your problem was the timings , dont worry !!! ;)
you have to adjust now and obtain the best compromise.
280fsb 1/1 on 2-2-2-5 timingsQuote:
Originally posted by niaboc79
i just receave my shuttle an50R
http://www.yamafoto.com/users/niaboc...80-2-2-2-5.JPG
OH MY GOD how much vdimm on that (probably) BH5 memory?
(why didnt you reply about our deal with the 3ghz barton)
280 on BH5/6? WTF?
Wow that is really good dancing bananas!!!
280 with BH5 corsair @ 3.7Vdimm ;)
PC3200 LL rev. 1.1 or PC3500 C2 rev. 1.1 ?Quote:
weeee, 3 GHz screenshot ^^
Not stable at this speed, max stable is 2.85 GHz.
Might try to get 2.9 GHz stable on 2.0v next time.
pics of setup: http://users.pandora.be/alz/dryice64/
CPU: CAATC 0405 VPMW
This is what I don`t get...all 3000+`s are Newcastle and the 3200+ and 3400+ are ClawHammer right? Well then why is post #2`s 3000+ (previous page) showing as a ClawHammer?
Link
Because it's an older version of CPU-ZQuote:
Link
Yes.Quote:
I will try later... Maybe 2-3-3-6 will work?
K32A are you sure GeIL PC 3700 are able to run 2-2-2-5 as you are saying on your sig? I highly doubt it
PC3200LL rev 1.1, it's BH5Quote:
my barton give me only 35sQuote:
3.7v
My A64 3200+ is now at 2740MHz, 3D-benchable
http://hk-submit.no-ip.com:2/bbs/att..._3200+2740.jpg
At 2790MHz, superpi1M completed.
http://hk-submit.no-ip.com:2/bbs/att...790superpi.jpg
20MHz more than before :D
tintin can you tell me where ya got oyur wallpaper??
and as always nice clocking my man :)
Tin tin that 3dmark01 score is 1000 marks low . compare to my score below sig
edit: nm you are running ddr 333 setting
Yes, i run at 2-2-2-5, 2.7v now ;)Quote:
Wee, got my cpu up to 2400MHz, but my memory could'nt handle it at 1:1 so i just ran it at 2:1
Reason:Quote:
1) Windows 2000 + DX 8.1 will have about 500marks more
2) The Game 1 low details always has some fluctuations in the frame rate, if you run this test for, say, 10 times, you will see at least, there is a score have about 20fps in average more for the same setting :D
3) You are running your CPU/RAM at 1:1 ratio
Totally, 1000marks...hahaha....
:D
Hey!
I hope that you guys can help my friend ;) He's just got a A64 3200+ caaoc 0352spmw but it will not go higher than 213x10!!! Can any one of you get some data on that chip for me?
Greets
A64 3000+ 0350 XPMW CAATC AEP4AP 9
Just Waterchilled.
http://pageperso.aol.fr/misteroadster/2958screen.JPG
I can do better , a little , .... but better :D
I am testing an FX-53 actually. :rolleyes:
cooling AMD Boxed :
stock vcore: 2510 stable prime 95
1,65V: 2580 stable prime 95.
max screen 2749 Mhz@1,65V
http://pageperso.aol.fr/misteroadster/MAXaircool165.JPG
http://pageperso.aol.fr/misteroadster/prime2588.JPG
I can do very very very Much better :D
wow
impressive mister :D
mister,
with the cooling box fan it's: :banana: :D
Waterchilled FX53 : Rock Stable Prime 2960Mhz 1,85Vcore.
But cpumark and superpi 2M doesn't work , i think there is a problem with my ram Corsair Ecc 3200 (CH5).
http://pageperso.aol.fr/misteroadster/3156.JPG
try with 2v for 3.2G
between ur FX-51 and FX-53 there are 100MHz at same voltage
I see 3275MHz rock stable in cascade for Tom Holck
:D
