Corsair 2133 C11 can be Hynix CFR or Samsung HCH9, I have both types.
That's interesting...CL11 at 2133 for HCH9 based stuff? Would never have guessed that. What's the voltage...1.5v?
I bought Corsair set. After I took off heat spreader I saw that Corsair had renamed the IC's. As old school...
for now I just placed them into Z77 Pro4 ASRock motherboard and Pentium G860. Loaded XMP profile and everything is working well.
Where can I find this chart where Corsair tells which revision is provided by which ICs?
Mine version of set was something about 8.XX
What's the latest batch of this hyk0?
At post #866 computerpro3 posted that he was testing week 1221...those are the latest generics that I've seen.
The GSkill Trident X 2400 C9 kit of Shiranui Gen-An (post #31 in linked thread below) are week 1237.
http://www.xtremesystems.org/forums/...9D-8GTXD/page2
Also week #37 are the ICs in the pic of the GSkill 2666 C10 kit posted by ihog6hog in post #24 of this thread.
http://www.xtremesystems.org/forums/...2666c10d-8gtxd
Looks like those later weeks migh have even more potential. Process being improved upon, perhaps?
Thanks Reefa:)
Quick test with latest bacth from NE
http://img713.imageshack.us/img713/2...enshot008t.png
Uploaded with ImageShack.us
http://img585.imageshack.us/img585/8...enshot012h.png
SonDa5, look on the upper right hand corner of his screenshot, at the SPD tab of CPU-Z, go down to serial number and then across to the week/year and you will see that they are week 29 of 2012.
Edit:
Or just look at the pic that Dump subsequently posted. :)
Your Inbox is full. Got a question for you about these, so I sent an email to your paypal addy.Quote:
Originally Posted by Dumo
I got the same batch today! :)
Better than batch 12/05 for me.
Work great with my delidded 3770k at 5GHZ. 1T 9-10-10-24 1.5v DRAM voltage.
http://valid.canardpc.com/2609406
Batch 12/29
http://minidriven.com/BlacknBlueforI...mmykeepers.jpg
Really the best RAM I have ever owned.
I just need to learn how to over clock them past 2133mhz and I will enjoy them even more. Right now I have only adjusted the 1st 5 settings on my ram BIOS settings.
Received 4 kits from B&H to Australia (4 day shipping - nice!)
All of them are Week 21 / 12. Hoping for similar results to this
http://i.imgur.com/9aN3c.jpg?1
First set I've tried is pretty good so far. Had to move them from RAM slots 1+3 to 2+4 - couldn't boot past 2200 with the ram in channel A.
I wasn't expecting much out of them from a Z68 board seeing as most of you are using them on the Z77
2400mhz 10-11-11-28 1T @ 1.63v
Haven't had much time to tweak them, can probably lower the voltage a little. They are lukewarm to the touch while running Memtest86.
http://i.imgur.com/ZxarY.png
Best I can do with my new Hyko Samsung 2x4GB kit from 12/29 batch is 2246MHZ with 1.55v.
I set my memory speed to 2200mhz with 9-10-10-24 1T with an increase my BCLk a little to get there. This is with my 3770k at 5GHZ@1.45v Vcore.
SuperPi 32m is 6:40 with these settings which matches my best time I had with my Gskill CL9 2400mhz kit that I had over clocked to 2666mhz CL 10-12-12-31 1T at 1.7v ddr voltage.
http://valid.canardpc.com/2618023
I think this kit will go alot faster but my MSI Z77 Mpower BIOS is limiting it in speed settings. :(
Best kit of ram for the money.
This ram helps get my 3dMark11 physics score over 13,000. http://www.3dmark.com/3dm11/5249080
Got an 1150 date with a M5A99FX Pro R2, and FX-8350. Going to start toying with them tomorrow.
CPU and or board was a dud. Couldnt get over 4.5 without throttling.
Took them back and got a 3770K and Z77X-UP4-TH
Hi , could you help me out please i bought one of this kits and iam quite disapointed that it giving problems if i try to just oc a tiny bit.
At stock system runs fine if i say bump it to 1866 11-11-11-28 @ 1.5v i keep getting errors in windows saying AMD driver stoped responding :/ no blue screens and memtest86 run for 12h was perfect. Iam quite new to this Memory oc my system is preaty mutch on default bios settings exept for turbo multi at 42x
Any ideas maybe i just got a horrible kit ?
My system is on my signature below.
10-10-10-28 @ 1.55vdimm 2133mhz on sandy bridge. going to really play around this weekend and try to get CL9 stable.
First test with FX-8350 (on 890FX, with SLI of GTX580s).
https://fbcdn-sphotos-a-a.akamaihd.n...48067044_o.jpg
DDR3 1866Mhz 9-9-9 :rulez:.
DDR3 1966Mhz 9-9-9-27 ROCK SOLID @1.5V
https://fbcdn-sphotos-f-a.akamaihd.n...90115874_o.jpg
delicious ram, bought a used set of 2x4 a 43,42 USD :D
they should just test at a little more on my P67
here i test 2
http://img9.imageshack.us/img9/6015/x7ls.jpg
