http://img292.imageshack.us/my.php?i...b1ed6b7ix5.jpg
no, also 3600mhz, 400fsb, 6x multiplier because of EIST.
Great results!
Great results!
I've used HIS in the past and I haven't had any issues with it thats why I say that. Sure notebooks might have issues or OEM machines because they sometimes switch the bios to only load from that place but regular retail or OEM shouldn't even consider that as an issue.
negative , with 8.37 he have EIST enable ( when CPU is Idle run multi x6 and FULL run multi x9 )
look at cpu-z >> FSB = 400 (400x9 = 3600mhz) ;)
He run Both tests :
- E6600 @ 400x9 = 3600mhz >>> 12530marks (3.8)
- E6600 @ 400x9 = 3600mhz >>> 12086marks (3.7)
>>> 78 FPS in Game (3.8)
>>> 63 FPS in Game (3.7)
regards
I had a HIS 1900xt and currently I'm using a HIS 1950pro Iceq3 on my internet rig. I've always used official ATI drivers or Omegas without a single problem. Their bundles are great, too.
does anybody know were could I get latest drivers ?
http://www.sapphiretech.com/us/media...iew.php?pid=80
Lol,Sapphire could foresee the future,look at the date:)
my friend is testing X2900 with E6400
that 3dmark 2006 scores and Dark Messiah FPS with E6600 its from a guy of other forum , the source is there (in the end of the post)
Source >> http://chiphell.com/viewthread.php?t...&extra=&page=3
link doesnt work
regards
Think this is what he was linking.
http://www.sapphiretech.com/us/media...iew.php?pid=78
But the link to the press release doesn't work on the site.
This is what he meant;).
The power requirements for this card is 225W so that means: 75W from the PCI-E slot + 75W from the 6 pin connector + 75W from another 6 pin connector = total of 225W
That means there is NO need for 8 pin PCI-E connector?
If overclock then:
If there is a 2x 6 pin to 8 pin in the package? that would be 150W combined + 75W another 6 pin connector + 75W from the PCI-E slot = 300W . Then O/C should be a breeze
Someone correct me if I am wrong, thanks
512MB is jsut too small ... i am waiting for HD2950XTX ... AMD better put up a good fight or better yet destroy nvidia so i can have HD2950 CF + X38
also from what i heard 8pin has 100W rating ... so 100W 8pin + 75W 6pin + 75W PCI-E = 250W total ... 2 x 6p will give u 225W ... should be enough to run at stock , but for ocing .... especially if ATI tool allows VGPU adjust
btw Denny over at 3d section has the card ... and did a wonderfull testing ... unbias
Has this already been posted?
Second R600 peview of it-review. :)
http://it-review.net/index.php?optio...1325&Itemid=91
Let us hope those numbers are not accurate.
IQ is better on ATI, at least they said something good!
