[hwbot] 12.218 - Q9550 @ 3780mhz - 4x1Gb @ 667mhz 5-5-5-15 [/hwbot]
http://img.photobucket.com/albums/v6..._oc/85x444.jpg
Is that all your 9550 can do? :confused:
Have not really tried to push it yet m8 but on air 450x8.5 wil probably be about the max for this one.
[hwbot] AriciU - 13.219 - E6750 @ 3843Mhz @ 1.62v [/hwbot]
http://www.hwbot.org/result.do?resultId=686665
[hwbot] 10.657s - X6800 @ 4744 MHz - Foxconn MARS- Crucial PC2-5300 10th Anniversary @ 527 MHz @ 4-4-4-8 Timings - DICE Cooling [/hwbot]
http://i157.photobucket.com/albums/t...perpi_best.png
[hwbot] 10.718 - E8500 @4320mhz (480x9) , 2gb @960mhz 4-4-4 , Asus P5K SE , on air[/hwbot]
[hwbot] 10.203 - E8500@ 4560mhz , 2gb@ 480mhz 4-4-3 , Asus P5K SE , on air[/hwbot]
Screenshot
[hwbot] 8.828 - Intel Core 2 Extreme QX9650 @ 5250MHz - Gigabyte X48T-DQ6 - Team Xtreem DDR3 @ 840 with 7-6-6-20 - Dry-Ice on CPU[/hwbot]
http://www.thehardwarelabs.com/forum...616aa99a72.jpg
e2140@3.4Ghz on AIR, STOCK HSF!!!
and thats on 1.4v so im sure theres more room there, ill b able to push it further once i get 800mhz modules
but for now, this is it!
http://img201.imageshack.us/img201/8721/1775eo6.jpg
[hwbot] 17.750 - e2140@3.4ghz 1.4v, ddr2 667@850 2.25v 4 4 4 10 1T [/hwbot]
[hwbot] 9.937 - E8500@ 4655mhz , 2gb@ 490mhz 4-4-4-10 , Asus PK5 SE , on air [/hwbot]
[hwbot]WeldZilla -9.843- E8400 @ 4725 MHz air [/hwbot]
http://img.photobucket.com/albums/v2...illa/piguy.jpg
Need some more Xtreme cold nigfhts to pump more cold air to this system
WZ
[hwbot] 9.828 - E8500@ 4712mhz , 2gb@ 496mhz 4-4-4 , Asus P5K SE , on air [/hwbot]
Screenshot
[hwbot] 8.578 - QX9650 @ 5398mhz , 2GB Corsair @ 519mhz 4-4-4-12 , FOXCONN MARS , LN2 on CPU & GPU [/hwbot]
http://img528.imageshack.us/img528/7...8ln2ko2.th.jpg
[hwbot] 9.391 - E8400 @ 4815MHz Air Cooled TRU120E - Abit IP35-Pro - Transcend AxeRam D9GMH DDR2 800 @ 1070 Mhz 5-5-5-15[/hwbot]
http://www.imgx.org/files/11573_tzwlm/4815.JPG
[hwbot]16.18 - Core 2 Duo E4300 @ 3510 - 2x1Gb Kingston 667 @ 975 5-5-5-15 - Big Typhoon VX[/hwbot]
http://i38.photobucket.com/albums/e1.../superpi1M.jpg
[hwbot] 41.968 - Athlon XP 2100+ (225*11) 1.9v air cooler, EPOX 8RDA3+ - HyperX 4000@225 MHz 3-4-4-8 2.7v [/hwbot]
http://img255.imageshack.us/img255/2...superpiyr8.jpg
[hwbot]Memory - 10.015 - Core 2 Duo E8400 @ 4630 - 2x1Gb OCZ Reaper HRC PC9200 @ 544 4-4-4-12 - Asus P5B Deluxe WIFI AP-All Air[/hwbot]
http://i234.photobucket.com/albums/e...l-10015sec.jpg
[hwbot] 25.813 - Phenom X4 9500 @2972 1.44v air cooled, ASUS CROSSHAIR II Bios 0502 - OCZ OCZ2N1066SR2GK@540 CL5 5-5-15 2CR Ganged 2.10v [/hwbot]
http://img176.imageshack.us/img176/5...2973xf1.th.jpg
[hwbot] 8.985 - E8500@ 5106mhz on SS , 2gb@ 1074mhz 4-4-4 , DFI 965S [/hwbot]
Screen
[hwbot] 8.421 - Intel Core 2 Extreme QX9650 @ 5508 - Foxconn MARS - MSI 8800GT - LN2 on CPU & GPU - Corsair Dominator @ 550 4-4-4-12 @ 2.35V [/HWBOT]
http://img215.imageshack.us/img215/5...5508xg4.th.jpg
[hwbot] dr_sharp - 13.234 - Core 2 Duo E6600 @ 430x9, 1.675V - 2x1GB G.Skill GBHZ @ 1:1 4-4-4-10 - Asus P5B Deluxe WiFi - Water [/hwbot]
[hwbot] Gutterz 9.343- E8500 @ 4900Mhz Water , 2Gb G.Skill @ 1088Mhz 5-5-5-15 , Evga 780I [/hwbot]
http://i39.photobucket.com/albums/e1...04/PC/4900.jpg
1.78V @ watercooling?? :shocked:
[hwbot] nachthymnen - 8.172 - QX9650 @ 5667mhz LN2 - Maximus Extreme - Evga 8800GTS 512 - OCZ Platinum 12800 @ 1744mhz 7-6-6-15 1T(2,06v) [/hwbot]
http://www.pctunerup.com/up/results/..._Spi8.172w.jpg
By that point in the night I didnt care what happend. My radiator is mounted in the front of my case an the cold winter air was directed in to my case with a house fan an some boards. Air after passing threw the radiator air temp was 25f inside my case. Computer was running fine an I didnt care if it caught on fire after loosing 2 gig of ram @ 100mhz Overclock on them. I Ended up using a single 2Gig stick of G.skill pc8000.
I tried so bad for 5.0Ghz but I was out of voltage incriments an I even cranked the GTLref an It would only post 5.0Ghz no Windows action.
Chip survived its running good as can be at 4.0Ghz :up:
