the new MSI K8N Diamond+ motherboard. This will be backed by an OCZ 600W Powerstrem PSU, as I will never buy anything from Enermax again:mad:
My Maxtor Diamond Max 10 250 GB hard drives will be replaced with new Seagate 7200.9 300 MB units with 16 MB of cache each.
Stay tuned over the next week as I put the new setup through its paces.
Originally Posted by kberguy1
sorry to hear man...but glad you will be back on feet soon!:toast:
Very glad to hear kberguy1 that your murdered h/ware is being replaced :clap:
If I owned an Enermax Liberty 620 W PSU I would be a very worried man ATM :stick:
there must be some ways to unlock the multiplier :slobber: :slobber: :slobber:
I'm really needing a chip that does 3.0 on air. I would like to trade my current 0551 CCBWE UMPW 170 + cash if possible. Does 2.7 dual prime stable with 1.5V in bios.
:eek: I'm using a Liberty 620 too... What happened?:confused:Quote:
Yeah me too, I really dont want to put the Hiper-r back in but if enermax are killing components then I will. Tell us more plz.
Need a little advice.
I ruined my last opty (165 spmw) by popping the lid. I am now fed up with the temps my 170 0550 UPMW is pumping out (load = 53c @ 1.45 - 280x10) which is stopping me from going any higher. I know these chips run hot but as anyone had any decent temp drops with the UPMW's by going naked on air? If I can get temps back down enough for a few more volts this chip may go to 2.9..even 3 gig. If all removing the IHS is gonna do is lower temps then I wont risk it again but if I can get past 2.9 then would do it.
Opinions plz
Explain please :slobber:Quote:
Originally Posted by kenofstephen
Specs in my sig. Temp drops around 4-5c both idle and load, with same voltage+speed. Really helped, as those UPMW seem to like ~45c. you could try to lower the voltage to 1.425 or even 1.4 to see if you can reach 280x10 too. If that's possible, the voltage drop and IHS removal would end in: 45c @ 1.4 - 280x10. By what you're saying I think 2.9 will be really hard. The most I've read is 6c drop. I'm not saying it's impossible. Good luck!Quote:
Originally Posted by Ic3man
BTW navigate the thread and buy the "official XS IHS removing tool" :D I used that and absolutely NO problems ;)
Quoted to show him "the tool". :p: Sadly there are no Sherwin Willams or Ace's anywhere near here, so I can't get that tool. :( I'm gonna look for it, though.Quote:
there are very, very few dual cores that are doing 3.0 on regular air. the heat load these things put off makes it almost impossible to do. If you have a very cold room, open case, lots of fans, and a very good cpu cooler, you might get there if you have a super golden sample cpu. 1 out of 20,000 or something.
Not saying it can't happen, but 2.9 on air or 3.0 on good water is probably alot more reachable if you get a very good chip!
Originally Posted by fullup3
Thanks for the heads up! :) I do have a good watercooling setup, so I guess I should say I'm looking for a chip that does 2.9 on air or 3.0 under water :D
Nice to feel special, beeing 1 out of 20,000 and all...:DQuote:
So after seeing the ASUS A8V deluxe was a POS I stuck the Opteron 170 into my other computer
it has
MSI NEO2 Plat MB
1gb Corsair 3200 XL 2-2-2-5 memory
antec NEO power 480
I was able to find my
Max HTT 370
Max CPU 2.75
Max Memory 290
so I ended up setting it up as follows
CPU Voltage 1.4v
3HT x 275 HTT = 825
1:1, 200, DDR400 = 275 (DDR550)
multimpler 10x x 275 HTT = 2750 mhz
Works fine. I would like to mention that the temeratures at stock values were 34 idle and 46 load (3.75v)
While overclocked they sored from 36 idle to 55 load.
Would this be causing my MAX cpu barier?
http://www.dintek.on.ca/opty/opty_275.JPG
Got sick of temps, I had to do it.
http://www.sourcekills.com/albums/ts...0889.sized.jpg
Load went down like ~5C, at least with high ambient (75F). Was loading around 40C, and it's sitting @ 36C (dual folding, not prime, havn't set prime yet). I'll post more results when I have the time, gotta leave shortly, just thought I'd update.
