screeny of my setup. 255x11 (2805mhz) finally got my BH-5 to comply a little bit. 8M stable atm...going for 16M after some burn-in. :)
That is exactly where I'm at with my "0508", but with an XP-90C.Quote:
Originally Posted by boostdfd3s
Using a Vdimm modded Epox NF3, with Mushkin PC3500.
32M SuperPi passes.
Any reason to get one of these over a Venice/diego now really? Other than maybe if you plan on putting it under a cascade.
Mushkin PC3500 BH5? 2x512mb? post your settings :toast:Quote:
Originally Posted by serlv
i made this whit the stock coller...
it´s a 09 week ...
http://img55.echo.cx/img55/39/screenhunter0045ev.th.jpg
http://img55.echo.cx/img55/7217/scre...r0031zz.th.jpg
i´m waiting for my r404a prommy to tested it.
2700mhz undervolted, nice :) How stable is that though?
No, 256x2.Quote:
Using 3.41 VDimm, 1.63 VCore
BIOS/A64 settings shown below.
I'm still trying to learn A64 tweaking. Any suggestions or hints?
http://www.xtremesystems.org/forums/...id=30026&stc=1
in bios set ur us rating to 3120 set it to 15.6 us in a64 tweaker, it's more efficient
Huh? Which setting? Not getting you.Quote:
Originally Posted by i found nemo
I'm not using an NF4 w this chip, so I don't think of seen that setting in my BIOS. Or in A64 tweaker. Which setting?
he means the refresh rate (tref), might not have it in you rbios or it could be caleld something else, what mobo?
Epox 9NDA3+
Serlv, identical vcore here at 1.63v....nice on the vdimm though. I had to use 3.5v and burn in extensively to get it half stable! :toast:
Probably related to the fact they're 512s... Maybe.Quote:
I had 'em up to 274 @ 3.6, but, of course, I can't run the 11 multiplier with that FSB. So, I can't get the overall clock as high. It didn't seem to make a difference as far as SPi went either, at least as far as 1M. So, I figured let me back off the volts a touch and run them a little slower. A program I run 24/7 seems to benefit from total mHz, and as you know, the system doesn't seem slow where its' at. ;)
Just want to add this to the thread, stock voltage and HSF.
http://img268.echo.cx/img268/4913/26...vspi32m4jz.png
I'm up to this on water. My personal record. :p:
Do you guys think I can go higher than 1.7v Vcore without danger to the CPU?
http://img284.echo.cx/img284/9340/29...esized704n.jpg
I know it's old but that printed out motherboard is just classic.Quote:
Originally Posted by s7e9h3n
:rofl:
default
http://img52.echo.cx/my.php?image=defaut5rp.jpg
and whit 1.84v
http://valid.x86-secret.com/show_oc?id=19977
WoW! :eek: babyelf and MadMog :toast:
Can you guys show me your BIOS settings for getting stable at those speeds?
Hardware and cooling also?
u want a picture or just the settings?
260x11 = 2860
vcore
1.4 x 123% = 1.722
bios shows 1.67
ram at 2-2-2-5 3.5v
LDT multiplier at x3
Vldt 1.3
Vchipset 1.7
same for the below picture
cooling
http://img.photobucket.com/albums/v3...f/DSCN2444.jpg
XP120 & sunon 108CFM on CPU
Vantec Fan Card blowing on Dimms
The more informations the best! :p:
Thanks for your help. :toast:
Kos
erm.. what other info do you need?Quote:
Originally Posted by Kosmic71
bios is 331-2
Yep, I run my 3500+ 130nm with 1.9VQuote:
- SP8M @ 1.9V
- SP1M 1.77V :D
now that is sick....Quote:
Originally Posted by Dani
Everything looks to be there :p: Vcore, Vchipset, VLTD, FSB, multi, LDT/FSB ratio, BIOS etc thank you much.
The 32M at 2860 MHz impressed me!! :woot:
I think I've got a good cpu, 3 things prevent me to be SPi 32M stable @ 2.9.
1. I don't have active cooling on my RAM, Panaflo high RPM 90mm just arrived so I should be good now! :D
2. I'm still with 310 bios, I will try 331 414 and 510 I'm looking forward to 510
3. I'm running a SLI setup, I don't think its good for OCing.
