well it sounds like maybe you have a bad ram or something. I would try to do some memtesting and see if it reports errors at stock... put maximum voltage ram is rated for and if it doesnt pass memtest, try each stick individually.
some data about my Bad Axe 2 FSB.
Max FSB on unmodded mobo was up to 470MHz (E6300ES)
This is with default cooling+ 80mm vent@2000rpm, and of course
I've changed thermal pad to AS5 :)
After Vmch mod with same cooling 3D stable:
1,75V Vmch- 450MHz
1,85V Vmch- 470MHz
1,90V Vmch- 480MHz
2,05V Vmch- 490MHz- screen:
http://www.oc.pri.ee/BadAxe/BX2/i975@490MHz.png
I'm choose to stop for now- 2V for aircooled chipset is enough I think :)
For 500+ FSB I have to choose something cooler- ln2 for instance :D
PS. With QX6700ES max FSB was only 390MHz :(
does this board support a total of 8 SATA drives? (i.e. can i plug an internal drive into the red connector?)Quote:
Originally Posted by heikis
I believe there are 3 versions:Quote:
Originally Posted by bloodbanger
-an OEM 'stripper' model which eliminates firewire, the marvel SATA ports, and i believe optical out on the sound
-a 'blk' version (bulk). should be same as retail but w/o the accessory cables (not sure what else its misssing)
-a retail version
yupQuote:
Originally Posted by MrDisco
Is there already a working clock generator to OC in windows? IDCC doesn't startup here :mad:
Sorry if I missed this but I can't find anyone posting about VRM temps in this thread.
Anyone have any temps on the board that are watercooling? Is it even a factor?
Got a few more BSODs
I ran a set of quick memtests.
super talent ddr2 800 at 4-4-3-8
on the default settings it ran fine for one round.
one the 10th test it ran fine with nothing for one round.
With all bios selected I let it run for 2 tests and was up past 1 million errors so I stopped it. I am not sure what testing is best to find out if my ram is crap but I will run a long run of standard and see.
Is this saying the bios is bad for super talent? I hope there isn't a bad factor between the board and the ram.
I tried to put a fan on my NB but I have a Tuniq Tower HS and it doesnt leave enough room. :(Quote:
Originally Posted by Omastar
Run test #5, for at least 3 pass. test 1 and 2 are easy to pass, test 5 is the hardest one i think.Quote:
Originally Posted by Teratism
If you see red.. its bad :P Be sure to set all default timing with maximum voltage. Keep your processor at stock... raise mch to 1.625v .
Try each stick separatly on the same test...
I went throught all these things too with my gskill pc4000... gskill rep also told me that memtest was good test, but memtest from hci desing is better for testing stability. Its a win32 application.
you might want to post your setting..are you overclockedQuote:
if so set everything to default and loosen memory timings and run memtest to see if it passes..if so keep everything stock and tighten to expect default timings and see what happens...once you know the ram is ok, them try to overclock but you will need to loosen ram timings I bet...
it has been said over and over cpu speed is key not the ram latencies
As soon as I find a Commando, ill buy and compare :)
I had my Infinity facing so the wide side was facing the PSU, not the exhaust, so it didn't partially cover the NB.Quote:
Originally Posted by chaotic646
I have the same ram as you in the xbx2 and it runs stellar for me. It ran at 893mhz at 2.3v at 4x4x3x8 but i run it at stock voltages (2.2) at 4x4x4x12 now at 893mhz with a 356mhz bus and ram at 667mhz which gives me a 3.2ghz overclock and ram at 893mhz. Ran memtest overnight and it ran with no errors. Orthos at 6 hours also ran fine. Maybe you got some bad sticks or are overclocking too much which in turn is bumping your mem speeds up and it can't handle it? A coworker also uses the same board and ram as me and he has had no problems with it.Quote:
A few pages back i did hear of some people saying that the new BIOS 2395 caused timings to have to be looser so maybe that is your problem too? Maybe going back to 2333 might help you.
Well theres only one way to correctly seat a Tuniq Tower, if you seat it any other way you lose cooling capabilities. The exhaust side of the fan has to be facing the back of your case for optimal cooling. I dont think theres even any aftermarket NB heatsinks that would fit this board with a tuniq tower installed.
I had one and unless you plan on running sub zero on a 3060, don't get it. Overall the board just didn't work well for me. BAD vdroop. Plus xbx2 is faster since it's 975.Quote:
Originally Posted by ChaosMinionX
P5B-Dlxs are good for quad cores, low multi chips and subzero like AFI said. But there are a lot of good mods for them, so you're not stuck with typical Asus crappy vdroop if you have some basic soldering knowledge.
I'm waiting for my new XBX2. -_-
I've been getting those 2 letter codes (bottom right corner of screen) since I first posted, and every time thereafter.Quote:
I figured they were some normal diagnostic tool, but do they in fact indicate an error? :confused: This occurred with 2333 and 2395 BIOS.
My RAM (see sig) has performed pretty poorly under intense OCing-- I can get my FSB to 400, giving 3.6GHz, and with 1.425v I was orthos stable for 5+ hours. But after trying to use the PC with anything but orthos I got a BSOD and instant restart. Upon memtesting I saw that, even with tame timings, the RAM was failing miserably, giving errors all over the place.
Is this bad RAM, or a peculiar OC wall I'm experiencing?
Here's what I have going on right now, memtest, orthos, and general-tested stable.
http://img169.imageshack.us/img169/4...apture1wj8.jpg
vdimm ?
ignore me when i posted that. They are just diagnostic notesQuote:
It seems that once I did the latest bios everything went south, bsod's, IE crashing and any program I tried to install would fail. I installed my evga board to get back on line and it would not boot, my Dominator C3DF bit the dust:eek:
When I had my system at 3.6ghz, I tried vdimm all the way to 2.32 (I have an 80mm fan blowing over the dimms and northbridge BTW). I don't remember the exact timings I was using.Quote:
Originally Posted by Supertim0r
I'm going to do some more fooling around right now and get some more precise info.
2395 BIOS is a crap chute. Avoid it.
bios 2333 linked in the first post
Still not prog to overclock in Windows ?
