Thumbdrive.
Your looking for BOOTMAX !
It dosen't exist yet.. ;)
We are still looking for a leader!
http://www.xtremesystems.org/forums/...d.php?t=163212
I'll just go ahead and use a thumbdrive tomorrow. Also why does Probe read 2.11 for the DRAM when I have 2.0 set in the bios ? Is it just an incorrect reading or is it overvolting ?
Based on how it clocks my ram, it's overvolting.
So is it best to uninstall it ?
I just got this board today the LCD poster is a neat lil deal. Does it show anyting other than the time? Someone hack this thing to show the speed of my CPU :P
wasup, please help me, i want to buy the maximus formula normal WITH-OUT the WC tubes, i need this :
http://www.asus.com/999/images/products/1889/1889_l.jpg
but, i search in google 'n don't find a seller for this mobo, please if anyone see this mobo in a online store please tell me :worship:
You can check it also on hardware section in BIOS...I think those readings are closest to the true...
i upgraded from ip35pro to maximus and so far my feelings for that mobo are mixed...
pros: very good ram o/c
cons: limited fsb o/c (i lost ~15 fsb ),issues with certain memory dividers(4:5), mobo doesn't post with x-fi on the last pci
are there any tips to gain more fsb for quads?
using 0505bios
I don't think the non SE has made it to the vendors yet. Everyone still has the SE though.
http://www.clubit.com/product_detail...emno=CA4802848
Or you can get the P5E
http://www.newegg.com/Product/Produc...82E16813131219
I see that some of you are looking for the non-SE version.
I thought the SE can be used in a air-cooled configuration as well. The heatpipes looks similar.
Is the non-SE better if air-cool?
Take the plunge man...go LC
I was thinking about getting Maximus Formula. Not sure now after I see alll the problems you guys are having.
Maybe a P5K-Deluxe?????
so what about the ausus p5e ? i search a review for this mobo , but don't find googlin' , maybe some user see a review for this version :confused:
don't waste your time and money to make a lateral move...UPGRADE!;)
see this, some friend show me this pic of asus P5E ....
http://img166.imageshack.us/img166/8...6ro7yi3.th.jpg
its, a maximus formula PBC ? or this is P5E CHULA jijiji ( chula in spanish means pretty LOL )
so far im really happy with this board
I previously had a P5B-DLX WIFI and my Q6600 wouldn't post at anything above 3.2GHZ, now im at 3.6GHZ with prime stable with only 1.4v
Im having some issues with certain memory dividers like everybody else but im counting on this to be fixed on the next bios rls
