Wanders in, brings big box of popcorn waiting for the fireworks to start..:D
New Chapter | H20 & LIQUID ONLY | Preparation
Read Carefully | 1 Photo | 3 ScreenShots | H20 ONLY
Photo 1 - Rig | ScreenShot 1 - Best H20 Result 3D 06 Valid | ScreenShot 2 - Best H20 Heaven Result | ScreenShot 3 - Best H20 Result CineBench 11.5
ScreenShots Should Include Standard Config Data | Old Work Fine To Post | X2,X3, or X4 But Consistent Within Post | State Temperatures or Include In ScreenShot | CPU & GPU Clocks Should Be in ScreenShots | Do Not Ask, Do, or Do Not Do
Prepare Thy Selves | Weary Now I Prepare Day And Night For The Gathering | It Comes To Us Now | And At The Moment You Shall Know What Must Be Done
NOTE: As always, seeking clarity in relationship between temperature & results, so use the tools we have used here and we will all learn.
Current setup
Phenom 2 965 @4ghz
M3A79-T Deluxe AM2+ mobo
G-skill 1066mhz 2x 2gigs DDR2 5,5,5,15,24
His 5970
Enermax Galaxy EVO 1250
cooling
Enzotech Saphire wterblock
Mo-Ra 2 Extreme 360x360 radiator
4x180MM cooling fans
XSPC pump/res combo
Operating system
Windows 7 Home premium 64bit
http://i271.photobucket.com/albums/j...1/P3170308.jpg
Highest cpu clock attained in 06.....with 4850x2 singel card (uninstalled now)
http://i271.photobucket.com/albums/j...3dm0623942.jpg
heres my best heaven result 8xaa 16xaf extreme tesselation run on ambiant temps with 4ghz cpu (24/7 on 64bit os)
http://i271.photobucket.com/albums/j...71/heaven2.png
4.28ghz cinebench 64bit 11.5 (done at 14c chilled water)
http://i271.photobucket.com/albums/j...n771/cine3.jpg
Need to do the Cinebench 11.5 and throw up a screenie of it for the meantime heres cinebench 64bit at 4.4ghz
http://i271.photobucket.com/albums/j...nch6418580.jpg
hmm got some decent results here, no 4.5ghz 3d runs like titan! gj man, just shows how much a few degrees difference makes :)
sorry for the random pic sizes lol photobucket acting up :p:
current pic of rig, loop in sig - 3d runs w/ 4870x2 @ stock clocks:
http://i70.photobucket.com/albums/i8...s/IMG_0702.jpg
run of 3dmark06 @ 4.335ghz (cooler ambients):
http://i70.photobucket.com/albums/i8...5htthighnb.jpg
run of heaven 2.0 @ 4.25ghz (70f ambients) (16x/8x, 1900x1200):
http://i70.photobucket.com/albums/i8...heaven4250.jpg
run of cinebench 11.5 @ 4.3ghz (cooler ambients):
http://i70.photobucket.com/albums/i8...inebench-1.jpg
I need to take a better pic, My computer is a mess though and I need to tuck in some wires I changed the tubing a few weeks ago so I guess thats a start:shrug:
Crazydiamond how did you get tessalation running on your 4870x2?......I didnt know you could do that. let me know how you did it I still have my 4850x2 Id like to see what result it gets?
Well, I have to do a Heaven test tonight, I do have some 3dmark06 and Cinebench if I can find it on my website. I don't have the graphics power of most on here but here it goes. I will run some test tonight and will update. Hope I won't be to late....
System Specs
Swiftech Pump and 3x1 RAD, Enzotech Luna Block, and 50/50 Anti-freeze mix.
Phenom II x4 965 Currently 4ghz 1.456v, 2400 stock-v NB 24/7 WCG crunching
OCZ Black 1600 8.8.8 24 RAM
Gigabyte MA790FXT-UD5P Bios F8f
HD 5850 1GB
Windows 7 64bit
Corsair 750w 60amp Single Rail
System
http://3800z24.info/Phenom/Skeleton/Antec-965.JPG
3dmark06 Chilled Water
http://3800z24.info/Phenom/3dmark06-...850-single.jpg
Cinebench 11.5
http://3800z24.info/Phenom/Skeleton/CB-11.5_4.2ghz.jpg
Unigine Bench, I used defaults that came up for my hardware. Details are in the screen shot
http://3800z24.info/Phenom/Skeleton/...000mhz-gpu.jpg
titan, tessellation was disabled, sorry.. thats what i get for running it at 5am :D
:eek:
Placeholder, I hope:p: These things always seem to start right after I go to bed, with work the next day. I'll try to backfill but have a lot on my plate, a big honeydo list plus just pulled my HD. I'll need to install a new one, +windows 7 and all the tools, and run all the benches from scratch :( What's that whining noise?
OT, crazydiamond, do you feel the second small rad is worthwhile? I have a spare 120 (to add to my 220) but didn't figure it would make much difference.
Here are my results (so far :p:)...
RIG (specs in sig):
http://i30.photobucket.com/albums/c3...t/DSCN0433.jpg
I certainly don't have the strongest VC (4870)!
