Sry, but this is ugly as hell:rolleyes:
No cable management, tubing at the edge of bending...
guys... some people can't afford expensive fancy looking setups. It doesn't have to be pretty all the time, sometimes function > form you know. He's getting load of 50C with an OC at 4GHz so ease up :rolleyes:
ha poor guy , i think it looks alright
No need to flame because his system doesnt meet your standards.
But on that note, being a gallery, people like to look at systems where alot of effort has
been applied, but a little cable management wouldn't go a stray InsaneOne.
Your temps are good though.
http://img201.imageshack.us/img201/8...2008010pt6.jpg
http://img210.imageshack.us/img210/7...2008012wn8.jpg
http://img210.imageshack.us/img210/2...2008016pu4.jpg
http://img408.imageshack.us/img408/1...2008018nr7.jpg
http://img211.imageshack.us/img211/3...2008037vm0.jpg
http://img337.imageshack.us/img337/2...2008039wn2.jpg
http://img185.imageshack.us/img185/3...2008046jo5.jpg
http://img185.imageshack.us/img185/5...2008047as1.jpg
http://img207.imageshack.us/img207/3650/newpc002io3.jpg
http://img201.imageshack.us/img201/6627/newpc005xj0.jpg
In before, "Laff it's a kit!"
It looks alright though. I like your case.
I bought this kit because i used it in a customers computer and it works great.
It installs easy... fits outside the case perfect and looks cool :)
Im only keeping this setup for a little bit anyways... im selling it on ebay or in my computer shop soon :) I just like building them and selling them lol. I think im leaving AMD for the first time EVER... ive never built an intel but im not getting any satisfaction from AMD and they will slowly burn in hell if things dont get better :)
im at 2.8 and its only 35c
not too bad :)
Nice setup unkn0wnhacka.
Regarding the earlier posts, this thread does not need negative feedback but rather constructive feedback. If you don't think it doesn't look that great, why not give some tips. It doesn't hurt putting out suggestions.
At 50C on load, the temps are not at its best but at least it isn't that bad.
below are some pictures of my 2nd Rocket Fish case .... :woot::woot::
http://img91.imageshack.us/img91/7633/50355480fv1.jpg
http://img91.imageshack.us/img91/6923/79588137lf9.jpg
http://img91.imageshack.us/img91/1834/18024260sx6.jpg
http://img91.imageshack.us/img91/1519/11006052pc5.jpg
http://img91.imageshack.us/img91/5508/82878186nd8.jpg
http://img91.imageshack.us/img91/6910/77699975kj5.jpg
Note: Pictures were taken just after I finished put everything into case. As you can see, the RAMs were not there ... :D ... All were done after 3 beers .... :toast2::toast2:
Cloudy tubing is cloudy. Also, love the levitating pump - am I right in thinking it's being held up by the tubing?
I like the uneven rheobuses the most :p:
Everything was moved from old (mid tower) case .... and was used as is ... :D :D ... Actually, ClearFlex tube seems to get cloudy so fast ...maybe tubes are exposed to light too much (while in old case, I had the side panel wide open)? Any way to clean them without taking them apart?
Hahaha ... it cannot avoid ... since it was made around mid night ... and after few beers .... :D :D
Can't really make cloudy tubing clear again. :(
I found a loophole. Don't use clear tubing and it can never get cloudy!!!!
http://img520.imageshack.us/img520/6...56745c9pe3.jpg
Solid black Tygon tubes are nice :D. Forgot what the product number is :shrug:
R3400
Ahh yes, that's right. Good stuff :up:
Also A-60-G
AKA Norprene.
http://www.petrastechshop.com/1id3odtyanot.html
