Altering northbridge multiplier with this board.
The research I have done says that you can change the multiplier of the CPU-integrated northbridge in the BIOS of this board. The sources also suggest that this feature was not available with the original stock BIOS (F1) and was added later.
http://www.hardwarezone.com/img/data.../giga_bios.jpg
This screenshot of the BIOS shows at the top something called the Memory controller frequency. I know that the CPU intergrated northbridge deals with the level 3 cache and memory. Is this the northbridge multiplier by a different name??
I am assuming this to be the case as the values match up i.e stock 2000Mhz and default multiplier x10.
The recent F5 BIOS allows you to adjust the voltage of this too doesn't it?
