Looks like you're having fun doing that. Enjoy!
We here at Xtremesystems, Like to keep it extreme :D that's why i joined here in the first place.
CPU Model: AMD Phenom II X6 1100T BE
CPU Stepping: CCBBE CB 1045GPMW
CPU Frequency: 4107MHz
CPU vCore: 1.46V
CPU Multiplier: 18.5x
CPU Turbo: Disabled
CPU NB Speed: 2664 MHz
HT Ref Speed: 222 MHz
RAM Speed: DDR2-1184
RAM Timings: 5-5-5-15-2T
RAM Configuration: 2 GB (2 x 1 GB)
RAM vDIMM: 2.16V
Motherboard: Gigabyte GA-MA790X-UD4P
Chipset/Socket: AM2+, 790X + SB750
Cooling: Air (Zalman CNPS10X Performa & 7V Delta FFB1212EH)
Temps: 27C Idle / 50C Load
Operating System: Windows XP Home SP3
32/64-Bit: 32
Stable/Suicide/Untested: 8hr Prime95
Clunkers are cars that don't work so,you can't win the race unless you make it to the finish line.
Sorry, I wasn't meaning to make a racing analogy...I meant junk. "Stuff."
Some of us like to push limits, you like to push absolute stability. Have fun with that.
Testing 24 hours with P95 at max mem is essentially the same as 24 hours of LinX at max memory which is essentially the same as 1000% HCI memtest which is essentially the same as a month of Memtest86. Nobody cares, at least I dont care that you like to excessively stability test. Intstead of running all of those, I suggest you just run one for five days. I test based on what I know I will do with my rig. PCs that go to customers get 18 hours of Prime95 blend, 2 hours LinX and 32M. Unless they will be running WCG, which the probability is less than 1/10000 I dont think they will hold a 100% load for more than the hour they ever encode video with Windows Movie Maker.
Being able to use performance gained is so much sweeter,5ghz 24/7 or 7ghz for 10sec.
Don't down talk stability because you know you have rma'd before.
Charts updated.
You are right, I RMA'ed a $40 kit of ram once because it couldn't run stock. It was obvious by the bsod's I was getting in normal use.
I'm able to use my 4.1 Ghz OC 24/7, and I didnt stability test it, so what does that tell you? Maybe I already know where the wall of stability is on my chip because I know how stability to non stability scales.
I quite enjoyed my 5.2 Ghz on DICE for about 5 hours.
Finally got 1 to play with. May do better with some cooling maintenance.
Benchable cinebench/p95 etc
CPU Model: AMD Phenom II X6 1090T BE
CPU Stepping: sorry impatient when installing :D
CPU Frequency: 3999MHz
CPU vCore: 1.5V
CPU Multiplier: 19x
CPU Turbo: Disabled
CPU NB Speed: 2730 MHz
HT Ref Speed: 210 MHz
RAM Speed: DDR2-1130
RAM Configuration: 8 GB (4 x 2 GB)
RAM vDIMM: 2.3V
Motherboard: Asus M4A79 Deluxe
Chipset/Socket: AM2+, 790FX + SB750
Cooling: Water swiftech storm II
Temps: 30C Idle / 52C Load (needs cleaning)
Operating System: Win 7 64bit pro
Time to go look @ war films and cuss the almighty.:cussing:
Don't complain when rma's get denied.
Well, here is mine. This is what a get so far, Ill try to push it to 3.8/4.0 but need some time
CPU Stepping: CCBBE CB 1031MPMW (Im almost sure....)
CPU Frequency: 3616.4 MHz
CPU vCore: 1.360 V
CPU Multiplier: 18x
CPU Turbo: Disabled
CPU NB Speed: 2812.8MHz (1.35 V)
HT Ref Speed: 200.9 MHz
RAM Speed: DDR3-1600
RAM Timings: 8-8-8-18-1T
RAM Configuration: 4 GB (2 x 2 GB)
RAM vDIMM: 1.7 V
Motherboard: Gigabyte GA-MA790XT-UD5P
Chipset/Socket: AM3, 790FX + SB750
Cooling: Corsair H50 + DeepCool UF120 P/P
Temps: 30C Idle / 55C Load
Operating System: Windows 7
32/64-Bit: 64
Stable/Suicide/Untested: Stable Prime 95 64BIT Blend 8h 9m 0 Errors 0 Warnings
Ill update later.
PD: Sry for my english.... i know its not the best hehe
EDIT:
Im having some problems with the mind blowing 4.0GHz xD. I was testing if the processor can actually work at that frequency, so i put all other values at stock or under stock.
CPU Frequency: 4000 Mhz
CPU vCore: 1.488 V
CPU Multiplier: 20x
CPU Turbo: Disabled
CPU NB Speed: 2000 MHz (stock V)
HT Ref Speed: 200 MHz
RAM Speed: DDR3-1333
RAM Timings: 9-9-9-20-33-2t
RAM vDIMM: 1.7 V
Temps: xC Idle / 65C Load (TMPIN2 in HWMonitor was under 68C)
32/64-Bit: 64
Stable/Suicide/Untested: "Stable" Prime 95 64BIT Blend 8h 0 Errors 0 Warnings
I seted up a Blend test in Prime95 and went to sleep. This morning after 8h the test showed no errors at all (i have the result.txt). But i decided to open BFBC2 while Prime95 was still running (I can use League of Legends at the same time, so i just open it to test a little bit more if it was rock solid). But... supercrash, PC restarted (BSOD, memory dump) and Windows 7 didn't boot (got stuck in the loading animation, it wasn't an infinite loop, the animation just stopped). I said some pretty bad words and go to work... now, after repairing the W7 boot, here am i trying to figure out what the hell is wrong with this.
