Anyone have a link to 1.13 or to all of the BETA BIOS's archived somewhere?
It's true. CPU manufacturers implement Vcc drop across the cores through the VRM circuitry due to high load Icc, and the colder it is, the higher the Icc values due to less leakage, quicker on off transitions, quicker switching transistor speeds with less resistance -> higher voltage, less heat, less power. But Vdroop/Vdrop doesn't necessarily exist in the amounts you want in all boards, which is why ASUS provides the option of "load line calibration" and "voltage damper" to avoid it, because when overclocking, too many times Vdroop is much more than it should be for perfect stability at those particular settings, surpassing the low limit core voltage for stability, i.e. 1.3V idle -> 1.25V load, when you need 1.265V minimum load for perfect stability. So to limit this droop to less is good for oc and finding oc stability. Things get complicated when you complain about Vdrop and Vdroop for no reason, i.e. why does Vcore idle so high (which is good actually, provides a large offset from the low limit which'll cause instability).
We've had 16 BIOSes that I know of, including 3 official final releases, and another one coming up soon. ;)
Here's 1.13 BETA jesteronyer6: 1.13 BETA
You suck:p:
Thanks KTE !
One last Q is what is the best method for flashing these MSI boards, in the past I used winflash.
I always just use an FDD with the AFUD412 or AFUD418 flash tools. Easy and safe.
I'm wondering if burning in this thing will help at all?
the only problem I see with it is as I stated in prior instances it always froze without a load on it at high clock speeds.
Yea know find the max stable at XXXX mhz with X.XX vcore and then drop the vcore .01 and load it up with 4 toast instances or with cpu burnin.
continuing to work the vcore downwards/
not that I'm tring it or anything:rofl: :ROTF:
http://www.ocforums.com/showthread.p...ntentials+Burn there used to be a guide here
Well, did you not read me mention it a few times already?
If your system locks up randomly at idle but not in load, so did all mine, this one boots 2.8G and locks up only idling. You know why? Instability. :yepp:
That's why I did idle, load-idle-load fluctuation testing above.
You need to add NB volts or lower the NB speed to sub 1.9G and you'll have it stable. ;)
Testing BIOS BETA 133.
Pros
*Excellent addition. Can now POST and run perfectly ALL RAM dividers, including 1066 at 200HT. 800 is stock.
http://img85.imageshack.us/img85/6949/133bl3.png
Cons
*TLB patch applied by default without removable option. :(
*No AM2+ P-State options that we need.
BTW, I'm not sure if I've mentioned it in this thread yet but VIDs are basically VCore OFFSET values, meaning, each VID allows a certain range of CPU Volts. The lower the VID, the lower the VCore available and the higher the VID, the higher the VCore available. :)
KTE +1 nice job...Now only if the Ts770 had working memory functions like above:D
Does the Unlocked NPTFID work or do they even have it in the Bios?
I did about 5 times already LOL :clap:
Man when are they gonna release a new bios with the ability to enable and disable the TLB patch....
Gonna try what you stated but ATM I'm happy at 2.6 / 1.41v stable. Not high HT ref tho its 11.5x226, 2k on NB and HT, ram at 902 4 4 4 15.
nice 1066 fixed...
can you post a compare of this bios vs the 1.13 at same speeds...
like an old setting/pic you already did
BIOSes are out, at least 3 which have the option to enable/disable patch. ;)
Even though the disabled option still doesn't return the performance of the no patch versions.
New BIOSes don't have the options for NB FID/VID/DID. :(
Can we disable the fix via crystalcpu with a enabled patched bios?
is that possible?
Nice onward to 11.5x235 now thanks to you.
Of course, it's been covered many times before.. BUT the performance is still bad compared to non patched BIOS.
Totally non-patched BIOS is like this:
http://img220.imageshack.us/img220/5093/winzf1.th.jpg
With present BIOS at those settings, you're looking at 1/3 that performance. :(
Testing BIOS P0H
Pros
*Can now POST and run perfectly ALL RAM dividers, including 1066 at 200HT. 800 is stock.
http://img87.imageshack.us/img87/1997/p0htf9.png
Cons
*TLB patched but removable option there.
Same as BETA 133 in most cases for me but for the TLB option. :(
That just plan sucks 1/3 of a performance hit. Who in there right mind would run a bios that give them 1/4 less the performance across the board. I mean I cant under stand it. If the B3 stepping is fixed and you where to have a bios with the patch are you still going to be hit with the 1/4 loss?
Prozactly!:D
Cant say about worth of DFI Bios on Phenom end but for dual core they are getting worse!
