Originally Posted by agenda2005
Tim,
The version 9 of the intel compiler also allow optimization for AMD 64 as well. I'm not sure if their's new version of the compiler that have compilation flags for Macro op fusion that allows an extra instruction issue.
The 128-bit SSE on Conroe will obviously benefit more than AMD 64 because two 64-bit SSE(x) intructions will now require one cycle unlike two in Presscott and Athlon 64. This is nobody's fault since Intel have concentrated more effort on making better CPU than crippling competitors performance on their compiler.
You guys should be able to get a Conroe sample from Intel if you ask. Just write a request and give your website link as well as other link to websites using your benchmark.
In the meantime, You can make an SSE/SSE2/SSE3 compiled binary for Victor to install Windows Server 2003 to test the power of Conroe. It will sure be interesting to see how that bad boy will do.
Conroe/Woodcrest will surely be the new king for Molecular Dynamic Simulation developers. This will also reflect well on their SPEC results.
