New X2 issue found with Domains
This MAY be because I don't have the AMD CPU Driver installed, I am not sure but here is what I found with my troubleshooting.
I run XP SP2 with 2 workstations and a Windows Server 2003 Standard server with Exchange 2003 installed.
I noticed Event Viewer messages with the following information:
Event Type: Error
Event Source: Userenv
Event Category: None
Event ID: 1054
Date: 8/13/2005
Time: 1:21:08 PM
User: NT AUTHORITY\SYSTEM
Computer: PENTIUM
Description:
Windows cannot obtain the domain controller name for your computer network. (An unexpected network error occurred. ). Group Policy processing aborted.
Naturally you will only see this if joined to a domain controller. The fix? well I tried many many fixes but finally at the end of my troubleshooting and using gpupdate /force over and over to test, I found a racing condition existing with the dual cores, used my patent pending explorer.exe set to one core fix. Voila when the gpupdate.exe runs (runs so fast I had to turn on dual prime to slow it down to confirm only one core was selected) it does not error and shows:
Event Type: Information
Event Source: SceCli
Event ID: 1704
Date: 8/13/2005
Time: 1:21:08 PM
User: N/A
Computer: PENTIUM
Description:
Security policy in the Group policy objects has been applied successfully.
Now just for more info, this issue only occurred occasionally definately NOT everytime it is very random and the reason I investigate so much is because some of the solutions pointed to NIC communication issues, naturally with online gaming and my home network which I use for work also I did not want networking issues, also I'm using the Marvel LAN Adapter because I read somewhere it used less CPU.
I ran the group policy update 20 times in a row and not a single error in application viewer, definately a racing condition which was one idea someone had on eventid.net but he didn't provide much info on it really. Of course I really don't care about the group policy erroring occasionally I don't have a need to have group policys on my home network and the fact it errors once in a while doesn't mean much to me now that I know the reason.
Thought I'd put this message up because it kind of goes with the other racing conditions mentioned here for gaming and how setting one core to the application / game corrects the issue. Hope this helps people out and saves someone time.
