link to auction? wonder if the seller has anymore
Sem: Most Core i7 CPUs start to thermal throttle and slow down at 100C. Any temperature below that is fine as long as your computer is stable. If Intel thought you were going to hurt one of their CPUs at this temperature then they would lower the thermal throttling point. The bean counters don't like RMA returns.
no sorry it was the last one but www.pctweaker.de have one with this batch.
Hmm, I just ordered a 3849A832, so I'll be able to do a head-to-head comparison against my 3845B026.
Is anyone putting up a list like we had with the S775's ? I'm getting a brand new 950 tomorrow, though I have no idea for batch. The one I get just has to be good. After 3 normal CPu's I hope it's time to get something decent for once :p
Who knows the batch 3847B019 I7 920 D0?
is good?
3849B018 4/18/09 P6T Deluxe TRUE air. First attempt
http://i455.photobucket.com/albums/q...4Ghz25Pass.jpg
Will try lower voltage
My i7 920 :yepp:
http://img155.imageshack.us/img155/8104/oc4.jpg
PLL 1.81
QPI 1.20
IOH 1.20
LL Enabled
I noticed my chip doesn't get hotter with high voltage, I can run 3.80Ghz with 1.25v with max temp 77c, and 4GHz 1.28v my max temp 80c
chip can do 4Ghz with 1.26v, it passed 25 passes LinX but it is not 100% stable, I have to up vcore to 1.28v for 100% stability, also temps are same with 1.26v or 1.28v, is 1.28v fine for 4GHz?
I'm using True120 unlapped
It bought it on May 3.
http://happy.ap.teacup.com/yomoyama/img/1245127903.jpg
CPU-Z :1.136V 191MHzx21=4011.2MHz Prim95 9h30s
http://happy.ap.teacup.com/yomoyama/img/1245463529.jpg
CPU:Core i7 920 BOX Lot.3845B027
Motherboard:GIGA GA-EX58-DS4 (BIOS F6)
mem:APOGEE APG3-1600-2GX3GT (DDR3-1600 2GB×3)
VGA:Radeon HD2600 Pro
HDD : Western Digital WD740GD
PowerSupply:Zippy 600W
OS : WindowsXP Pro SP3
CPU Cooler :MUGEN∞2(SCMG-2000) 12cmFAN*2
North Chip : Retail+12cmFAN
South Chip : Retail+12cmFAN
CPU Clock Ratio : 20X
Intel Turbo Boost Tech : Enabled
BCLK Frequency : 191
PCIE Frequency : Auto
DRAM Timing : 2:8 8-8-8-24
CPU Vcore : 1.136V (CPU-Z)
QPI/Vtt Voltage : Auto
IOH Core : Auto
DRAM Voltage : 1.640V
This 3845B027 is the highest. Thank you.
Hi phsinc1
>temp is high? I'm getting same temp @ same speed with 1.28v Vcore
A hot day leads to Japan.
Air-conditioning is not used.
Though CPU is also hot
http://i455.photobucket.com/albums/q...z/bumpdown.jpg
These chips ROCK!! 3849B018 ON AIR, CLOSED CASE !!!
how can you find out what the VID is for these the new realtemp and coretemp..doesnt tell
you can set all the system at default and look what voltage set the bios in auto.... theoritically that is the VID ;)
I dont run x64 and i only have 3gb of memory that will change soon tho.
That is all it will let me run in 32 xp it puts such a heavy load i cant do anything while its running with the settings in the picture.
I have windows 7 32 bit i'll try to grab the 64bit version.
Thanks MACMAC :)
Is the temperature of CPU too high? It worries a little.
http://happy.ap.teacup.com/yomoyama/img/1245127988.jpg
http://happy.ap.teacup.com/yomoyama/img/1245162569.jpg
If you are only hitting low 70C's that's perfectly fine for Core i7's.
Insane chip by the way, what are you cooling it with?!
Pseudo : Marcolecorse
Batch : 3847B019
vCore : 1.25v
vQPI : 1.21v
vPLL : 1.81v
Modèle de CM :Asus rampage gene
Ram: G-skill 3X2 perfect storm -6-7-6-20 1T
cooling : WC
T° ambiante : 23°
Screen :
http://img189.imageshack.us/img189/6...t42001h.th.jpg