16 Bios.......You Bastage:lol: You need to come to DFI arena I have already Knighted You:bsod: Now you're obligated!:toast2: better have 3 more...:toast2: :toast2: :toast2: don't forget the Pink TuTu either :rofl:
I thought it was paxiactly:ROTF: :rofl:
it works :D
Here's a direct comparison of the best of the new BIOSes (patched>turned off) compared to my favorite older BIOS - head-to-head WinRAR shootout at the same settings within 3-4 minutes of each other.
BIOS P0H (P0F is the same)
http://img352.imageshack.us/img352/3241/p0h800hs3.png
BIOS 113 BETA
http://img214.imageshack.us/img214/9160/113ax3.png
See any difference? :p:
And now the OC fun begins. VIDs, DIDs, FIDs, what else... :D
1800.2 vs 1800.1 HT&NB :shrug:
Remind me not to try any new bios.....:mad:
nice!!
How can 230 be stable and 232 cause a BSOD no matter what NB, HT, and cpu vids. I didn't relax the ram but it's able to do ddr1000 at these timings.
I even did as you suggested and dropped the voltage and muilti's on the HT and NB all it did was make it easier to get to the desktop and not freeze up and 230-231 fsb.
I guess I must be close to the max of the cpu but prime doesn't error on core 3 or nothing just BSOD kinda like ram is outta spec....
I have ram at 127ns instead of what I was running 105ns
current 2+ hours into testing. time to drop core #4 off of prime so I can game.
http://www.jonspd.com/jonspd_uploads/screenies/test.JPG
any thoughts?
just be happy with 2.6ish?
NOT I want 2.7 its only like 50mhz away :D
Something I want to say is: those overclocks in reviews are totally hype. Single 30min and 1hour tests to consider something totally stable is just far from correct. Let alone after 2 hrs the temps will usually rise 1-3C across the cores. Why can't they leave everything at the same conditions and just run 5-10hr stability testing? It doesn't take long for a one off, it'll take 'em longer reading their daily IT gossip.;)
That's how core limits are surfaced. 1MHz difference->instability. :yepp:
That's the blend test you're running, right? Run the small FFT for CPU if you want to find errors, blend is only if you don't know the RAM stability and want to test RAM mainly. CPU isn't tested/loaded as much at all.
However, IDK what your core limit is yet and IIRC you could hit 260HT, so I'm still doubting things here. To me, it looks like your RAM but you need to run Memtest and if you can't run bootable Memtest at those RAM settings due to them not being your bootable options, then stay in Windows, keep all software closed and run Systools Pi 32M 4-core multithread, highest priority, and if that passes then run RightMark Memory Stability Tester followed by in-windows Memtest (open two and set 700MB for each). If any fail with one error, set MaxAsyncLatency to 60 and close>open>try again.
Mine does 230HT pretty easily stable at 9x NB stock volts, same with 232HT and 234HT. However, that's the absolute limit for the NB at 1.25VID 9x = ~2.1GHz. Over that by 1MHz and it'll get NB instability showing up randomly.
Check this:
I undervolted CPU to 1.121VID 1.192V @ 200x12.5 = 2.5G and NB/HT to 1.112VID ~1.0V 1.8G.
Then ran P95 and played a game...
http://img81.imageshack.us/img81/279...2067bg6.th.jpg
The system was quite stable in P95 and benchmarks... until I started my 2nd round of tests, load cycling. In any case, the power consumption was now much less, topping out at 151W AC. ;) What it means is that, I have headroom to undervolt at stock and when overclocked.
So right now I'm mainly testing the NB/CPU headroom... testing CPU 1.2VID 1.224V idle/1.208V load 2.3GHz and 1.3VID NB 2.4GHz. On 4 hrs now, fully stable. Last screenshot I took:
http://img242.imageshack.us/img242/6...ablear0.th.png
2.5G NB is next. ;)
I totally understand the 12-24hr full load prime testing and I would do it with both small and large as large is normally the 1st one I run the small I never run blend just run memtest via boot disk if I'm gonna check ram stability. It ran for 2 hours at over 1000mhz with 4 4 4 timings and 2.2vddim
I have another set coming this way some tracers. I have always done mediokra testing till I find where I really want to be at in terms of how things are running and how stable they are and what bench's/test show.
I have yet to try max fsb again I just wanted to get a fill of how high I can clock the cpu at what vid. I think my max cpu vid is about 1.45. I really wish I had hours on end to let this thing just run P95 and memtest but seeing is it's my primary rig I have to find the sweat spot or as close to it as I can and once that is done then it will.....
24hr prime
6 hour memtest
6 hour loop 3dmark
32mb superpi twice
I used to test by finding where it wasn't stable max and then coming down from there and thats kinda what I do but not like I used to as this thing has no desire to run 2.7 ghz LOL.
FORGOT to say 2.4ghz on nb:up: :up: :up:
