I can't change my damn multiplier :( Every time i change it from BIOS it's set back to x10 when i come into Windows :( And with clockgen my computer freeze :(
What is the problem ?
set your LDT to 2,5X
Make sure you click on `get values` before you change your multiplier settings. Once you change it click `apply FID` and then `set values` and your system should`nt freeze anymore.
Hey!
I've just tried that in clockgen, it seems to work fine if i set the multi to x9 and apply it, but when i want to run 2000MHz it freeze's x(
It is really p*ss*ng me off :(
try to clearcmos and retry. :/
or try to set to 230X10 and set multiplier to 9.
LDT to 2,5X or 500MHZ
Take it up SLOWLY....don`t jump from say 200FSB to 230FSB in one jump, rather do it in 15MhZ intervals. Also (VERY IMPORTANT) set your FSB to 210 in the bios and then play in ClockGen. For some reason it like the system a bit overclocked before you push it further.
Also your Mem voltage may be too low. Try more juice...say 2.9v and see if it helps.
i'd buy a 3000+ Today , an 0350 XPMW CAATC
http://pageperso.aol.fr/misteroadster/3000MAX.JPG
i think i can do better.
french touch
3ghz now ^^
Nice CPU man! :thumbsup:Quote:
What cooling? Chilled water?
yes, watterchilled
I just got my D-tek Pro-core and a Hydor L20 home today, now i'm just waiting for my homemade waterblocks for cpu and gfx, and my little Biostar IDEQ200P Barebone :P It's goig to be fun ;) How high do you think i can get my cpu?
Do some benches, or is this a critical shot???Quote:
Originally posted by neo.life
yes, watterchilled
nice thing btw... I have a CAATC 0404XPWM and I can take a shot from 2800Mhz.
These are nice chips :cool: 2550Mhz stable with 1.68v (Asetek water) :banana:
Humm les xpmw are good ^^
I buy too in 3000+ mister shop ( e-soph ) and i send a mail for stepping...
waiting responses et after gogogo ( adata4000 +an50rand tm 948U )
you mean extreem good.Quote:
Most XPMW can do 2500MHz stable in air/water and 2600MHz with chilled water.
I had a:
CAAMC 0449RPMW = 2250MHz max @1.8v:mad:
CAAOC 0350XPMW = 2550MHz max stable @1.79v
CAATC 0404XPMW = 2550MHz @1.70v still OCing
Lucky XPMW can do 2700MHz.:)
All with WATER and AIR.
I can get a 3000+ CBAPC 0404UPMW (CG stepping) :D
For me this
lovely !!!!
I buy thrusday my computer :D
Core cg is not very good for o/c
2.3ghz ( reviews of 3000+ in english site )
i think, i prefer good C0 of bad CG
hehe, :toast: this chip we have clocks realy good with prommie.Quote:
For me this
lovely !!!!
It can take high speeds :D
Unfortunaly it is not a lucky chip but a good performer
Waterchilled by this machine :Quote:
http://pageperso.aol.fr/misteroadster/CHILLON.JPG
Thanks ;)
But i hope better tomorrow :)
Weee..... I also have the CAATC 0350XPMW, not a CAAOC as I first remembered (I have a bad memory), until now I have not clocked it higher than 2300Mhz air cooled with stock voltage, will have my watercooling set up in the weekend hopefully, so let's see what my 0350XPMW can do, those 2900Mhz is just lovely... :slobber:
i fly so highhhhhhhhhh
i'm flying right up to the stars :D
i want more FSB... 400 and more, tips ?
http://downhill666.bei.t-online.de/R..._345_small.gif
worthless running on 400HT...
i just receave my shuttle an50R
http://www.yamafoto.com/users/niaboc...80-2-2-2-5.JPG
good job my friend ;)
:toast:Quote:
It seems to work fine with decreasing the multiplier to x9 now. I dont know what the problem was?
240x9 1:1 2.9v to the memory, Auto timings :( I had just cleared CMOS and then i forgot to set the timings :$
I dont know if my memory can get higher?
