guy i am having a problem, my graphic is only link at 1x :(.
what should i do, i reseat the card, and it links 16x, then i turn off and turn it on it return to 1x, it drive me nutty.
I flashed to the 711 bios.
Is this normal?
It was 16x and 16x at one time..
A bug in cpu-z or bios?
YEAH UH - I can't even press enter to enter it - enter does nothing NOTHING!!! ARGH!:mad:Quote:
Originally Posted by funkflix
Does CPU-Z's Mainboard Tab show correct information about your motherboard or does field it usually is displayed in go blank?Quote:
Originally Posted by Concorde Rules
Unless something else is up, normally you change FSB by either:Quote:
Originally Posted by TheGoat Eater
- using keys + and -
- keying it in directly (without ENTER).
i don't think it cpu-z bug, if you a 3marks bench you should see that oyu get very low fram rate.Quote:
Originally Posted by OnDborder
it get 16x link if i reduce my FBs to 415MHz over that it 1x, i am new to this board, the only bios i us so far is 711, the board camw with 507.
I just wonder does this happened to other bios beside 711 if you go for really higher FBS?
Does setting the SATA drive work under AHCI mode give me any additional performance? and i mean installing the windows on the AHCI-enabled hard drive. compared to the IDE mode ofcourse
Originally Posted by icywater
I have the same problem of 1x, but it went away after a couple cold-boot with no changes to the BIOS settings.
I flashed to 0711 but had too many problems. Couldn't even change the boot drive. Anyway I'm back to 0706.
http://i51.photobucket.com/albums/f3...ntitled371.jpg
0706???Quote:
Originally Posted by zizo
try 1101 or 1401/1402
Quite a bit better!
and a stupid question, what program is that displaying stuff like the vcore?
Is there a xp64 version?
nop it's asus probe : ) (green) other one is CPU-Z :X
0711 is the latest and 0706 is a beta. Us P5B mobo users don't have a higher version then that. You have the P5W.Quote:
Originally Posted by catscit
It was the bios, 711 that was the problem. My 3dm2k5 score was in the 5800 range.. Re-flashed to 614.
I think most of you people flashing to 711 bios forgot to MANUALLY CLEAR THE CMOS afterwards. This is a MUST, which is why you're seeing these anomolies left over from older bios settings.
I have the 711 bios and have never seen this 1x PCI-E issue. I also cleared CMOS after a few cold boots. I have cold booted and restarted many times and so far nothing.
flashed to 711 also . all goes fine , and of course cold boot gone away :D
Guys does anyone know how should i wake up my mobo from bios corruption?I cleared cmos+turned off battery,but no luck.It happened when i tried to play with max fsb on boot.
if i cold boot my machine it is fine now :), it does not like warm boot very time i warm boot it chuck me back to 1x link :(.
Has anyone else run into this problem?
When I go past 360 FSB, my CPU scores go up as they should, but my 3DMark06 score goes way down (it's an ATI x1900 XT) This happens anywhere from 360 - 402
Any thoughts would be most helpful...
Same here with the 711 BIOS....oh thank heaven for 711 :DQuote:
You guys SUCK at debugging!!!:p: :stick: :eek:
all this freaking time I was wondering why my 3Dmark05 scores were a little low compared to the rest of you, and it was because I had THE WRONG slot installed on my X1900XT :brick:
I had it at 4x instead of 16x because I had installed it in the universal PCIe slot, and not the real primary 16x slot...LOL!
check it out now!!! Super stable, good temps, down from 3.38ghz (because temps were a little high for my liking):
http://upshizzle.com/gallery/albums/...d_PCIe_x16.jpg
:woot:
Bios 0711 ok here
Over clock to 400+ fsb, do a warm reboot and see if still says x16.
Ya not a problem with that it stays at x16 not a problem for me at least.Quote:
Originally Posted by Blue078
I have tried both and found only very minor differences, I use AHCI because its supposed to utilise features such as NCQ on SATA II drives I think but it would be great if anyone more knowledgeable could explain further :)Quote:
Originally Posted by heikis
At 400FBS it is still ok, for me. Actually up to 415 FSB warm boot is ok. Why don't you try 420FBS :) and see.Quote:
Originally Posted by deathman20
