http://www.ybris-cooling.it/images/p...o/pict9196.jpg
Excellent for single loop and many Waterblock :yepp:
here's my stacker 831, first loop finished, will add a second loop for nb/sb/mosfet later :)
http://img217.imageshack.us/img217/5635/dsc00426dn0.jpg
http://img77.imageshack.us/img77/3307/dsc00473jw3.jpg
http://img217.imageshack.us/img217/7718/dsc00434zz5.jpg
http://img217.imageshack.us/img217/5668/dsc00436dj5.jpg
http://img366.imageshack.us/img366/3646/dsc00471px9.jpg
http://img257.imageshack.us/img257/7388/dsc00467wx4.jpg
http://img257.imageshack.us/img257/1683/dsc00468sp4.jpg
http://img257.imageshack.us/img257/8273/dsc00441qr0.jpg
http://img257.imageshack.us/img257/3028/dsc00437yo5.jpg
http://img257.imageshack.us/img257/9293/dsc00479ks5.jpg
!! I love the heatsink poking out of the IO shield and getting cooled by the exhaust! haha n1
inonefly where is PSU ?
Where is powercable?
yep the PSU is relocated at the bottom front. Used a right angled power cable, running from the front to the top of the psu then through the bottom vent ( the bottom fans ) to the outside of the case
http://img87.imageshack.us/img87/6838/dsc00423ls4.jpg
http://img87.imageshack.us/img87/6537/dsc00422hu7.jpg
http://img87.imageshack.us/img87/8840/dsc00421po9.jpg
thanks for your comment,i put it that way for a reason ,that pump i`m using is more than powerful enough, as you proberly well no,and if the water circulates slower the water move`s slower though the block and allowing the heat to transfer better from the block to the water,and with an idle temperature of 29c cpu @3.2 i dont think that is to bad
like the case looking clean and tidy,please check out mine on page 366 if you have the time
*scratches head*
The rate of heat transfer is dependent upon the delta. The greater the difference in temperature, the faster the transfer rate. Accordingly, the longer the water remains in contact with the CPU, the less efficient heat transfer will be, and the less heat-per-molecule is transferred to the coolant. There is absolutely no benefit to having your coolant in contact with your CPU for longer periods of time, in fact doing so will reduce the amount of heat transferred.
By all means, if you can't be bothered, leave the loop as it is. As you say, your temps are fine. But you aren't getting better temps by slowing down the flow of coolant.
http://www.atomic-modding.de/hwluxx/...8/DSCF8021.JPG
http://www.atomic-modding.de/hwluxx/...8/DSCF8024.JPG
http://www.atomic-modding.de/hwluxx/...8/DSCF8032.JPG
http://www.atomic-modding.de/hwluxx/...8/DSCF8035.JPG
http://www.atomic-modding.de/hwluxx/...8/DSCF8039.JPG
http://www.atomic-modding.de/hwluxx/...8/DSCF8041.JPG
yes i understand what you are saying,who is right and wrong about water cooling solution`s you hear so much this ways right this ways wrong.. i use to have the pump straight to the res before and it use to run on idle cpu@3.2ghz,about 35c.now it run`s around 29c as i said.I have a thermometer to keep an eye ambient temperature in th room,but it`s not that i cant be BOTHERED it work`s for me..p.s thought this thread was for showing water cooled case`s only:)
RADIUM...nice clean system
XPATAR..i have read most of the stickies before..i just try thing`s my own way,and this way my temperature has dropped what more can i say
Posting pics and giving advice/feedback. There wouldn't be much point to it otherwise, now would there.
Dude, this is basic science. It's not like a "vinegar vs tomato sauce" or "higher head vs higher flow rate" debate where there's ambiguity, it's just not open for debate without extensive controlled testing. Your watercooled rig is not immune to the laws of physics; if you're getting lower temps with a lower flow-rate, some other variable has changed.
thx for the positive feedback :cool:
And the 88gtx will be watercooled soon, but i dont know wich waterblock is the best.... EK or Watercool (cheaper) ?! My favourite at the moment is the EK Waterblock in the nickel plated version :D
