Rampage III Gene EK Waterblocked....
http://i572.photobucket.com/albums/s...i/EKBlock3.jpg
Managed to pick up a nice camera "as a Christmas gift" and will be having more questions in the correct area, however;
As there are what I call numerous "professional quality" shots here I was wondering how many are working from .raw files? :shrug:
Well Since I'm Allowed To Post Now... I'll Donate Some Pics
Aqua Computer Kryos HF
http://farm6.static.flickr.com/5167/...ed806af8_b.jpg
Intel Core i5 670 ES
http://farm5.static.flickr.com/4132/...83e900ce_b.jpg
EVGA GTX 460 GPU
http://farm5.static.flickr.com/4052/...3bbd2d96_b.jpg
Koolance Ram-33 Modules
http://farm2.static.flickr.com/1392/...38117121_b.jpg
wow havent seen those ram blocks from koolance before, look awesome!!
And probably resistive as hell. Very small cross section and load of tight 90deg turns. Ram uni-blocks like those from MIPS is way to go.
yeah they do look pretty slow with all those 90s but itd be worth it in its own loop or sub loop, very bling :D
remembers me at my first cpu block:
http://www.abload.de/img/board02099f.jpg
Anfi-tec eXFRS limited edition
http://h-4.abload.de/img/sb01640l.jpg
EK-RAM Dominator prototype block with acetal top, just came from the workshop. Not nickel plated yet, there will also be nickel-plexi version.
http://file.si/pfiles/138180/DSC_0388.JPG
http://anfi-tec.de/forenbilder/10.12...I_extreme2.JPG
Anfi-tec Asus rampage III extreme set
http://anfi-tec.de/forenbilder/10.12...I_extreme6.JPG
I am loving the EK Ram Block, when do you recon the Plexi-Nickel version will be available?
@Mudgey: Simultaneously as Nickel Acetal. I believe right after new year! :up:
Hi Tiborrr,
Thanks for the reply, i'll certainly be picking one up as soon as they are available!
jc... what is the difference in performance between serial and parallel in the piece that attaches the VGA water blocks to each other so that you dont have to use like an 1/4in of tubing between each card in SLI set ups?
this is the best thread. theres some of mine
http://i312.photobucket.com/albums/l...0-22202240.jpg
http://i312.photobucket.com/albums/l...0-22205721.jpg
http://i312.photobucket.com/albums/l...0-21202933.jpg
http://i312.photobucket.com/albums/l...0-21204955.jpg
http://i312.photobucket.com/albums/l...0-21195217.jpg
Rotary, 3 pics wrong gallery. ;)
2*Swiftech MCP655 + EK-D5 Dual TOP G1/4 - Black Acetal + EK-Multioption RES X2 - 150 Advanced + EK-Multioption RES X2 - LINK50/60 1xG1/4
http://img146.imageshack.us/img146/6875/mg4819small.jpg
Swiftech MCRES Micro Rev. 2 + Bitspower G1/4 Crystal Lighted Stop Fitting
http://img573.imageshack.us/img573/3474/img4854a.jpg
My new toys:
Asus P6T6 WS Revolution + Koolance X58 FC custom painted
http://b.imagehost.org/0457/B_W_000071.jpg
http://b.imagehost.org/0453/B_W_000073.jpg
Bitspower Black Freezer Asus X58 Mosfet blocks
http://d.imagehost.org/0025/B_W_000105.jpg
http://d.imagehost.org/0270/B_W_000106.jpg
http://b.imagehost.org/0320/B_W_000107.jpg
http://b.imagehost.org/0490/B_W_000108.jpg
Corsair Dominator 3x2GB with white "combs"
http://d.imagehost.org/0851/B_W_000110.jpg
http://d.imagehost.org/0499/B_W_000111.jpg
EK HF B&W
http://b.imagehost.org/0786/B_W_000112.jpg
Nicely done!! :up: All the nice goodies available for intel mobos almost has me willing to go to the "dark side"! :shocked: :lsfight: ;)
Did you paint the RAM combs?
