Helfarch nice cfg. Tell me what rad is it? Place of fittings is interesting :)
i should bill XS for the water rig i now want thanks to all of you!!! :)
XSPC R-120 T on top and a R-120 S in the 5 1/4 bay :)
http://www.xspc.biz/r120.php
Are you asking what case it is ? its the antec 900
a few updates and better wire tuck
http://i31.tinypic.com/jj3dpe.jpg
wtb better camera
kalok what case is that? does it come with the window and mesh as standard?
:/ I hope not previous posts will have the answer!
edit: found the posts but pics are no longer hosted.
Very nice, tell me did you use a standard Cooler Master 4-in-3 Device Module for the second enclosure for the front?
Also that Zalman ZM-MFC1 Plus Fan controller looks great, all your components looks uniform and is so easy on the eyes. Thanks for the ideas. :)
It's a silverstone TJ-07.
it can either come with a window or without the window but the mesh is standard on both.
http://www.newegg.com/Product/Produc...82E16811163067
http://www.newegg.com/Product/Produc...82E16811163060
More and better pics my bulid WC
http://img408.imageshack.us/img408/881/dsc03339oa7.jpg
http://img361.imageshack.us/img361/6683/dsc03306if7.jpg
http://img520.imageshack.us/img520/2576/dsc03313ax8.jpg
http://img210.imageshack.us/img210/6364/dsc03326uw3.jpg
http://img296.imageshack.us/img296/568/dsc03324gt2.jpg
http://img363.imageshack.us/img363/4328/dsc03327kd3.jpg
http://img363.imageshack.us/img363/4145/dsc03329tj8.jpg
http://img362.imageshack.us/img362/8067/dsc03330le5.jpg
http://img529.imageshack.us/img529/3826/dsc03331vc3.jpg
http://img65.imageshack.us/img65/4166/dsc03333ze5.jpg
http://img187.imageshack.us/img187/2228/dsc03334yk3.jpg
http://img65.imageshack.us/img65/5301/dsc03335ux2.jpg
http://img165.imageshack.us/img165/3316/dsc03336an4.jpg
http://img165.imageshack.us/img165/560/dsc03338kk4.jpg
Yeah, that looks awesome I must say!
Plastek...what dye / coolant in your loop there?
It's probably Feser UV BlueQuote:
Feser dyes are really very good :) a few drops will be sufficient for the whole loop, and a 50ml bottle will last you for about 7 - 10 loops.
I gotta get that Metallic coil :D
Hi all :p::p::p:
http://img296.imageshack.us/img296/7...1037ry9.th.jpg
http://img254.imageshack.us/img254/4...7870kl4.th.jpg
http://img355.imageshack.us/img355/8...4826wb6.th.jpg
http://img165.imageshack.us/img165/5...3381yb8.th.jpg
http://img373.imageshack.us/img373/4...3260dx6.th.jpg
http://img60.imageshack.us/img60/152...7333vw9.th.jpg