I thought i was going to have no problems. I mean, isn't 8h of prime enough?? Maybe the PSU??? I have a P&C Silencer 750w.
Here is something new from my 1st LN2 OC.
CPU Stepping: ------
CPU Frequency: 6520.77 MHz
CPU vCore: 1.84V
CPU Multiplier: 31.5x
CPU Turbo: Disabled
CPU NB Speed: 2070.9 MHz
HT Ref Speed: 207.01 MHz
RAM Timings: 9-9-9-24-2T
RAM Configuration: 4 GB (1 x 4 GB)
RAM vDIMM: 1.65V
Motherboard: MSI 990FXA-GD65
Chipset/Socket: AM3+, 990FX + SB950
Cooling: LN2
Temps: -180ºC Idle / -190ºC Load
32/64-Bit: 64
Stable/Suicide/Untested: Untested
I can run SP but not full stability test was done.
http://valid.canardpc.com/cache/screenshot/1901257.png
http://valid.canardpc.com/show_oc.php?id=1901257
Got my 1100t still waiting for the CHVF to arrive and I'll start some OC'ing :D
Charts updated. Sorry for the delay, folks.
As a reminder: Those submitting "stable" results need to show a picture of the result.
Just installed the New CHV and I'm loving it. I gave My 1100t to my brother, let say it's not a very good chip :P
http://valid.canardpc.com/cache/banner/1911341.png
....just got a new 1100T...1122APM....will test by the end of the week...
CPU Model: AMD Phenom II X6 1075T
CPU Stepping: ACBBE CB 1023DPMW / HDT75TFBK6DGR
CPU Frequency: 3750 MHz
CPU vCore: 1.360V
CPU Multiplier: 15x
CPU Turbo: Disabled
CPU NB Speed: 2500 MHz
HT Ref Speed: 250 MHz
RAM Timings: 7-7-7-20-1T
RAM vDIMM: 1.50V
Motherboard: Gigabyte 890GPA-UD3D rev.2.1
Chipset/Socket: AM3, AMD 890GX + AMD SB850
Cooling: h20, ek supreme + ehiem 1048
Temps: 35c Idle / 50-57C Load
32/64-Bit: 64
Stable/Suicide/Untested: Stable, 8h+ OCCT.
sorry for the bad picture, was tired when I woke up. tried for 4ghz but became unstable because off mobo on default/auto/stockvolt. think autosetting is bad, cl7 on cl9 ram is´t good for oc. but hey it works =)Attachment 118692
edit:
stable with 1.28v now =D
http://valid.canardpc.com/show_oc.php?id=2024102
(if I get the time I might validate it)
Updated
Just realised mine isn't on the untested list?
http://www.xtremesystems.org/forums/...=1#post4747224
Working on doing a stable bench...
Oops - forgot to post about this in this thread:
100% stable, been running this for about 2 months! :)
* CPU Model: AMD Phenom II X6 1090T
* CPU Stepping: Sorry forgot to get this! - Purchased April 2010
* CPU Frequency: 4013 MHz
* CPU vCore: 1.435V + LLC (1.48)
* CPU Multiplier: 20x
* CPU NB Speed: 2800 MHz
* HT Link Speed: 200 MHz
* RAM Speed: DDR3-1600
* RAM Timings: 8-9-8-24-1T
* RAM Configuration: 2 x 4Gb
* RAM vDIMM: 1.65V
* Motherboard: Crosshair IV
* Chipset/Socket: 890 AM3
* Cooling: Custom water (DDC + Supreme HF + PA120.3)
* Temps: 36C Idle / 56C Load
* Operating System: Windows 7
* 32/64-Bit: 64
* Stable/Suicide/Untested: Stable
Memory is Mushkin #996987 DDR 3 1866Mhz 9-11-9-27 (1T) @ 1.65v stock rating
http://i1022.photobucket.com/albums/...0MushkinC8.jpg
CPU Stepping: ACBBE CB 1021APMW
CPU Frequency: 4063 MHz
CPU vCore: 1.403v
CPU Multiplier: 13.5x
CPU Turbo: Disabled
CPU NB Speed: 3000 MHz
HT Ref Speed: 2400 MHz
RAM Speed: DDR3-2000 (3:10)
RAM Timings: 7-9-7-24-1T
RAM vDIMM: 1.700V
Motherboard: C4F
Chipset/Socket: AM3, AMD 890FX + AMD SB850
Cooling:EK watercooling
Temps: 36c Idle / 51C Load
32/64-Bit: 64
Stable/Suicide/Untested: Stable ,Prime95
http://valid.canardpc.com/cache/banner/2014372.png
http://img844.imageshack.us/img844/7853/91915789.png
Uploaded with ImageShack.us
