3700+ SD
KACAE 0602 GPMW
http://img204.imageshack.us/img204/5945/30005lr.jpg
Out of the box, cpu is like 10 mins old now. Running prime at the moment :cool:
3700+ SD
KACAE 0602 GPMW
God damn thats nice :)
http://valid.x86-secret.com/show_oc?id=85723
Prime stable for 2 hrs so far . . . Now it's time to buy some TCCD mem (10 x 300 1:1 = sweet :cool:)
Anyone knows how KAB2E 0548EPAW performs thru air cooling? :D
It should be good :) Test it out
hey all star is that 1.3 voltage true. I am at 2904 (12*242) My voltage is @ 1.6125 and I can not go much high in the fsb. I have oc'ed to 3000 but I can not go 5 minutes in prime no mater how high I set my voltage. I hope it works for u. I am so j.
I am at 1,408 vcore, 1,4 in bios, so mobo is overvolting a bit. What's your stepping?Quote:
Originally Posted by captses
I am new to oc'ing so you must bear with me. I am not sure what stepping is except that perhaps someone wants to scrap. My cpu has on it from top to bottom this:
AMD ATHLON 64
ADA4000DAA5BN
KACAE 0544EPAW
1353107 K50612
I hope that helps.
What cooling are ya?Quote:
Originally Posted by All_Star
How it goes with higher vcore?
It is a 0549MPMW
http://www.zwiebelweb.de/testing/sd3700.jpg
Cooling: Thermaltake Big TyphoonQuote:
Originally Posted by Spyrus
Haven't testes with higher vcore so far.
very good. :toast: my 3700+ has the same stepping ( KACAE 0552 FPDW ) :)
first try: 273x11=3003@1.52V@boxed cooler.
unfortunately this stepping has a coldbug under my vapo ls :(
c u
ok, I'll ask. Is this a new one?
no , it's the same cpu :DQuote:
Originally Posted by coop
i wanted to try what it does with lower voltage :stick:
Temp is pretty high? :confused:Quote:
Originally Posted by starostise
ADA3700DAA5BN
KACAE 0602 GPMW
XXXXXXXX60241
3000mhz / 1,392 vcore
Screen:
http://img159.imageshack.us/img159/1829/30001394jo.jpg
that's true, i'm aircooled by freezer 64 pro with 22-23°C ambiant temp :)Quote:
What are your Ram running?Quote:
are you using a divider. if you are, wich??
2/3 divider = 200mhz :)Quote:
Originally Posted by mikael999
I did something very good before running StressCPU 1M @3306MHz... but what's the hell was it? I've failed to do it again @3316MHz and unfortunately lost 2 1/2 mins... :rolleyes:
http://www.beforeoverclock.com/image...CPU1M@3316.jpg
http://www.beforeoverclock.com/image...CPU1M@3306.jpg
Hey all
My first attempt at OC'ing my 3700, got it at 2.86GHz @1.5V prime stable, running an Asus A8R32-MVP deluxe. Started running into some stability and boot issues if I went much higher. Cooling with a Zalman CNPS9500 with the fan adjusted by my mainboard's Q-Fan, so if the temps get any higher than 47 C it'll kick the fan into high gear. O yes and arctic silver II - stupid me forgot to order AS5 when I bought the other stuff :slap: Ambient room temp is about 25 degrees C.
I don't know what is good since I'm fairly new to OC'ing. My 1st OC I did was a pentium 1 100MHz to 133MHz, oo goody :p:
high resolution pic
My memory apparently doesn't like higher speeds, had it up to 224 and it wouldn't take it :( timings 2.5-3-3-6
Besides the AS5, anything else I should mess with to try and squeeze more speed out? Like, would bumping the voltage up to 1.55 stabilize it? I'm just afraid if messing with voltages too much.
Cheers :toast:
very nice, but those rams you got there, they're amazing :banana: :banana: :banana:
Spi32M improved! :D
http://img192.imageshack.us/img192/2...32m21m54s0.jpg
@Hystrix^: These RAM modules are awesome; Spi1M @283MHz
http://www.beforeoverclock.com/image...26s%5b7%5d.jpg
