Originally Posted by Teratism
Okay the 2 letters are fine and no one needs to worry. The raid device causes the unknown pci device, disabling it got rid of the annoying pop up. I installed my HD's with no raid drivers or floppy and all went well so that should be cleared up about needing a floppy.
e6600, supertalent ddr2800 4-4-3-8, winxp home 32 bit, corsair hx620, BX2, x-fi gamerxtreme, sapphire radeon x1900gt, 2 7200.10 320 seagate HDs, lite-on sata 16x dvd/rw drive, running a scythe infinity on it and all temps programs refer to it being mid to high 30's and low to mid 40's.
My board is not overclocked at all, I was having these bsods on both the 2333 bios and the 2395 bios. The ram timings at both 5-5-5-15 and 4-4-3-8, set them to their supposed voltage of 2.2v, put on power slope, shut off eist, stopped the raid and firewire, I don't see this C1E people talk about or a maintenance part of bios.
I ran memtest+ for 11 hours on default settings in memtest and it went through 24 passes 0 errors. If I run the bios all instead of STD then I get millions of errors, if I run probe I sometimes get my system to reboot itself and the screen not to be picked up by the system.
