:down:
http://www.xtremesystems.org/forums/....php?f=59&a=53
Is that a thumbs down to the link or the rules :p:
Whatever you want it to be. :D
Naw, really it was a thumbs down to posting cracked stuff.
Sorry for the link i didnt think at the moment i put the link
its now deleted
Ket you now you have the IDA Pro 5.3 i gave you?:)
If you need another app or something just say myfriend :cool:
So ket-- it seems like you actually like the older bios's over the new ones.. m703 seems to be the one you like best-- yes? What about 1406?
Right now im using m1402 and it doesnt seem quite as stable as i would like.. Seems like guys are having good luck on 703 ande 1406.. Also-- is there another place to get your m703?-- Im having a rough time with megaupload tonight..
I do like like 703m a lot, its a fantastic BIOS. When I was running it I could do PL6 @ mem frequencies of 1216MHz+, which lead to some incredible bandwidth scores even with a CPU at *only* 3.4GHz. My P5Q Pro is currently in RMA as 1. I killed the BIOS chip, 2. The fan sesnor was going dodgy, and 3. The board wouldn't POST with a NB voltage of 1.7v+, so haven't had a go with 1406 yet. Theres no other place to get the files apart from megaupload either right now. If your having problems getting the files, then I guess that means quite a lot of ppl are dowloading them atm :p:
I posted them on rapidshare.....
Damn "CPU Fan Error" message returned.
WTF!
Is anyone else getting this error when using Q-Fan to control CPU fan speed? I get it every day when I first turn my PC on.
No errors, fan control just doesnt work at all :mad:
That sucks.
Fan control works in 703m
I use Q-Fan and for a period of time (I believe it was with BIOS 1201) I did get the CPU Fan Error. It's been a long time since I've seen that error now tho... or maybe I just haven't been paying attention because I set "Wait for F1 on error" in BIOS to disabled and unplugged the case speaker... if I'm getting the error, I'm no teven aware of it, so it's as good as not getting it :P
I just leave my fans blaring and forget about it.
Pro was having fan and NB issues, hence RMA. AW9D-Max just got a corrupt BIOS so I bought a new board, when my programmer arrives I'll revive the Max. No ETA on the uber BIOS, simply as it might not ever happen.
I wouldn't be able to forget about mine, the CPU fan is ridiculously loud on full blast. Not only that, but there's literally only a 1 degree decrease in temps between full on and Q-Fan managed. With Q-Fan enabled, my CPU fan is silent except for when under heavy load. Massive difference in noise.
That's what I'm gonna do. I don't use a speaker anyway, they are annoying and unnecessary 99% of the time, but I never thought about disabling "Wait for F1" option, for some reason. I'll do it now! :up:
Actually, while I'm thinking about it, what is the point of Num-Lock being enabled on bootup? I have wondered about this for years and never investigated it.
Point of it AFAIK is if the option isn't left on the numberpad on the keyboard is always off and you have to turn it on yourself with the numlock key :eek:
Can't wait until you release the P5Q Pro 1406m BIOS Ket :up:
Hopefully my Pro or the TPower will arrive soon, whichever board comes first is what I will use to get my system running again to make the BIOSes :up:
hi Ket when rls mBIOS 1406 for P5Q-DLX?
for all you people postin rapidshare/megauploads.. you should really check out http://www.getdropbox.com/
the app you run is really small and its GREAT, 2 gigs storage, direct download links, and its fast. downloads @ 1.9MB a sec (cap for my cable) like nothing.
You need to run an app to download/upload? No thanks.
