i got an antec 550W 24pin true psu. i got 2 evga 6600gt, 2x 12mm fans, and g.skill 2x512MB rams. i hope my system is not underpower :).
I think what's really important is how many amps the rails are supplying, particularly the +12V rail.
Yeah, hopefully absolute0 will take my old fully modded antec550 EPS off my hands. It's a nice psu with a nice 12v rail @ 36A. Hehehe, but nothing (well almost nothing besides the PCP&C 850) can touch a Zippy 700W's 12v rail @ 45A, but even better - how about a modded Zippy 700W's 12v rail? :cool: :Quote:
Originally Posted by dng29
http://img255.echo.cx/img255/5131/zippy12v2mz.jpg
Speaking of the Devil. :devil: I'll try to get you some info tonight ;)Quote:
how much is a zippy 700w? wow 45amp on the 12v rail, that's alot of juice :). this antec 550w eps is expensive though :(.
If you think that the antec is expensive, don't bother following the link....(Hint: It's probably 3x the antec) ;)Quote:
yea i did a froogle search and it showed the newegg link and i nearly fainted :). in the long run, it's worth it though. need to start saving now to be able to afford it :).
Hey guys, noob here, I bought from the AMD Tech Tour the desktop bundle and I got a Venice 3200+ 0519CPIW @ 2.6 1.425V. I'm running some stress tests right now I'll let you know how it goes. Look at my sig for more info.
Finally got it working. My rig running Prime95 as we speak with the following
270x10 = 2.7 @ 1.48V (47C while priming)
2.5-3-3-7 1T @ 225MHz @ 2.7V 5:6
The divider helped a lot because now I can run 1T and I can go to 2.7 without problems. Only thing is that from 2.6 and on the CPU demands more and more power. I'm going to prime it 24hrs and then I'll post.
2.7 Ghz with 1.48 volts looks like one of the better week 19s by a long shot!
Yeah it's been 3 hours of priming and no errors. I'm really happy. Too bad I can't push it to 2.8GHz but I guess I'll have to stop the need for more OCability
Originally Posted by Xchus
vcore at 1.48 is awesome at 2700Mhz. i have to run my 3200 venice week 19 at vcore of 1.7 for stability :(. week 19 will definitely not hit 2800Mhz no matter what.
my current 3000+ can do 2.72 ghz with 1.42 volts
3200+ in sig does 2.75 with 1.475 as advertised
other 3000+ blows and isn't stable at 2.7 Ghz period.
While we're talking 2.7 Ghz, my APAW fairs best, 2.7 Ghz is fully stable at default volts.
I was gonna say that 2.7GHz @ 1.48v aint that great...but for a week 19...yeah...not bad. :)Quote:
9x300 @ 1.376v prime stable for 15 hours :woot:
Whoever doesn't believe in burn in should see this CPU. Last week it wasn't prime stable @ 1.424v so I had to raise it to 1.440. A couple of days ago 1.376v didn't work for more than 30 minutes.
Edit: http://web.telia.com/~u18411604/2700.png
I just got my hands on a 0517APAW. So far I have managed to post at 2.9GHz+ and I can get into windows and prime at 2.85GHz. Will have more screenies later. BTW this is all on stock HS and fan. Will be getting an XP-90 soon to go on it.
But I have a suggestion, if you could sort the OC DB list, it would make it easier for people to find what they are looking for. So to make life easier for the thread starter, I have done the sorting:
3000+:
3000+ CBBLE 0504DPAW - 2800 MHZ 1.616V AIR - Gorod XS
3000+ CBBLE 0504DPAW - 3000 MHZ 1.648V PC - Gorod XS
3000+ CBBLE 0512DPAW - 2700 MHZ 1.360V AIR - =STE=BloodAngel XS
3000+ CBBLE 0512DPAW - 2800 MHZ 1.520V AIR - =STE=BloodAngel XS
3000+ CBBLE 0512DPAW - 2857 MHZ 1.632V AIR - DesertShooter XS - Zalman 7700CU , stable ?
3000+ CBBLE 0512DPAW - 2880 MHZ 1.520V AIR - vrtn XS - XP120 + FAN , SuperPI 16M Stable
3000+ CBBLE 0512DPAW - 2902 MHZ 1.500V AIR - SmokeyTheBandit XS
3000+ CBBLE 0512DPBW - 2826 MHZ 1.500V H2O - xpr-k XS
3000+ CBBLE 0512DPBW - 2901 MHZ 1.680V H2O - mongoled XS
3000+ CBBLE 0512DPBW - 2916 MHZ 1.664V H2O - Jimbo Mahoney XS
3000+ CBBLE 0512DPBW - 2922 MHZ 1.580V AIR - Torman XS - stock cooler
3000+ LBBLE 0512FPDW - 2700 MHZ 1.480V ??? - SillySider03 - prime stable
3000+ LBBLE 0515FPDW - 2845 MHZ 1.530V AIR - sinsinking XS - Hyper6
3000+ LBBLE 0515FPMW - 2808 MHZ 1.600V AIR - askimo XS
3000+ LBBLE 0516CPBW - 2450 MHZ 1.520V AIR - Geforce4ti4200 XS - 2500 NOT STABLE
3000+ LBBLE 0516CPBW - 2475 MHZ 1.472V AIR - JDizzle Ocforums
3000+ LBBLE 0516CPBW - 2600 MHZ 1.632V H20 - bmaffin13 XS - 12+ Hours prime stable
3000+ LBBLE 0516CPBW - 2610 MHZ 1.488V AIR - shiznit93 XS
3000+ LBBLE 0516CPBW - 2610 MHZ 1.568V AIR - patrck17 Ocforums
3000+ LBBLE 0516CPBW - 2630 MHZ 1.536V AIR - Skratch XS - stock cooler
3000+ LBBLE 0516CPBW - 2700 MHZ 1.400V H2O - Craptacualr Ocforums
3000+ LBBLE 0516CPBW - 2700 MHZ 1.488V AIR - stang8118 Ocforums
3000+ LBBLE 0516CPBW - 2700 MHZ 1.552V H2O - ociadotnet XS
3000+ LBBLE 0516CPBW - 2700 MHZ 1.664V AIR - HousERaT XS
3000+ LBBLE 0516CPBW - 2700 MHZ 1.750V AIR - clockedOut XS - NOT STABLE
3000+ LBBLE 0516CPBW - 2765 MHZ 1.648V AIR - TheMeatFrog XS
3000+ LBBLE 0516CPBW - 2765 MHZ 1.744V AIR - trans am XS
3000+ LBBLE 0516CPBW - 2808 MHZ 1.664V AIR - stang8118 Ocforums
3000+ LBBLE 0516CPCW - 2600 MHZ 1.550V AIR - Vroom - from Trend4PC.de XS
3000+ LBBLE 0516CPCW - 2610 MHZ 1.650V AIR - KamE38 XS - stock cooler stable
3000+ LBBLE 0516DPJW - 2800 MHZ 1.568V AIR - UCmajewski XS - stock cooler
3000+ LBBLE 0516DPMW - 2627 MHZ 1.536V ???? - zwierzak24dg TWEAK.PL
3000+ LBBLE 0516DPMW - 2712 MHZ 1.536V H2O - zwierzak24dg TWEAK.PL
3000+ LBBLE 0516DPMW - 2745 MHZ 1.550V AIR - VerB TWEAK.PL
3000+ LBBLE 0516DPMW - 2844 MHZ 1.648V H2O - Mardok TWEAK.PL
3000+ LBBLE 0516EPAW - 2700 MHZ 1.552V AIR - SDX XS - XP120 + FAN , prime stable
3000+ LBBLE 0516EPBW - 2160 MHZ 1.400V AIR - PURE TWEAK.PL - EXTREME BAD
3000+ LBBLE 0516EPBW - 2806 MHZ 1.600V H2O - Yotomeczek TEAK.PL
3000+ LBBLE 0516EPBW - 2860 MHZ 1.730V H2O - Yotomeczek TEAK.PL
3000+ LBBLE 0516EPHW - 2700 MHZ 1.536V AIR - MassiveOverkill amdforums
3000+ LBBLE 0516EPKW - 2700 MHZ 1.696V AIR - Cornelious0_0 XS
3000+ LBBLE 0516GPAW - 2754 MHZ 1.504V ??? - Trevor XS - prime stable
3000+ LBBLE 0516GPBW - 2808 MHZ 1.552V H2O - arj XS
3000+ LBBLE 0517APIW - 2700 MHZ 1.360V AIR - peter lu XS
3000+ LBBLE 0517APIW - 2800 MHZ 1.440V AIR - peter lu XS
3000+ LBBLE 0517EPAW - 2700 MHZ 1.475V AIR - SoboL XS - FreeZone QC-80 CU - http://www.esc.pl/index.php - prime stable
3000+ LBBLE 0517EPAW - 2781 MHZ 1.480V AIR - Pure tweak.pl - stock cooler , prime stable
3000+ LBBLE 0517EPAW - 2925 MHZ 1.522V AIR - Vosh tweak.pl - 12 h prime stable , Freezer64 + AS5 , BEST CPU IVE SEEN
3000+ LBBLE 0517EPAW - 2942 MHZ 1.580V H2O - wampir XS - SuperPI 16 M stable
3000+ LBBLE 0517EPAW - 2961 MHZ 1.616V AIR - Vosh tweak.pl - 12 h prime stable , Freezer64 + AS5 , BEST CPU IVE SEEN
3000+ LBBLE 0517EPMW - 2700 MHZ 1.376V AIR - qk4722 XS - prime stable
3200+:
3200+ CBBLE 0504EPAW - 2800 MHZ 1.520V AIR - Kane XS
3200+ LBBLE 0515APAW - 2700 MHZ 1.360V ??? - jinu117 XS - prime stable
3200+ LBBLE 0515APAW - 2800 MHZ 1.400V AIR - Burnt_Ram XS - SuperPI 32M , XP-90 + FAN
3200+ LBBLE 0515APAW - 2800 MHZ 1.408V AIR - D3kMatrix XS/OCforums - prime stable 8 h
3200+ LBBLE 0515APAW - 2850 MHZ 1.450V AIR - 4rory XS
3200+ LBBLE 0515APAW - 2850 MHZ 1.520V AIR - D3kMatrix XS/OCforums - prime stable 24 h
3200+ LBBLE 0515APAW - 2900 MHZ 1.408V H2O - musk XS
3200+ LBBLE 0515APAW - 2906 MHZ 1.550V AIR - s7e9h3n XS , SuperPI 32M stable
3200+ LBBLE 0515APAW - 2950 MHZ 1.500V H2O - JfRsQ XS - stable ??? , Bought from NCIX Computers, Canada
3200+ LBBLE 0515EPGW - 2800 MHZ 1.504V ??? - daddy_fizz XS - prime stable 2h
3200+ LBBLE 0515FPBW - 2700 MHZ 1.408V AIR - Techwarrior XS - 24 h prime stable , XP-90 + FAN
3200+ LBBLE 0515FPBW - 27500 MHZ 1.450V ??? - oasked XS
3200+ LBBLE 0515FPBW - 2800 MHZ 1.552V AIR - Techwarrior XS - 24 h prime stable , XP-90 + FAN
3200+ LBBLE 0515GPBW - 2700 MHZ 1.328V ??? - leotonch XS - prime stable
3200+ LBBLE 0515GPBW - 2700 MHZ 1.450V AIR - bonzer XS
3200+ LBBLE 0515GPBW - 2800 MHZ 1.392V H2O - H2OGun XS
3200+ LBBLE 0515GPBW - 2929 MHZ 1.664V AIR - PcCI2iminal XS
3200+ LBBLE 0515GPBW - 3000 MHZ 1.600V H2O - H2OGun XS
3200+ LBBLE 0516?????? - 2800 MHZ 1.680V H2O - Badge56 XS
3200+ LBBLE 0516EPEW - 2650 MHZ 1.584V AIR - dnottis XS
3200+ LBBLE 0516EPEW - 2700 MHZ 1.700V AIR - Deus Falsus XS
3200+ LBBLE 0516EPEW - 2800 MHZ 1.616V AIR - vapb400 XS
3200+ LBBLE 0516EPGW - 2500 MHZ 1.550V AIR - Dermen Ocforums
3200+ LBBLE 0516EPGW - 2670 MHZ 1.700V AIR - Deus Falsus amdforums
3200+ LBBLE 0516EPGW - 2670 MHZ 1.700V AIR - Deus Falsus XS
3200+ LBBLE 0516EPGW - 2700 MHZ 1.456V AIR - Ziku TWEAK.PL
3200+ LBBLE 0516EPGW - 2700 MHZ 1.504V AIR - 4X4N XS
3200+ LBBLE 0516EPGW - 2700 MHZ 1.568V H2O - aMp XS
3200+ LBBLE 0516EPGW - 2763 MHZ 1.664V AIR - politenessman XS
3200+ LBBLE 0516EPGW - 2800 MHZ 1.696V AIR - Wayway XS
3200+ LBBLE 0516EPGW - 2808 MHZ 1.580V AIR - Rubescen XS
3200+ LBBLE 0516EPGW - 2840 MHZ 1.660V ??? - TheMeatFrog XS
3200+ LBBLE 0517APHW - 2850 MHZ 1.520V AIR - PITer TWEAK.PL
3200+ LBBLE 0517BPDW - 3201 MHZ 1.608V DICE - Dj_Rudy XS - stable ??