Originally Posted by Proendo
i wouldnt guarantee that your mob reads the temps that well, but if that result is on air then you might be reaching your limit on air, and need to go to water.
Whats the batch code?
the shaving razors work alot better and cut through the silicone like a hot knife in butter. Plus they're thinner.Quote:
I took the ihs off mine (first time ive done it) and it took literaly 2min to do.
Removing the IHS always takes way longer for me. I never understood how people got it in like, 2 mins. I always take a good half hour to get it done. :slapass: Maybe I'm just slow/over cautious, but whenever I cut thru all 4 sides, it never wants to come off...so I have to go around, checking all the sides, then pulling on the top, etc. When it finally came off and I saw how close the SMD's on the one side were to the glue I was like DAYUM! :eek: She's safe and sound now though, and I'm trying for 2.8GHz on stock voltage. I'll leave it go when I leave in the next 20 mins or so.Quote:
Originally Posted by Delirious
If mine clocked as nicely as yours i would have taken longer i think. :D
Its mostly cause those shaving blades cut through the silicone so effortlessly its easy to be careful and still get it done quick.
Came home, still priming. I'll consider it "golden" if it keeps going. :cool:
http://www.sourcekills.com/albums/tsuehpsyde/2800_G.png
OH for shizzle...
lookee lookee
"You Won eBay Item: New AMD Opteron 170 CPU CCB1E 0550VPMW Retail Box"
sitting in my inbox. heh.. my wife is going to kill me.. it was 7hundy.. but worth it. :)
more info from the ebay selling portal
"This is my very last one of this stepping. I have no way to get any more after this, so that's why the price is so high.
This auction is for 1 Opteron 170 2.0Ghz Socket 939 processor with two cores, each with 1MB cache. The Opteron 170 is 64/32-Bit compatable, Socket 939 w/Hypertransport technology. This Retail box processor is new in box and comes with copper pipe heatsink/fan. 3 year warranty.
There are a few green flakes loose in the case, which is common in these CPUs because of the heavy heatsink/fan unit chipping away at the foam that houses the fan and CPU on the inside of the box. The CPU itself is enclosed in plastic and is not affected by loose foam pieces. This box has never been opened, even though the seal has been broken on the box.
Worldwide shipping available! Prices below. Insurance free on orders outside of the US!
Stepping is CCB1E 0550VPMW
Batch is 0362
I sold a CCB1E 0550VPMW Batch 0290 a few weeks ago and here are the record-setting results. Note that the performance screenshots are NOT from this CPU, but one that is from the same stepping. This CPU is new and unopened shown in the last three pictures.
Setup for the performance screenshots (3473.7 Mhz!!):
CPU: Opteron 170 CCB1E 0550VPMW batch 0290
Motherboard: DFI NF4 Ultra-D (704-2BTA bios version)
Custom Watercooling: MCP600 pump, Danger Den TDX block, 120.2 heatercore.IHS on the chip has NOT been removed, and the ambient temperatures were very normal (67f).
RAM: 2gb kit of DDR500"
yadda yadda.. whew.. finally!!
if it's a dud I will :banana::banana::banana::banana: twice and die!! lol ;o
You payed $700 for that :stick: monarch is shipping (hopefully) CCB1E 0609 for $400 second day
Anyway nice tsuehpsyde, told you guys it would be golden :slapass:
Yeah, $700 is entirely too steep considering how well the new steppings are doing. Oh, and btw, I opened the windows to drop temps down to about 70F from 75+, and now I'm loading at 34C! :woot: And I'm still on a single 120mm rad....this chip is going to love my dual rad. And for $280, this chip kicks total ass.
Sounds a bit fishy, why would you break the seal for no reason? Don't forget to give us results.Quote:
Originally Posted by revenant
I guess I felt it was worth it to me to know I was getting what I wanted... ya a bit steep, but I have the cash, and my bday is next week... I figured this might be the last chance to get a vpmw 170.. so I pulled the trigger.. I guess it's possible something is fishy with the "never been opened but the seal is broken" bit, but there's chance in everything.. I guess I might be a little too trusting, but I think/hope things will be fine with it. The selller has great feedback
http://feedback.ebay.com/ws/eBayISAP...iid=6865569849
Anyways.. I will be sure to report back when I get the chip, but I am with my folks tending to my mother who is very sick ATM, so it might be a little while..
