I need BS Help, little different to other types!
Hi,
Hi, I purchased an XFX GF 6800 128MB DDR DUAL DVI TV (AGP8X) with product code : PV-T40K-NDD3 secondhand from ebay, but have ended up looking at this website.
The problems are, no matter what driver I use, After I install a driver, When I boot, just as it gets to the windows login screen the screen goes black, monitor hits standby, But when I reboot , then press f8 then choose "enable vga mode" it will work (in software mode) only when any driver is installed this black screen will occur.
I see a few posts above "lenselijer" is having a similar problem to me!
soldered the purple capacitors back and i had screen again, but when it tries to boot windows xp it goes black, and its not the drivers or rivatuner, because my ti4200 works fine when i put that in the same computer. this was at stock frequency.
I have tried the card in another PC and still has same problem. I initially thought as im using dvi > vga adapters this may have caused it, but i see the BS issue seems common and obviously some design fault.
Seems to be using SVP 560 caps marked 502, svp, 560, 10 for C136, C142 & C143
47, 470, 16a for c141,
443, svp, 1500, 2.5 for c138 & c146
504, svp, 330, 16 for both c139 & c148
Anyone have any idea whats wrong?
What do you think has gone?
any help appreciated!