3200+ LBBLE 0517BPEW - 2800 MHZ 1.560V AIR - KamE38 XS - stock cooler stable
3200+ LBBLE 0517BPEW - 2845 MHZ 1.376V H2O - Fintas-XP XS
3200+ LBBLE 0518APDW - 2853 MHZ 1.696V H2O - htkm1 XS
3500+:
3500+ CBBLE 0504EPAW - 3003 MHZ 1.480V PC - TodB XS
3500+ CBBLE 0512DPAW - 2750 MHZ 1.660V AIR - mcbarnet007 XS
3500+ CBBLE 0512DPAW - 2840 MHZ 1.456V PC - Onepagebook XS
3500+ CBBLE 0515?????? - 2705 MHZ 1.552V AIR - Rickster_64 XS
3500+ LBBLE 0515FPAW - 2750 MHZ 1.440V AIR - Tibu XS
3500+ LBBLE 0515FPAW - 2850 MHZ 1.648V AIR - Joe Camel XS
3500+ LBBLE 0515FPAW - 2900 MHZ 1.648V AIR - Tibu XS
3500+ LBBLE 0515FPBW - 2972 MHZ 1.648V AIR - charlie XS - Hyper6 , bought from monarch
3500+ LBBLE 0516CPAW - 2754 MHZ 1.616V AIR - Dani XS - stock cooler
3500+ LBBLE 0516DPMW - 2700 MHz 1.550V H2O - Sillen XS
3800+:
3800+ CBBLE 0504EPMW - 3306 MHZ 1.664V PC - s7e9h3n , Mach2
3800+ CBBLE 0507DPAW - 2906 MHZ 1.360V PC - Cranox XS
3800+ CBBLE 0513CPBW - 2750 MHZ 1.500V AIR - Seriola XS - stock cooler - prime stable 5h
3800+ CBBLE 0513CPDW - 2700 MHZ 1.360V PC - spiritedandy Ocforums
3800+ CBBLE 0513CPDW - 2929 MHZ 1.650V H2O - xxmartin XS
3800+ CBBLE 0513CPDW - 2950 MHZ 1.664V ??? - kamui XS
3800+ LBBLE 0515GPAW - 2856 MHZ 1.488V H2O - Jaco XS - 14h prime stable
3800+ LBBLE 0516CPCW - 2751 MHZ 1.460V H2O - Computersmsa Bel-Hardware.be
BTW I didn't do this by hand!
Exscape, that is terrific news! I'm glad you chip burned in so well, and i hope mine can burn in that much. I have high expectations for mine.Quote:
Originally Posted by exscape
Ahmad, thanks for organizing the database. I think it could use an update; it's been a month since the last update! But i can't blame sobol for not wanting to update; there is TOO much stuff to update, it would take forever.
what do you guys use for burn in? i've been using folding to burn in my cpu. prime doesn't work for me at all.
Sorry that i dont update the list. Unfortunly im in holiday work for 3 months. And for now i dont have net in my living place. As soon i get plugged in the web ill update it. Btw guys seems 0517 and 0515 are only good weeks.
Greetz
Looks like its the mobo thats holding me back :mad: try as I may in or out off sync can only only get 2500 stable unless I set the mem to 100Quote:
Originally Posted by ahmad
yet mem stable 275Htt 1:1 and CPU 2700 11hrs+ stble when mem at 100
It can still be the CPU.Quote:
Originally Posted by Zeus...
My prev. CPU could do 2600 (9x289) @ 1.46v with mem @ 240MHz... BUT, if I ran it at 7x370 (mem @ 1/2 = ~185), it could do the same speed at 1.33v...
My new CPU (same stepping, lower batch number) does 2700 @ 1.39v with memory >200 though.
Edit: Oh, and I use prime95 for burning in. Actually I use it for stability testing but it seems to do wonders for the CPU anyway :)
well heres my submission
2500 stable and prime 24hrs (scroll to bottom)
suicide run 2800MHz 1:1
Suicide run 2900MHz out off sync
My DFI dead :mad:
http://wowgame.free.fr/Divers/DFI%20...DSCF0945-2.JPG
http://wowgame.free.fr/Divers/DFI%20...DSCF0955-2.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0937.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0938.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0939.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0940.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0941.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0942.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0943.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0944.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0945.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0946.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0947.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0948.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0949.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0950.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0951.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0952.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0953.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0954.JPG
http://wowgame.free.fr/Divers/DFI%20...9/DSCF0955.JPG
wat the hell did u do to ur board?? =.= omg
No joke.... geez.... seems a little harsh.