3D06 Results:
http://i30.photobucket.com/albums/c3...rt/3D06_SS.png
Cinebench 11.5:
http://i30.photobucket.com/albums/c3.../CB115_Max.png
The Heaven benchmark was really strange, I probably ran it about 10 times.
I'd never ran it before so right after downloading I ran it with my 24/7 clocks
(240x17x11x11) and actually got a higher score than I could get with my best OC.... :shrug:
Heaven (best OC):
http://i30.photobucket.com/albums/c3...aven_ssMax.png
Heaven (best score @ 24/7 clocks):
Sorry, no sys info panels opened, didn't expect to use it... ;)
http://i30.photobucket.com/albums/c3...eaven_Best.png
I'll have to play with this when I get home from work so I can figure out whats going on.
Simon, could you give us some pointers on settings for Heaven benchmark? If we all run different settings it's hard to compare.
I hope didn’t misunderstand because if I did I hope someone corrects me and I’ll retest before it’s too late?:shrug:
These tests were done with chilled water and yes they were all completed earlier.
I tried Speed Fan but it doesn’t read the core temps below 0C and didn't read up higher when I tried it earlier during these tests. I did try the CPUID HWMonitor later and found that it did read the core temps above 0-C but it was too late for my best tests below. These temp readings are what I have found in different areas some at idle some under load. The coolant temperature in the freezer at the beginning of testing is -22/-20C, bios reads the CPU temp @-3C, system 17C, HWMonitor read a maximum temp of +20C during testing of both CineBench 11.5 and wPrime 1024. Sorry that I'm not more helpful with the temp reading.
Below is a link to a photo of the thermometer showing coolant temp @-22C
http://i262.photobucket.com/albums/i...r/DSC01099.jpg
Below is a link to a photo of a bios photo showing temps CPU @-3C system @17C
http://i262.photobucket.com/albums/i...r/DSC01112.jpg
Rig frost on the waterblock
http://i262.photobucket.com/albums/i...r/DSC01114.jpg
3DMark06
http://service.futuremark.com/compare?3dm06=13637798
http://i262.photobucket.com/albums/i...27131score.jpg
Heaven 2.0
http://i262.photobucket.com/albums/i...9scoreDX10.jpg
CineBench 11.5
http://i262.photobucket.com/albums/i...it510score.png
I updated my Post here. I ran default, should I run again with everything maxed? Tesalation was on normal, res was 1080p, etc.
I grabbed a coolermaster wc kit today, it was on sale for ~120$. It only has a dual rad, but compared to air i'm in heaven now. :D
http://img709.imageshack.us/img709/3764/rigm.jpg
Here are some very quick results at normal ambient:
3dmark06
http://img7.imageshack.us/img7/2928/3dmark064200.png
unigine heaven
http://img293.imageshack.us/img293/4254/unigine4200.png
cinebench
http://img193.imageshack.us/img193/5408/cb114140.png
New HD, windows 7 64 HP installed, everything downloaded. Only spent an hour and a half on the phone with microsoft to get it activated (they gave me a full version activation since there was no upgrade path from xp for the home premium family pack upgrade). Yawn. Bear with me, first benches after work tomorrow.
Well Folks...
I just took the plunge and ordered a Crosshair IV Formula from ZZF! :woot:
I've been running on MidRange boards for the last couple years and have been wanting a nice FX board.... I figured nows as good a time as any...
Hopefully It'll live up to my expectations (at least it will look nice in my case :p:).
It cost me $280 with FedEx overnight, maybe I'll get lucky and it will be here on Saturday.
Welcome to the world of Water Cooling beta! :clap: :D
If your feeling frisky with the cash, this block is cheap and VERY nice for the price!
http://www.newegg.com/product/produc...82E16835708019
It may be able to lower your temps a few more degrees....
BTW: Something seems to be seriously wrong with your Heaven bench... :p:
First off... Sorry for the double post. :cool:
I know Simon didn't ask for this, but I agree with you Zeus...
There are a whole lot of options that can give wildly varying results on the Heaven Bench...
I've never used it before, but like I said earlier, I've been playing with it since I got off of work. ;)
I came up with these Standard settings that everyone may want to use. I chose them to be as fair as possible for folks who might not have the best Video Cards/Monitors...
(BTW: beta, now I see why your numbers looked so wierd 8xAA and 16x AF :shocked:)
Suggested Standard Settings:
http://i30.photobucket.com/albums/c3...Heaven_STD.png
The other good thing about these settings is that it won't take too long to run (with decent gear) and it still looks 1/2 way decent.
For folks that have 58xx (DX11) cards, feel free to change that option (I just don't have it :shakes:)
This is just a suggestion for a standard, I'm not trying to be bossy... :p:
Anyway, heres my result @ these settings:
http://i30.photobucket.com/albums/c3...D_HeavenSS.png
EDIT: I ran this bench with the sound off.
soon man soon........every time I think Im ready to upgrade the monitor I get something that acually is a performance upgrade instead.
Just in preperation for Thuban I bought (so far)
HIS 5970...............................$750
Enermax Evo Galaxy 1250........ $175
Windows 7 64bit Home Premium $130
thats only the last 4 weeks
Still have to buy
mobo$$$
cpu$$$
4gigs ddr3$$$
I dont even want to think about it:D
And you worried about my screen:rofl:
