Get one of those PCI cards that switches the power to the cooling, don't remember the name of them. Somebody help me.Quote:
nice to hear ,im waiting a new update from my suplier :DQuote:
AOpen's & ASUS's Yonah motherboards will be available within 2days, finally!!!
same here in europe, our suppliers told us that mobos should show up tomorrow in their stocks :)
Yonah - OK
IHS on Yonah - OK
Cascades - Checked and OK
New evap mounting - Working on
Mobos - ??
:D
ok, got my laptop (T2400) and did a single test : PI
about 31", results later.
going to install the T2600 later on, after I played with it ;)
any working overclocktools maybe ?
very thanks! 大箸、Mats:banana:Quote:
Originally Posted by kyosen
hicookie - great work here :toast:
yes please :D, here in Europe, we really hope to se the board next week.Quote:
okay trying to find stock status at ingram micro now... ill update you when i get the email back.
Getting excited again.
Ooops, overlooked CAL930's modPI 8M result with his QHJJ T2600 ES:
modPI 1.5 XS 8M: 4m02.313s
CPU:T2600ES
Vcore:1.365V
Vdimm:2.45V
MB:MSI 945GT with kyosen's Vcore & Vdimm Mod
MEMORY:CORSAIR 5400C4 V5.2 CL3-2-2-4
FSB:218.3MHz(5:8)
COOLING:XP-90C + Delta x 2
OS:WinXPsp1
http://cal930.sakura.ne.jp/cgi-bin/c...600es_4_02.PNG
hicookie, I've just ordered a step8 :)
Thx for the advise, I'll write difference on my 2 CPU's once mobo's here.. :)
Gonna test it with Heatkiller rev.2.5 + 10 deg water (dont wanna insulate when changing CPU during test sesson)
- Afterwards I'll give the best a shot on a mach II, (tuesday or wedensday all this will happen)...
Wedensday / Thursday LN2 action will happen UNLESS my mem sucks, then I'll order a pair of G.Skill 2GBHZ (PC6400), they should do about the same as SuperTalent :)
M.Beier> my board has boot coldbug at-50c:rolleyes:
find some issues,945GT can set 3224,
aopen set it 3224 in bios,but cpuz shows 3228,
3224→3228
3225→3229:slapass:
my mainboards,:banana:
http://home.arcor.de/16vbogi/dothan/IMGP7301.JPG
Hmm, holy :banana::banana::banana::banana:...Quote:
Originally Posted by hicookie
That makes Mach II ultimate for cooling :S - BUT I WANT LN2 ACTION ::mad:
hope ECS wont have that issue...
Bogi>woa! u got two pics,and many..many...yonahs
ecs will delay 10/may....;)Quote:
hmm to bad you cant try to get with a higher temprature into windows and then go sub -40 or so.. mayb the board has a terrible cold boot
@ bogi :D
Fire it up :D
:toast:
i have very much yonahs for tests, gg
http://home.arcor.de/16vbogi/dothan/...0start%203.jpg
omg, that's plain sick :D, and you're testing one? Cause I see an empty space!
wtf, now for AMD we have coldbugging cpu's and no-coldbugging mobos, while for Intel - vice versa? :slapass:Quote:
Well, we just need Hipro5 to fix some kind'a mod :PQuote:
Can you explain more? Board doesn't boot at all if temp is already below -50C? Can you power on with higher temps and then lower temps below -50C already in windows, does it still bug then?
i think it will be just on POST.Quote:
It is hte known ''cold boot'' problem.....
Sometimes it can be solved giving more Vcore at startup....
But moved by 120 deg C?Quote:
Originally Posted by GoriLLakoS
