I submitted my RMA form with CC information about 2 weeks ago and I still don't have any news on my RMA status.
Does anybody knows what that connector is for?
http://i82.photobucket.com/albums/j2...2600K/ws13.jpg
Hi Bullu$ , thats for extra power when running crossfire or SLI , its a normal molex connector.
@unrealer: thx.. :) posted the screeni at the linx 5,+ghz thread
@asmola: will give u a screen tomorrow.. but did u use the right prime vers for SB ?
I received today my P8P67 Deluxe B3 (1305 bios) and i have a strange issue installing nvidia drivers 266.58 that never seen on my replaced P8P67 Deluxe.
Made a fresh W7 64bit installation and motherboard drivers every is fine until the installation of nvidia drivers, after reboot i can't get to the desktop and have instant reboot. I only can get to the desktop with windows safe mode or uninstalling nvidia drivers.
Is this a known issue?!..... :confused:
Can I run sli in the 1st and 3rd pci-e slots? Doesn't seem to work P8P67 deluxe
also using 266.58.. no problems on the pro
Wich voltage/setting do I need to raise for more stability with tripple cfx?
Cause each card (single test) can reach >1GHz core but in tripple cfx it's not working yet.Using 2 power suplies(1000W+750W)
NEW BIOS for P8P67 (1401) - P8P67-Deluxe (1502) - P8P67-Evo (1502) - P8P67-Pro (1502) Download links here: http://hwbot.org/forum/showpost.php?...&postcount=379 Thanks to Massman at Hwbot for the heads up :up:
Try to raise IOH (North Bridge) and (South Bridge) , very important PCIexpress voltage.
Also disable everything that you are not using while benching in the Bios, example: disable Lan , Realtek onboard sound , USB-3 and Sata 3 , 1234 firewire port etc.. , sorry i cannot remember all my settings from my P8P67-Deluxe. Good Luck.
Thanks Massman.:D
http://hwbot.org/forum/showthread.ph...870#post101870
Why cant they update support for Hyper-chip memory's?? Well, im going to get MIVE anyway..
@Asmola: :up:
Well, my week-old B3 Deluxe broke last night, dammit. I lost the PCIe x16_1 slot (top VGA slot).
I was getting a brief chirp the last few days whenever I'd power on the system or shut it down and it gave up the ghost last night.
I swapped vid cards and I get no action on that first PCIe slot - the second one works fine, although I still get a brief chirp. All power connections were/are fine.
If I have a card occupying that first slot, the VGA LED lights up red and I get no display.
Any idea what could've caused this?
Rig in Sig (top one)
thx mate ;) mine needs a tic more vcore for blend than linx. currently testing linx @5,2ghz :cool:
:edit and done : :cool:
Hi, how to change multiplier in windows? I use 2500k
BIOS 1502 changes:
1. fix the CPU/turbo ratio is wrong after clear CMOS
2. fix mouse cursor may be drift if there is a joystick plug in
3. fix that xhci legacy support function fail if there is another PCIE usb3.0 addon card on the system
4. Improve TPU's algorithm to bring better performance on some CPUs.
source
Im going to try this new Bios 1502 for my P8P67-Deluxe and will post findings later , cpu is a 2600k