Opteron 165 CCBWE 0604 TPMW
Stock cooling
http://img84.imageshack.us/img84/9839/bench8uy.jpg
For some reason prime95 crashes within seconds even at stock. Same thing happened on this system with my old Winchester 3200 and a San Diego 3700, no idea why. Otherwise it appears to be completely stable.
Thats a nice FX-60+ you have there for such a low price :toast:Quote:
Originally Posted by violence
Except the FX60 runs at 1.3V. Maybe it can run that low after some :cord:Quote:
Anybody know what the lowest voltage a good 165 chip can do at stock speed? My voltage doesn't go low enough to test, but I got it prime stable at 2.1 GHz 1.175V.
and the FX-60 is fully unlocked. :) not sure on the vcore question
Now at what I assume to be 24/7 stable. 311*9 1.612v (1.57 in CPU-z/MBM5/SmartGuardian/BIOS, 1.550+104%), 4x LDT (I'll try 5x in a sec). I'm gonna start playing around with my BH-5 next and see what I can do with that until I get my Gskill HZ. It ran 1024-4096 in-place dual prime for 1 hour, that's not a complete cycle of the test but it's still suitable for 24/7 use. When I get time I'll run it much longer. Looks like I missed out on the 170 0550VPMW craze, but the new steppings look nice, so when I get around to it I'll sell this thing and try one of these new chips out. :)
EDIT: Screenies coming later or whenever I can be bothered.
I cracked it!
On the ASUS A8N-E disabling floppy support cripples the board oc capabilities.
Enabled it, boom 280x9 stock voltage no problemo. Will see how high I can get :D Suddenly I feel so much better about this chip.
I was using my computer as normal, and had spent a few hours running Far Cry. Previously, I had spent 2-3 hrs doing research on the internet. Anyway, my friends and I were going out for supper, so I shut computer down.Quote:
Originally Posted by ChkDsk
When I came back a couple of hours later, the computer wouldn't boot up. I had a look at motherboard, and had flashing lights on it. I also noticed a faint burning smell, so I quickly unplugged it.
So there you have it. I wasn't stress testing it, pushing big volts through it or anything. If I owned one of these power supplies, I would be quite vigilant in monitoring voltages, etc.
The technician at the computer store told me that this was the 4th Enermax Liberty PSU to come in this week, and they all seemed to fail from an overvoltage condition.
I just got my system up and running about an hour ago, and it will probably take me until Monday to do an initial overclock.
I'll let everyone know how the new system is working soon.
I bought another CCB1E 0550 VPMW from this guy , he s absolutely trustworthy , no probs at all..Quote:
BTW running 2590 now, 3000 is possible, but the temps are a liite bit high -need a new waterblock for the CPU
Still going....
http://www.sourcekills.com/albums/tsuehpsyde/2800_2.png
Note the half our time difference now, since I played some CS:S last night. :D
IIRC mine does like .975, maybe .95 but I don't remember if it was stable.. I was doing 1.05 last night and got to 2GHz.Quote:
Originally Posted by r3w4
Anyway now start pushing it further tsuehpsyde! and to think it crashed at 2.4 before :p:
THX for the input! :) good to hear... what vcore are you at for 2.8ghz? and about the temps. I have no qualms about popping the top on this baddie for extra chill. I like my procs topless anyways.. ;)Quote:
Originally Posted by famich
EDIT: nm - found your other posts.. 1.37 for 2.8ghz sounds mightee good 2 me. What is your 2950 (I assume you meant that and not 2590, right?) vcore?
Weird sh*t :slapass:Quote:
Been using this PSU for few months now, never had problems with voltages... Maybe bad batch? :slapass:
Bought this one from eBay so it would be appreciated to let this :banana::banana::banana::banana::banana::banana: live :toast: But I'll keep an eye out... Was it on a grounded thing? (Argh, can't find the english word)
