I,ve been wondering about those CABYE,s toQuote:
Originally Posted by Hugo van Dijk
Me to, I've seen a CABYE 0536GPMW
Originally Posted by Rufus7
Erm...do i see Fatal error?
:lol:
Right now i'm running large ffts at only 1,4V my last run at 1.42V errored at 1 hour 57min. :p:
Alot of assumptions are being made abt similar chips! My CPU is of the same batch as Zeus and your own, but it is an impossibilty for it to run 3Ghz with 1.4v!!! Unless I have a poor mthbrd this chip will never be able to run at the speeds and voltage you r assuming i wish things were different ;). I have no IHS, am on water with a LRWW and nothing else iin the loop, but still need vCore greater than 1.5v to even think abt getting prime remotely stable. Could you please tell me wht I am meant to do!Quote:
Zeus,
thanxs for teh information, I understand your wearyness for using a multimeter for vCore point. I asked this because I want to know if your '1.42v' is actually tht. For me '1.42v' with my multimeter is 1.49v!!!. So if we are going to say tht our chips are prime stable with 1.42v at least we should be sure tht this is a fact.
I will try your timgs with my chip, hopefully I will be able to get prime95 stable, at the moment I havnt passed more than 2hrs without it crashing :(, maybe i should switch my wireless connection off, to see if im getting crashes because of tht. Our before i forget, which bios are u using?
Yes but it failed after those two hours and you're not even running large FFTs orQuote:
Blend.
Mongoled,
I'm using bios 623 that came as stock.
Prime large ffts failed after 46 minutes at 1.4V
Gonna burn in more with small ffts.
Before i ran a night Prime with small ffts at 1.45V 3GHz large ffts always failed within 30minutes, now it's 2hours+ stable at 1.45V at large ffts.
Gonna do small ffts at 1.42v tonight. :)
The Screen with 1,36Vc was Large Custom for 2 Hours.
Ok I will try burning with small FTT's also, Ive been using the blend test to do my burning in + 'CPU burn-in' program. Im ok booting into windows at 3Ghz with 1.4volts im doing tht right now, but as soon as I start prime, boomf it failsQuote:
Originally Posted by Zeus
LOL, hehehheee
Small ftts seems to keep running fine at just 1.4V (45 minutes now)
Forgot to tell:
DRAM drive strength: 7
Data stenght: 2
Dram response time : fast
http://tinypic.com/eb4i0i.jpgQuote:
Sierra and myself are using the CABYE. I'm not sure which week he has or the rest of the code. He of course is just tearing it up with his posts. I'm hoping mine will close the gap when I get it in a better mobo. Wish he would have indicated his air/water limit, but he may have gone straight for the sub-zero cooling.
You might have better luck asking the leprechauns where they keep their pots of gold. :p: j/k I'm sure someone would post if they had a source - right after they get their shipping notification. Read through the posts and you'll find the online stores that have shipped Opty 939. Then with multiple browers up on those stores, keep refreshing until they come back instock. Be patient, it may take a while. :DQuote:
Originally Posted by halcy
I have different values for these, but i doubt they will help my chip run stable with 1.4v! Ive been running small ftt's for an hr now with 1.52v bios (MM==1.59v!!). 1.4v impossible, hehehee.Quote:
Sorry, I should have posted that info earlier. My chip is CABYE 0528GPMW. I went straight to phase change cooling because I wanted to know what the CPU could do frozen. I'm an impatient person. :D ;) The chip will eventually go into an air-cooled system.Quote:
Originally Posted by gundamit
I had some heat-related issues a few days ago because the IHS was apparently not making good contact with the core. I re-seated the evaporator head and now everything is fine. I'm very close to getting the Opteron to complete SuperPI 32M at 3.5GHz. But I think I need 1.67v and that puts a real strain on the system. Will keep you posted.
It failed after 2 hours with a ~5C ambient....just raise the voltage and find it's max already.Quote:
Put this on a couple other threads hope everybody gets it monarch told me today that 146's (939) will be on there site this fri. Will try to find out some step'ns have a good friend that works there.
I thought I read an earlier post that said they talked to Monarch and they said they would never sell them. :confused:Quote:
Originally Posted by jot
That's like I talked to the DFI office today about a rma so I then asked for sales. I asked the salesman when the experts were going to be out. He said he was getting them today and they would hit the streets by Friday. :rofl:
Sales people generally tell you what you want to hear.
If you know German, please tell me what the cooling is in the #873 post this thread for the German opty oc results. Thanks
U are soo right about that, but this guy usually doesnt steer me wrong. I hope
ok im in love :) 3gigs defualt v-core 1:1 on tccd 2.5-3-3-7 going to run some prime wish me luck! hope it passed this would be the start of a good ocing experiance....
peace perc,
good god, i just stepped through hoops to get a 146, those baaastads @ monarch, lie, then they don't lie...!
they need to just tickle our ears ALL the time, not just some of the time :D
its all good, 1 heart attack later and a 146 on its way :slap:
Dude that's insane 1.36. Can't wait to put one one my phase if I ever get it back, have'n a mod done hope it helps.
I know that feeling, don't tell me that this isn't sweeter then oc'ing a x2. :DQuote:
Originally Posted by Perc
These are look'n like the best ocer's ever, come on fri! Oh the X2's suc comp to these.
it locked up on me about 10mins in while i was setting up to prime soooooo lets see what 1.4v does at 3gigs same settings as above. also i rember someone saying that with thier tccd theyhad to change from 2.5-3-3- to 2.5-4-3- to get stable you think i may have this problem or 1.36v just pushing it for 3gigs. also if these 0530APMW CABNE chips are realy fx core wouldnt they run a 200mhz oc or even more with the chips defualt v-core? know what im saying?
peace perc,
Maybe these are the CABNEs that didn't make the FX-57 cut but were supposed to?
Either way...they're about the best deal you can get for ~$200.
The high Pre-amble requirement still makes me curious....like these were meant to be Opterons and were made in the FX production line.
I agree. Loosen that ram a little and keep burn'n I know it will run.
You got an old verison of MaxTCase that shows 940, the new v1.03 shows 939. Also your 67c is higher then my 65c on my 146. Burn in helped both my optys.
You'll see that just a little bump in Vcore really makes a big difference in being stable.
