cosmos for sure! only question is whether is it S or plain.
cosmos s.... sorry... i thought the triple fans up top would have given it away... ;)
Maaja if you spun your rad around so the hose barbs were at the back of the case you could have much shorter tubes.
Ahhh! I love the smell of freshly completed WC Rigs in the morning! :D
this is my Gaming watercooled PC...later post more details ..and i ve got whole instalation guide in images...post later too...
http://i289.photobucket.com/albums/l...DSC06976-1.jpg
http://i289.photobucket.com/albums/l...K/DSC06976.jpg
http://i289.photobucket.com/albums/l...K/DSC06962.jpg
is striker II formula E8400 , 4 Gb ram 150gb raptor i ll post more details and whole instalation guide on friday...many thanks..
http://i289.photobucket.com/albums/l...K/DSC06981.jpg
Great setup, the Blue looks great. where is the GPU ?? :rolleyes:
rig is still in progress, but here's a lil preview:
http://sargatanas.gwebspace.de/PC/umbau/mbkammer.jpg
sargatanas try connect tubing same like Malik here :
http://galeria.shackit.pl/Malik/6/sl...scf1930ky3.jpg
@sargatanas - Awesome build. Can you post some more pics?
well im fine with the tubing.
loop 1: swiftech res - d5 - black ice 360 gtx (with 6 scythe slipstream) - d-tek
loop 2: swiftech res - d5 - mo-ra2 pro (with 9 scythe slipstream) - nb - 2x mosfet - 2x 9800gx2 - sb.
isn't that easy to change the order of the tube since the sb is covered by the 2 9800gx2 and i needed to put in both 9800gx2 cards at the same time since they are connected.
now, the temps are much better on the gx2 cards. idle ~31-33°c (stock ~60°c), load ~38-40°c (stock 73°c) during gaming a few hours crysis.
well the nb temp...don't know, 38°c seems still hot for wc. on the other hand the nb has much to do with 4 gpu cores and 4 mem stick.
gonna post some more pic later on.
well i'm a bit tired now since i had a lil wisdom tooth operation this morning. after that, i had to finish the wc so i mounted the coolers and tubes.
Maaja do you have any other fans on your rad other than the Antec BigBoy located at the top?
I dont see any other top holes in the case for venting. How are your temps?
Im curious because I have an Antec 900 that I have been pondering water cooling with keeping everything internal and trying to figure it all out.
Thanks!
if you wanna see more images of my gaming rig check
http://www.xtremesystems.org/forums/...=1#post2989292
nice work unseen! I do like the look of the Feser UV Blue!!
Unseen, that is an awesome shade of blue, what dye is that?
ARNI:
As Peebee already said: please remove the hotlink (a direct link to a source on someone elses website) of the photo to www.million-dollar-pc.com
Save the photo on your desktop and then you can upload it to an image hoster of your choice. :)
ok done btw now in mine galery ::D
Thanks a lot Arni - greetings to Poland :)
http://www.abload.de/img/mdpc-343-disassemble84v.jpg
Thx ;) btw new case :D
http://images25.fotosik.pl/211/d3198755bb2d2a7cmed.jpg
http://images33.fotosik.pl/247/d6ef76467b06d116med.jpg
http://images28.fotosik.pl/210/f2abe1418861e59emed.jpg
http://images34.fotosik.pl/246/907d04c4e06dfc43med.jpg
http://images31.fotosik.pl/246/cdea79123d4e4702med.jpg
http://images27.fotosik.pl/209/24f942459794441fmed.jpg
http://images33.fotosik.pl/246/76f9c7cfe25d981amed.jpg
http://images24.fotosik.pl/210/04e2c0c996543df9med.jpg
:sick: config :(
Pretty much done with my new build, i just wish i could use my camera to its potential :mad:
http://img.photobucket.com/albums/v3...sj/lianli1.jpg
http://img.photobucket.com/albums/v3...sj/lianli4.jpg
http://img.photobucket.com/albums/v3...sj/lianli3.jpg
http://img.photobucket.com/albums/v3...sj/lianli2.jpg
very tidy mate
very nice work on that window!!!
