Again my BRAND New motherboard is in and NO POST. the bios is 0801 and i have a feeling this one can be fixed but i feel i tried it all ie. clear CMOS
what else has worked for you guys that has had this same problem
If anyone tries to watercool on this mobo, a whitewater block wont fit. Its too wide and hits the capacitors near the cpu socket. I had to find out the hard way. Anyone want to trade a ww le for a apogee or something similar? I gotta get a new block and wait even longer now to get my computer up and running.
So far I havent been able to figure out what it changes nor have I seen anyone post what it changes.Quote:
Originally Posted by revenant
For some reason my USB ports are not detected within windows. I have tried to following things:
new board
latest bios
new CPU
new memory
new hard drive
new OS (have tried Win 32 and Win 64)
setting every USB setting within the BIOS this or that way to figure out what is disabling it
2 different OSes on two different boards with two different CPUs and two different sets of memory are having this issue for me
USB mouse and keyboard are detected within the bios and work fine to install windows. As soon as I get to the first time you see the desktop, bang, no USB. WHAT THE HELL IS GOING ON??
This wouldnt be confusing at all if USB devices didnt work in the bios.... But they DO!
I hate to sound like a raving lunatic, but Im desperately searching for a fix for this issue. Ive tried everything that seems obvious to me... Everything is at stock right now and default bios settings... This is my first intel build and its been a total gong show so far...
edit: setting it to enable only 4 USB devices makes my back USB ports work, but neither of the headers, and not my integrated wi-fi.... Does anyone have a better fix for this?
hi everyone... having same problems since i installed my rig basically here's my stuff
(NOOB HERE)
lol
Mainboard P5W DH Deluxe
CPU INTEL Core2 Duo E6600 (2.4GHz)
Power Supply CoolerMaster iGreen Power 600W Sli
Graphics Card Asus EN7600GT
Optical Drive LG GSA-H10N
Memory F2-5400PHU2-2GBLA (run memtest there no error)
Hard Drive 320GB SATA 3.0Gbp/s Seagate 7200.10 hardisk
OS Windows XP Pro sp2
Bios 1305 (flash my new bios windows based)
after installing windows, try all the USB.. all was workable. after 2 boots thereafter.. onlt 4 out 8 of my USB ports can be used n all this 4are at the I/o ports . help me pls.....
can any of u guys recommend me on how to solve my USB ports problems.. is it due to a bug or something?
THANKSS...
REGARDS...
mine is worst cant detect in bios n windows...
HR-05 cannot fit on the NB of this board but does fit the SB.
The only 4 that work for me are the rear panel ones as well. I also can't find a way to get the integrated wi-fi to work with half of my USB ports disabled... It appears to simply be installed over a USB header, so I guess that's why it doesn't work. If someone has a workaround for this, that'd be great.
BUMPQuote:
Originally Posted by 450tantrum
I had the same problem. This has been well documented here. I had to get another 775 CPU (an AMD i had) installed it, that allowed me to post....then upgrade the BIOS to 1101. Then installed my xonroe 6600 chip....and it posted fine.Quote:
I have issues with my sound card but that's another matter....
I read the complete release notes, and there does not appear to be anything significantly changed to warrant using it vs the drivers on the ASUS supplied CD.
Andrew
How do I install Ai Booster? The setup gets part way, then I get the
error mess ".ACHI driver load failed"
wow that saved me a bunch of time, thanks man :)Quote:
Originally Posted by zax1972
edit: i need to update my sig
i have a problem here pls help,
when i turn on my avr the pc will automatically turn on without pressing the power button then after a few seconds maybe 5 seconds it will shutdown again, do i have to change anything in the bios of this board?
You have a socket 775 amd? :rolleyes:Quote:
Originally Posted by Robster
:nono: :slapass:
anyone here done the v-droop mod? what results resistance are you getting, i'm down to 25k and still getting some movement.
Originally Posted by gersson
My apologies...a celeron
Originally Posted by aamsel
this 8.1.1 version improved the performance of the jmicron controller on this board. I have 1 drive attached to that controller and 4 to the ich7r, and the jmicorn was always REALLY slow. This was noticable in windows (windows would "hang" while trying to access the drive under certain circumstances, this is now gone). I was running 8.0.1 before (got it from the intel website).
Hi folks...
Found 1402 bios here: http://www.forumdeluxx.de/forum/showthread.php?t=256507
I Don't know whats new..
thanks for the link :D
Originally Posted by Homeronte
free multiplicator choice for example with a E6600 of 6-9
Yeap! i've installed and works perfectly
Hi my system temp on this board is running at 52 when idle is this normal or should i RMA the board my cpu runs at 26 idle i have not tried to oc yet.
Really? Or are you joking?Quote:
Originally Posted by arne72
Shoot 1401 hasn't even made it to ASUS's official site yet.
really
